Question about Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I just got a Toshiba 40" 1080p tv. Everything looks good except dvds are red tinted with no sound??? It is a standard dvd player (no hi-def) with component cables
  • 3 Answers
Double check that your componet cables are in the correct colors on both the dvd and tv. Also what are you using to transmit the sound from the dvd player to the tv. Component cables are video only and not sound.
Posted on Mar 23, 2009
Red tint while using component cables
Disconnect component cable while observing screen, just to make sure that is your problem. If it is and you already substituted the dvd player and it still happens,, try replacing the cable, it may be defective. If it still happens there may be some kind of a processing defect with the component input of your tv, why not just return to RCA's
Aug 07, 2009 | Toshiba 27AF45 27" TV
Picture and menus are red-tinted all over
check system mode on dvd player,should be on pal
Jul 12, 2009 | Televison & Video
No colour when watching dvds ok for everything elese
You will have to make sure you are connecting them with the red and white cables on audio and the yellow on video at both ends, as both your dvd and tv have low def and hi def cabling options.
That means Red and White to Audio at each end and Yellow to video at both ends. If you connect the yellow cable to one of the other three connectors at iether end you will only get black and white as they are meant for a different type of connection.
To get the maximum quality out of your sets you may want to purchase a set of Hi-Definition Component cables which will give you a set of five cables, still red and white for audio but now red, green, blue for video.
Hope this heps a bit more,
Chris
Apr 30, 2009 | Panasonic DMR-ES35VS
Toshiba 40" 1080p plays dvds with a red tint and no sound??
When connecting the dvd player using component cables and audio cables, go to the progressive scan setting on the dvd player and select it. Once I activated the progressive scan, the problem was solved.
Jan 26, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I recorded my movies on the dw 100 but now i can't grt them to play on my dvd player
The DW-100 records discs based on the format they were originally recorded.
If your camera is recording HiDef videos than the discs this unit creates will be viewable on a Blu-ray disc player.
If your camera is recording in Standard Definition (ie. NOT HD) then I believe that the discs will work in regular or upconverting DVD players.
My Canon camcorder does not record in Standard Def so can't quite vouch for that last comment though.
Jan 06, 2009 | Canon DW 100 DVD-RW Burner
I purchased a new Zenith Tv and have hooked up my dvd player which is about four years old (Toshiba). The connections are all right but when I put in any disk (I have tried many) it registers no disk so...
try to use player on old tv again does it still work 4 yrs old dvd player is to old for new days dvs on new tv u def wann upgrade to 108p upscaling player samsung makes with hdmi cable to new tv flat screen or reg coneection will look 10 times better also older toshibia cant play read new dvds its terrible
Oct 07, 2008 | Televison & Video
Dvd player only plays in b&w, and connectors dont seem to match up with tv
Go into the player's setup menu and make sure it's set for the kind of connection you're actually using (component, S-video, composite). Also make sure the connections are pushed "all-the-way-in" Lose connections can cause B&W picture.
Sep 09, 2007 | Televison & Video
No sound on my toshiba television
just be basic....dvd is ouput goto tv input...watch the color yellow to yellow ,red to red etc, got tv ,look for audio output to anything input to home theatter etc.if u hook in to aux set home theater to aux etc, input to output and output to input ok? hope i help u..
May 08, 2007 | Toshiba CN32G90 TV
Can't Receive Ch 23-48
It looks to me that u still have some dry joints, look carefully with a magnifier glass and resolder those bad joints
Dec 26, 2006 | Toshiba 36A60 36" TV
Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
141 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
