Question about Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba 40" 1080p plays dvds with a red tint and no sound??
Plays dvds but they are tinted red and have no sound???
When connecting the dvd player using component cables and audio cables, go to the progressive scan setting on the dvd player and select it. Once I activated the progressive scan, the problem was solved.
Posted on Jan 26, 2009
My MacBook has a red tint whenever I play movies and videos
Try resetting your PRAM-reboot holding command/option/P/R until you hear the chimb a couple times.
May 24, 2012 | Apple MacBook Pro Notebook
Dvd player only plays in b&w, and connectors dont seem to match up with tv
Go into the player's setup menu and make sure it's set for the kind of connection you're actually using (component, S-video, composite). Also make sure the connections are pushed "all-the-way-in" Lose connections can cause B&W picture.
Sep 09, 2007 | Televison & Video
Toshiba 50HDX82: Extreme yellow tint
On/off switch is a normally-open,momentary hold binary switcvh- is burned out or dust/contaminants in the switch. First try spray-air keyboard cleaner on and around the switch. Otherwise, replace )professional svc.)
Nov 09, 2009 | Toshiba 50H82 50" Rear Projection...
Red tint while using component cables
Disconnect component cable while observing screen, just to make sure that is your problem. If it is and you already substituted the dvd player and it still happens,, try replacing the cable, it may be defective. If it still happens there may be some kind of a processing defect with the component input of your tv, why not just return to RCA's
Aug 07, 2009 | Toshiba 27AF45 27" TV
55'' rear projection Phillips (dptv335) Red Tint in 4:3 area
Sounds like your fluid in the CRT's need replaced. I would recommend a servicer take care of that problem. The corrosion that ethylene glycol can do to components is vast if you spill it on any of the PC boards. ( You know it as Anti-freeze ). Play it safe---Make a Call.!
Jul 24, 2009 | Pioneer Televison & Video
GREEN TINT TO ALL DVD'S PLAYED
Your red component cable needs replaced or your red component input in either your DVD player or TV needs replaced.
Jun 13, 2009 | Panasonic SC-HT730 System
Magenta Color
Here is something that may help from the toshiba.com website under your model number television. Q. Why are people on my screen green?
Models: 32HL17, 37HL17, 42HL17, 42HL167, 47HL167, 52HL167, 42HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00107
If the problem is not the connections, try adjusting the tint on your television. A high tint setting will usually create a green
image on the screen where as a low tint will create a more red hue. In order to access your television's tint:
1. Press the “MENU” button on your remote control and use the LEFT or RIGHT arrow keys and select the
VIDEO menu.
2. Then use the UP and DOWN arrow keys to highlight PICTURE SETTINGS and press the "ENTER" button on
your remote.
3. Next use the UP and DOWN arrow keys to highlight TINT then use the LEFT or RIGHT arrow keys to adjust the
TINT. If the picture is too green the tint will need to be lowered.
4. Once you have adjusted the tint to your liking, use the DOWN arrow key to highlight DONE and press ENTER. The toshiba customer service telephone number is : 1-800-631-3811. I hope this helps you with your problem.
Feb 01, 2009 | Toshiba 42HL167 42 in. LCD Television
I just got a Toshiba 40" 1080p tv. Everything looks good except dvds are red tinted with no sound??? It is a standard dvd player (no hi-def) with component cables
Double check that your componet cables are in the correct colors on both the dvd and tv. Also what are you using to transmit the sound from the dvd player to the tv. Component cables are video only and not sound.
Jan 26, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Red color abunDANT
Please verify model # from rear of set.PVAT! Look closely at signal PCB for signs of CRT coolant leak.
Oct 03, 2007 | Toshiba 42H82 42" Rear Projection...
Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
121 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
