Question about Kenmore 43142 Front Load Washer
Gunk in Front Loader
There is gunk build up between the drum and the belt .... any ideas how to get it out completely or how to prevent it? Thanks.
  • 5,911 Answers
If you are talking about the gunk build up around the rubber DOOR BOOT, that is actually a common problem. You can take some cleaning rags with some bleach spray and wipe thoroughly around the entire door boot. Make sure you clean the rubber boot as well. About once a week you should run the machine with no clothes in it on the hottest cycle you have. Add some bleach in the dispenser and allow the machine to complete the cycle. This will kill any bacteria that is left inside the drum and drain lines. Now, preventing the problem from coming back will take a little diligence on your part. Routinely, clean the the door area as needed and LEAVE THE DOOR OPEN between washes. Because of the nature of these machines, the door seals tight and the drum is dark. This allows the build up of mildew over a period of time, because the tub is never allowed to dry out. A little water in the bottom of the drum is normal, but the door area needs to dry. I hope this is the problem you are describing and I hope this may help you.
Posted on Jul 16, 2007
SOURCE:
Our admiral 7005l washer has a build up of black gunk around barrel , any ideas?
Mildew because you are using to much soap. The mildew hangs in the extra suds in the washer and feeds on the skin and food removed from your washing the clothes.
Mar 14, 2015 | Admiral Washing Machines
Model WF7700N6W1 - front loader - smell? Rubber seal inside door peels back a bit to reveal buildup of gunk between seal and inside frame? retaining water here?
Ok, nothing to worry about. You have bacteria growing in your machine. Clean out the slime from the door seal using a soft cloth and soapy water. DON'T use any harsh chemicals such as bleach !
Remove your detergent drawer (if possible) and clean it thoroughly - a dishwasher will do this very well. Disconnect your machine from the power supply and clean thoroughly inside the space where the dispenser drawer was, using a toothbrush or larger nylon brush and a soft, soapy cloth.
Using liquid detergents all the time can cause a build up of residue over time, which gives the bacteria and mould somewhere to grow. So try a hot wash cycle (without a load) using a powder detergent intended for whites. Washing powders contain brighteners and chemicals which are hostile to mould and bacteria.
Finally, leave your dispenser drawer and loading door open every night to allow fresh air to circulate through the entire machine. This will reduce the number of cleaning occasions needed.
Jan 10, 2018 | Samsung WF337AA Front Load Washer
Smudging across the page.
Here is a generic question I would like you to consider.
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If this does not apply to then do not worry about it.
My concern is that the gunk you are seeing is caused by toner leakage. To the best of my knowledge, current day drums cannot be serviced. They have to be replaced. Wiping the drum will scratch the surface and you would still need to replace the drum.
Also, it may be that you are at the "End of life" for the drum.
My suggestion would be to have the printer serviced by an authorized repair technician.
Don
Nov 12, 2009 | Brother MFC-9440CN Laser Printer
Hi I have an Ariston Aqualia front loader. It has
You could try mild solution of bleach to the drum, perhaps replace door boot seal..
Nov 04, 2009 | Vacuums
Oil on clothes front loading kenmore washing machine 7 years old
Oil cannot get on clothes from a front loader . It's probably the liquid fabric softener you are using . Either try a different brand , use dryer sheets instead , or make sure the water temperature is correct for the softner . Also check the front drum seal , for built up , undisolved softner , collecting " gunk " which may be getting on the clothes .
Sep 16, 2009 | Kenmore Washing Machines
Please help me with my washer
Hello browneyez070
Welcome,
You said, your Hotpoint top loader washing machine won't spin water out. Model VBXR1O6OVOWW?
Common causes before considering repairs.
Water won’t drain
Drain hose is kinked or
Improperly connected on it.
Solutions
• Top of drain outlet should be less than 8 ft. above floor.
• Straighten drain hose and make sure washer is not sitting
Let me know if these measures help.
Huuum
Oct 15, 2008 | Hotpoint VBXR1090B Top Load Washer
WFR 2460 Front loader
We went through the whole "clean the soap dispenser" deal and results were the same. Exploratory surgery revealed that the Prewash hose (for lack of better term), which connects from the top of the drum housing to the right side of the dispenser drawer (facing the machine)was completely clogged with gunk. Especially strange since we don't prewash hardly anything, ever. The hose that connects the bottom of the detergent dispenser with the side of the drum housing did have a lot of buildup, but I do not believe it was the cause because this was only happening on the rinse cycle. I also found the flow meter was frozen up.
Jun 27, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Kenmore 43142 Front Load Washer Logo
170 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Paula Hamilton
