Question about Rapid Classic 1 Plier Stapler - Boxed 90119
How open to replaced staples - Rapid Classic 1 Plier Stapler - Boxed 90119
How to reload staples.
If this is a staple gun then you need to release the tab on the back of the gun. It will release a long spring with a push rod on it. Insert the new staple bundle and replace the push rod. If this is a desk top stapler then pull the top until it opens. Set staples in and close the top again. Make sure to clear out any staples that may be loose or lodged before.
Nov 29, 2015 | Staples Tools & Hardware - Others
How to Replace Staples in FS-526 Finisher
if the stapler is out. then open the finisher door and the staple cartridge with blue handle pull out and replace, do not throw the blue part away as you only replace the middle staple pack. Or open the finisher door and turn the green knob to bring the stapler to you
Jul 23, 2014 | Konica Minolta Bizhub C652 Color Copier...
Replace a staple unit in a di 3510 minolta copier
Sattle stich stapler or the corner stapler.
Corner is inside the machine open the front door turn green knob to bring stapler out then remove the blue/green cart. do not throw a way you will be replace the staple not the whole cart.. Sattle stich is the stapler that make you booklet with to staples in the middle. will be up on top of the finisher but under it same deal do not cast away replace staples only and make sure that you pull out the top section and reseat so the copier knows you replace those staples
May 27, 2014 | Minolta bizhub 250 Black and White Copier
How do I replace the staples in Stanley Bostitch B310HDS? I cannot seem to figure out how to open it.
"The staples load from the rear of the stapler. At the back end of the is a piece of black plastic that extends beyond the end of the stapler. This device holds the staples inside the stapler. To open the area where the staples are placed, push this extended button and lift up on it. The spring device that holds the staples inside the stapler will then slide out. Place a new strip of staples inside the stapler on top of the two metal guide rails. Then insert the spring device to lock the staples in place. The stapler is now loaded and ready to work. " hope this helps you out
Jan 06, 2011 | Stanley Bostitch 00540: 00540 AntiJam ?...
Staple unit impossible to open
Has to be empty to open. At bottom there should be a small black lever that moves down to indicate staples are present. This sometimes falls out giving a false replace staples message. Cartridge itself must be replaced. This is the cartridge where you insert the staples into. Clear plastic with spring.
May 18, 2010 | Canon imageRUNNER 5000 Copier
On our 5070 machine it ran out of staples. When
take out the staple cartridge and in the clear plastic you will see the arrow engraved the white box also has a arrow these two have to overlap each other to open the case it has two little tabs at the bottom press them in might wanna use a pen or something and the top part will pop up just pull it out
Feb 04, 2010 | Canon imageRUNNER 5570 Copier
I have a Ricoh Aficio 1035 stapler problem.
if you press the finishing button on the display does it so stapler function there ? or try taking the staple cartridge out and then close the door on the finisher and see if it says out of staples. if it does it knows it has a stapler unit.
Jan 20, 2010 | Ricoh Aficio 1035 Copier
How do I open the swingline model 900xd
It took me and my boss wrestling with this mongo stapler for 15 minutes to figure it out! :0)
To open the front end, pull up on the handle while simultaneously pushing down on the small black lever on the front. This takes some firmness and be warned, if it's jammed with staples it's going to take some serious force to get it open - watch your fingers!!! I strongly suggest the minute you get a jam, open up the front and clear it. Don't continue to staple in hopes it will work or clear itself or you will have a build up of jammed staples making it almost impossible to open and clear. Also note that when you open up the front end the staples tend to shoot out so be careful.
To open the back end to load staples, push forward and up.
Hope this is of help :0)
Dec 16, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Replacing staples
If I remember correctly, you open the cover and there should be a release handle, the staple unit will swing/ slide out , gently grasp the used staple cart. and while pushing down and pulling out. Install new staples.
Dec 20, 2008 | Toshiba e-STUDIO 282 Black and White...
Rapid Classic 1 Plier Stapler - Boxed 90119 Logo
96 people viewed this question
Top Rapid Office Equipment & Supplies Experts
Bill Boyd
Are you a Rapid Office Equipment and Supply Expert? Answer questions, earn points and help others
