Question about Dell OptiPlex GX270 PC Desktop
Dell optiplex gx520 front panel connector
How to hook up switch/led/reset
  • Dell Master
  • 27,725 Answers
SOURCE: connecting front panel leads of generic case to 4600 motherboard
-MrSlickShoes
Posted on Mar 20, 2009
  • 166 Answers
SOURCE: when I switch on the computer there is nothing on the screen
Do you hear anything during startup, beeps, fans or drives spinning, lights on the front or back of computer flashing or lit up? Do you hear the Windows starting sound?
Let us know more then we can troubleshoot better. It is starting to sound like 1 of 3 things, Power supply, Video card or motherboard.
Situation #1: If you get a blank screen and no sounds or movement it either indicates that the power supply unit (PSU) has failed or something on the motherboard has failed, preventing normal startup.
Situation #2: If you get sounds and lights but nothing on the screen then it indicates a failed or loose video card.
Always try a different power outlet that you know is working. (Eliminate the easy stuff first!)
If it is out of warranty, Try opening up the case, with the power off, of course. If you have Sit #2 and have a video card that you can reseat try that.
Also take the time to inspect the capacitors on the motherboard (they look like tiny soda cans) and check for tops that are bulging, swelling or leaking anything. Capacitors should be perfectly flat on top. If you find these then your motherboard is bad (well technically the capacitors on your motherboard are bad). The caps will need replacing to fix (not a job for an amatuer). If it passes the visual inspection then it may just be your power supply is bad. Notice that a bad PSU does not mean you are getting no power, just not enough to start and run the computer.
Posted on Mar 25, 2009
benwabnick
  • 2404 Answers
SOURCE: dell optiplex gx520 keyboard
If your dell machine is recognizing the keyboard properly and installing its own built in drivers properly then the USB ports are working and it a problem with your keyboard
Posted on Jun 17, 2009
  • 76 Answers
SOURCE: SWAP DELL DIMENSION 4550 MOTHERBRD IN AFTER MARKET CHASSIS
If you look closely at the motherboard the pinouts are there. I have always had to play with the reset and power pins and by this I mean that if they don't work right then turn them around. I have also had to put the cable marked reset on the pins marked power. The others are marked (hdd led). I have found this to be true with all dell machines.
Posted on Aug 25, 2009
dwane4444
  • 219 Answers
SOURCE: Dell Optiplex GX520 PC won't boot - power light at
OK the first step is to remove the side of the case and check that all the leads are firmly inplace. - If this does not fix it post a comment.
Posted on Nov 02, 2009
Dell Optiplex gX520 will not boot beyond the splash screen. Dell Optiplex gX520 will not boot beyond the splash screen. There are not post code beeps.The lights on the front panel are 1 and 4. Both are...
Sounds like you may have multiple problems. Suggest trying to eliminate possible causes by removing components. Remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged. Remove the components one at a time and see if the LED's change.
Dec 10, 2011 | Dell Optiplex GX520 Desktop PC - Intel...
DELL GX 520 Motherboard power led is orange, power button led is orange, the fun is running, no beep, no display....somebody help me with this dell gx520. sometimes it displays 3 and 4 lights on the front...
you should replace the motherboard or the power supply of your computer. to determine which one to replace is a simple test. disconnect all that is connected to the motherboard and if the problem is still there, then the problem is the motherboard.
May 06, 2011 | Dell OptiPlex GX520 PC Desktop
I have a dell optiplex GX520 the computer comes on and shuts off in about ten seconds. Changed the power supply and checked all connections. Any Idea?
Try to make reset in your dell mother board.once you reset your problem will be solved,but afterworlds you need to run it in normal mode.
Sep 21, 2010 | Dell OptiPlex GX520 PC Desktop
Hi guys, just been given a dell optiplex gx520 to tinker with. when i plug it in, the power switch on the front flashes orange and the unit doesn't switch on. any ideas??
Did you open the case up and do a general inspection. Things to look for:
Is the CPU installed correctly and tight?
Is the RAM installed correctly? Are they the right type?
Is there another PCI cards? If so, make sure they are inserted tightly.
Are the power cables for the mother board attached correctly.
Look at all the unused power connectors for drives. Make sure the metal part are not touching anything conductive.
Good luck.
Sep 03, 2009 | Dell Optiplex GX520 Desktop PC - Intel...
My motherboard out of a dell optiplex gx260 the board it self is part number ASSY-3M537, I want to put it in a atx case I am worried it won't work. on the board I don't see how to hook up the power switch...
This should be the front panel header configuration of that particular motherboard.
6-8 (red) is your power sw
2-4 (green) is your power LED
1-3 (yellow) is your HDD LED
5-7 (purple) is your reset sw
black is not connected
The motherboard should go into a custom case no problem.
Regards.
Jul 28, 2009 | Dell (E210882) Motherboard
System not start
Check if the power card is working and your CPU is in correct state..you can call the service people for the help
Jul 07, 2009 | Dell OptiPlex GX520 PC Desktop
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
Dell OptiPlex GX270 PC Desktop Logo
372 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
