Question about Dryers
Wireing in a previous answer since i only have a ground and no neutral but I have red and black for the 218 do I hook my ground to the neutral post on the recptical
  • 565 Answers
In theory that would work, however, the technically correct way to do it would be to install a 3-wire receptacle and a 3-wire cord on the dryer and make the bonding connection between the neutral and equipment ground (the dryer frame) using the factory jumper inside the terminal connection block of the dryer.
Posted on Jan 26, 2009
  • Bob
    Bob Feb 21, 2009
    Thanks for the positive feedback and taking the time to vote.
Iam wiring a celing fan with a remote(added). The wires from wall switch are green(ground), white(neutral) black(fan) red(light)? Hooked to the wall switch remote. 2. Fan green, white, blue, black. 3....
I'm an electrician and will be happy to help you out. I need a little more information to answer accurately first. 1) What is the brand and model number of the "ceiling fan with remote". 2) If replacing / adding switches, how many locations will control the fan / light fixture? Please provide this info and I'm sure we can get this working very quickly.
Dec 12, 2012 | Dryers
Wiring diagram sunsmart. I am replaceing a timer swithch of a differnt brand. I have a single pole installation, but the power enters the fixture and then comes to the switch. The diagram in the box...
Sounds like you have the GE sunsmart timer, and are wiring the timer for single-pole.
Following information does not apply to 3-way timer wiring.
Add a comment if you have different timer.
Start with previous timer:
The previous timer was connected to two wires: Hot wire and Load wire.
Hot wire carries power from circuit breaker.
Load wire connects to fan,light, or motor.
How to wire Sunsmart:
1) Only one wire in the electrical box is Hot. That wire is usually black. Connect black Hot wire to timer-black wire.
2) Load wire connects to timer-blue wire.
3) Timer-red wire is capped off for single-pole wiring.
4) Timer-green wire connects to bare copper wire.
5) Timer-white wire connects to Neutral wire. This will power the timer electronics. The previous timer probably had a battery to power timer electronics. Neutral wires are white wires that are twisted together and covered with wire nut and pushed to back of box.
6) If box does not have Neutral wires, then connect timer-white wire to bare copper ground wire until neutral wire can be run from any nearby outlet box.
7) Try the timer, and if timer does not work, then reverse timer-blue and timer-black.
Resources:
http://waterheatertimer.org/GE-timers-and-manuals.html#15312
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Oct 01, 2011 | Hardware & Accessories
I have tried to install the Utilitech timer but am having trouble. I have a ground, black, and red wire that were previously wired to a switch that controlled my outdoor garage lights. I tried to hook red...
Sounds like this was probably a three-way switch you are replacing as there is no neutral (white) wire in the box. If so, you can splice the white wire to the green wire in other three-way switch box; then hook the green wire in the box you are placing the timer to the white wire of the Utilitech timer.
Apr 17, 2011 | Intermatic & Self-Adjusting Wall Switch...
Need to know how to hook up to 220 power supply what wires go where we got a red wire,black,white, and green which is ground can u help?
L1
L2
L3
Neutral
Earth
North America
Black
Red
Blue
White
Green
There is no blue cable in a 220V, so you have only; white, black, red and ground always green colored wire.
Looking your plug frontal side.
Green Ground on top (semi-circle)
black on left
red on right
white on bottom (neutral).
Jan 10, 2011 | Miller Bobcat 3 Phase Welder Generator...
I have a 4 wired pig tail...dryer has 3 terminals...can I connect the ground wire to the neutral terminal?
Match the red to red, black to black, white to center. Remove the green from the center terminal that connects to the case and terminate it back on the center white terminal. Hook the green from the cord to the cabinet where you removed the green from in previous step. Be sure the black and red wires are on the outside terminals!
Dec 28, 2010 | Dryers
Wire from circuit breaker is Black/White/Bare(ground). From Jenn Air is Black/White/RED/Green (ground). How do I wire? Jenn Air Black to Black, Jenn Air Red and White to White? Grounds (Jenn Air Green to...
depending on your local electrical code:and I see that the unit is 240 Volts A.C., then RED=Power/Black=POWER(L1 & L2)/WHITE="N"Neutral/and GREEN=SAFETY GROUND,on the new unit, then use from the wall power BLACK = L1 and White= L2. then on the unit RED=L1 and BLACK=L2(either way you hook these 2 up there isn't a polarity issue on these 2 wires) on the units hook-up/then use the BARE supply wire as neutral and tie BOTH WHITE and GREEN from the unit together to this BARE wire
Apr 29, 2010 | Jenn-Air JED8230 Electric Cooktop
We have moved and the three prong cord now needs to be four prong
Ok here is how to hook up looking at dryer. Left brass screw is hot put red or black wire on. Center screw silver is neutral put white wire on. Right brass is also hot put the red or black wire on which one you have left. The green you ground to the dryer body or you can put with the white wire.
The reason why you have to hot wires is that it is a 240 volt dryer. Each hot wire caries 120 volts. The hot wires are the red and black. The white is a neutral witch is also a ground
I hope this helps. If you have any questions please ask before you rate.
Good Luck And Thank You for the post
Oct 20, 2009 | Dryers
Kenmre dryer electrical connections
Yes. Ground and neutral connect to the same point in the breaker panel, and neutral is not needed for an electric dryer.
Jan 26, 2009 | Dryers
Jenn air model JED8430bdb
A similar concern on a different model (8230):
To my knowledge, the:
green - ground
white - neutral
black - 120 to ground
red - 120 to ground but between red & black, it should be 240. A Jenn-Air JED8230 requires a 3-wire, 120/240 Volt, 60 Hz Outlet.
Pls consult/confirm with your local electrical utility/codes the availability/applicability of this power/wiring system or reference National Electrical Code, NFPA No. 70
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 12, 2008 | Jenn-Air JED8430 Electric Cooktop
Dryers Logo
63 people viewed this question
Top Dryers Experts
