Question about Water Heaters
My 50 gal lp water heater made a slight boom sound and now when i lite it and turn on the main bunner it snuffs its self out
  • Water Heaters Master
  • 5,089 Answers
1) Call manufacturer with model number and serial number appearing on label on side of water heater.
http://waterheatertimer.org/Water-heater-manufacturers.html
2) Copy following link to troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-replace-thermocouple.html
3) Product manuals today recommend yearly service, and yearly cleaning of combustion parts, and to keep air intake clean.
If air intake becomes clogged, or combustion parts get dirty, it can slow the exit of combustion gasses, and this will soot the burner, and clog burner ports, which means slow lazy yellow flame and incomplete burning of released gas. So unburned gas is present in combustion chamber and up the flueway. The ignition of unburned gas can cause explosion of various intensity ... and the 'boom' sound you heard.
The explosion certainly overheated combustion chamber and tripped FVIR system.
4) Since each manufacturer has different FV system (flammable vapor ignition retardation system), and each manufacturer has continued to make changes over time in FV systems, the solution for tripped FV will vary by brand and age and model of water heater.
For example the intellivent gas control can be reset in some models, while other models require replacement of parts ranging from gas control valve to FV sensor to glass vial, and include possibly full replacement of water heater.
Posted on Jan 20, 2013
  • 21 Answers
SOURCE: Rheem 50 Gal Hot Water Heater will not stay lit
On the back of the gas valve (where you turn the temp up) there is a stem that actually goes into the tank that senses the temprature of the water it could be dirty or buried in sediment depending on how old the tank is, or just bad. if the tank is over 10 years old i wouldn't bother replacing the gas valve, the tank is probably not far behind. A new valve will run around $100.00 maybe a little less. You wont find it at menards or home depot in stock but they may be able to order it for you. Menards sells rheem products or try you local plumbing supply house. REMEMBER TO RELIEVE THE PRESSURE ON THE TANK BEFORE YOU WORK ON IT. IF YOU CHANGE THE VALVE DRAIN IT FIRST!
Posted on Feb 10, 2009
gary1121
  • 332 Answers
SOURCE: Bradford White LP water Heater Power vent
does the fan come on, if not there is a problem with the circuit board, if it does then there is a problem with the gas valve or a wire from the gas valve to the fan , if the fan doesn't come on the gas valve is told not to open to light thru the circuit board,
Posted on May 30, 2009
gary1121
  • 332 Answers
SOURCE: the water heater will cycle 5-6-7 times with no
there is a screen around the bottom of the unit? if so take it off and clean it,, does this unit have a self ignitor, or is it piliot? make sure your flue is clear so the unit is not over heating,, make sure on the power vent that the filter is clear also,, does the fan come on before the gas ignites, if not the circuit board is going bad the fan should start first to omit the gas fumes
Posted on Jun 06, 2009
  • 297 Answers
SOURCE: I have a 6 gal Atwood hot water heater. I can
Kenny did you change the thermo coupler?
Posted on Jul 14, 2009
  • 454 Answers
SOURCE: I have a Rheem 50 gal. natural gas water heater
The most common reason a pilot light will not stay lit is a bad thermocouple. How old is the water heater? If the pilot light will light, but then go out when you release the safety button, that is a sure sign the thermocouple is bad. You can buy a replacement thermocouple at your local home improvement store. There is a small chance that the control valve has gone bad, but that is highly unlikely.
Posted on Feb 23, 2010
Water leak from top of hot water tank ?
Fix overflow system coz it is not working properly.
Jan 27, 2015 | Rheem Richmond 50 Gal LP Gas 6 Year Tall...
Why does bunner light then runs for a minute shuts off then shuts off
if you haven't already ,check thermostat, check inline fuse, check ground wire.
Jun 20, 2014 | RTO Atwood Water Heater - 6 Gal LP
Atwood Hot Water heater wont' shut off
sounds like defective thermostat/gas valve
Aug 05, 2012 | RTO Atwood Water Heater - 6 Gal LP
Rheem water heater Lp won't turn on
Hello,I suspect the LP regulator/ diaphram at the supply tank is defective.Sounds like fuel supply problem/pressure.You did everything right that all that is left!
Apr 23, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Piolet lite will not stay lite. Takes awhile to lite after it dose lite it kicks off again
Sounds like a bat thermocouple to me. Replace it they are not very expensive.
Good Luck,
Gil
Mar 01, 2010 | Reliance & 30 Gal LP Gas Water Heater
Electronic ignition tries to lite, clicks 5 times, then goes POOF
Gas burners go "poof" when they have too much gas in the area upon lighting. This is normally due to the ignition source not being close enough to the initial source of gas. This is normaally corrected by ensure the main burner is clean so that it distributes the gas correctly and having the ignition source at proper strength and location. I would have to have good schematics of your heater to be more specific. I hope this helps.
Sep 09, 2009 | RTO Atwood Water Heater - 6 Gal LP
Need the removal procedure for the G6A-8E RV water heater.
SHUT OFF ALL ENERGY SOURCES TO HEATER. REMOVE ELECTICAL SUPPLY LINES AND TAPE THEM OFF. DRAIN WATER FROM HEATER. REMOVE AND CAP WATER LINES. TURN OFF LP. REMOVE AND PLUG LP LINE. REMOVE SCREWS FROM OUTSIDE CIRCUMFERENCE OF HEATER. PULL HEATER OUT.
Aug 27, 2009 | RTO Atwood Water Heater - 6 Gal LP
Describe your Reliance & 30 Gal LP
TURN OFF THE GAS VALVE AND WATER TO THE TANK REMOVE THE PIPES FOR THE DRAFT USE A SHOP VAC AND CLEAN THE DIRT AND DUST FROM THE INSIDE OF THE DUCT WORK ALSO WHERE THE BURNER IS LOCATED YOU CAN VACUME THERE ALSO AND REINSTALL THE DUCT TO THE FLUE
Aug 23, 2009 | Reliance & 30 Gal LP Gas Water Heater
Water heater turns on and then after a few minutes shuts down
Are you sure there's water in it? May be on by-pass. Try opening pressure relief valve at top of tank slightly,and see if water comes out. If not, check your by-pass at back of tank for wrong position. Cold has to go in the bottom, and hot out the top. No valve open, or flow between them.
Jun 25, 2009 | RTO Atwood Water Heater - 6 Gal LP
Water Heaters Logo
114 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
