Question about Sierra Entertainment Emperor: Rise of the Middle Kingdom for Windows
How do I run Emperor Rise of The Middle Kingdom under Windows 7 in Parallels on Mac with Mountain Lion OSX 10.8.2?
When Install window appears, there's a message that says iKernel.exe cannot be found...
3 Suggested Answers
SOURCE: Does Emperor RotMK work with Windows 7?
I have Windows 7 32bit and was able to successfully install Emperor ROTMK. I used to get that error with an old disk I had. it was because my disk was damaged.
Posted on Mar 13, 2010
Suzman
  • 642 Answers
SOURCE: I've had "Emperor: Rise of
A CRC error points to the cd that you are installing the game from. While the installation program copies the file to your computer it runs a check to see if the file is being copied correctly with a mathematical calculation. If the calculation does not match a checksum stored in the file then a CRC error is given. This in short means that the portion of the cd where the data2 cabinet file is stored is damaged.
Try cleaning it or try with another drive on the same computer. Another drive may be just a little bit better aligned and able to read the damaged portion better. Alternatively try getting another copy of the game and install from there. (Please use original discs only.)
Posted on Sep 14, 2010
How to update a MAC Power PC to 10.5+
I don't think you can do what you are trying. You will need to find games that work on the Power PC format. Intel machines can go backwards, but Power PC's cannot emulate an Intel machine. At least I have never found a solution for that. I don't think the only issue is the Flash Player. It is likely the application as well.
Jan 24, 2014 | Computers & Internet
Tip
Problem: My Mac Does Not Work With VantagePoint Possible Solution: If your Mac...
<span style="font-weight: bold;">Problem: My Mac Does Not Work With VantagePoint</span><br /><br /><span style="text-decoration: underline;">Possible Solution:</span> If your Mac does not work with Vantage Point, please try this technique.<br /><br />Please try to use "Parallels". Parallels will allows you to use your Mac home as the Windows home. <br /><br />In your configurations for the Virtual Machine in Parallels make sure that the default is set to use your Mac home for the Windows home folders.<br /><br />You need to uncheck the shared profile so that Windows has its own home directory. You can now run 10.6.2, Parallels 5 and Windows.<br /><br />This solution also works for Mac OSX 10.4.11 - Parallels 4 - VP 1.60<br /><br />JG
on Dec 08, 2010 | GPS
Is it possible to get drivers for Mac OSX 10.8 Mountain Lion?
No this device doesn't even support windows vista or windows 7. Replace the device with a new one to have support on newer devices.
Sep 10, 2013 | Philips ToUcam XS Camera Composite A/V...
Lide 60 not working in mountain lion
Guide to installing Canon CanoScan LiDE 35, 50 and 60 on Mac OS X 10.8. Mountain Lion:
FIRST PART: DELETING OLD LiDE DRIVERS AND SOFTWARE
  • If this is the first attempt to install the scanner, skip this part
  • Trash the following files/folders from these folders:
HD:/Library/Image Capture/Twain Data Sources
delete the CanoScan CanoScan XXXX.ds file
(Make note of any other files that may be in this folder. If other files are present, move them to the desktop for now. Then place them back after successfully using the scanner.)
HD:/Library/Preferences
delete the 'CanoScan XXXX' folder
HD:/Users/Shared
delete the folders containing the name CanoScan, or starting with CNQL.
HD:/Applications
delete the CanoScan Toolbox Application
HD:/Users/YOUR-MAC-USERNAME/Library/Preferences
delete any items named "CanoScan Toolbox"
  • Restart your computer, then empty the trash
SECOND PART: MAKING YOUR SCANNER WORK
  • Make sure your scanner is well connected
  • Download the right driver depending on your Model. Also download the Scanner Software. Copy the filenames and search them via Google. Make sure you download the Canon files from an official Canon domain.
CanoScan LiDE 50 and LiDE 35 work both with the 35 driver:
lide35osx7721en.dmg
CanoScan LiDE 60 driver:
lide60osx11131en.dmg
VueScan Software:
http://www.hamrick.com/#download
VueScan 9.2 (or later) x32 for Mac OS X
Alternative to VueScan: CanoScan Toolbox. I prefer VueScan.
Try your luck with Version 4 or Version 5.
CanoScan Toolbox 4: cstbosx4934ej4.dmg
CanoScan Toolbox 5: cstbosx5014ej4.dmg
  • Open the downloaded driver file (lide35osx7721en.dmg or lide60osx11131en.dmg)
  • and Double-click the ScanGear file, install and restart when prompted
  • Open the downloaded VueScan file (vuex3292.dmg) and drag the VueScan application to the Mac Applications folder
  • Open the VueScan application. The scanner should be recognized automatically.
(Alternatively try and install CanoScan Toolbox 4 or 5)
Nov 04, 2012 | Canon Office Equipment & Supplies
How can I run windows as well as mac os on my notebook
You can check out Parallels or VMWare Fusion which will allow you to run Windows & OSX side-by-side.
http://www.parallels.com/
http://www.vmware.com/products/fusion/overview.html
Hope that helps!
Sep 09, 2012 | Apple MacBook Pro Notebook
Why Nikon CoolScan V ED Film Scanner does't work with mac OSX lion?
According to the Nikon site the software for the Coolscan is not compatible for Mac OS Lion, you need to purchase silverfast to get it to work see http://www.scandig.com/filmscanner/nikon/nikon-coolscan-v-ed.html silverfast can be bought from http://www.silverfast.com/ you can download a demo from here to see if it works.
Dec 17, 2011 | Nikon CoolScan V ED Film Scanner
I want to play emperor in 1280 by 800 but when I play the screen doesn't stretch its black margin. My brother's laptop can stretch the resolution to 1280 by 800 but mine can't. How can I fix this? Please...
Go to your start menu and open it.Click on control panel.Click on appearance and personalization.Click on display.Click on change display settings.It will let you choose from there.Click on apply or OK,whichever one is there,click on apply first if both are there.
Close window. Good luck and game on!Also if your computer is older,it may not give a big enough display option.
Jul 24, 2010 | Sierra Entertainment Emperor: Rise of the...
USB to serial converter will not link to Macbook
the mac is still a mac but running windows, is sewing machine pc/mac compatible? if it is then boot under osx if u cant its not osx compatible only pc
Apr 24, 2010 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Feb 02, 2010 | Sierra Entertainment Emperor: Rise of the...
Sierra Entertainment Emperor: Rise of the Middle Kingdom for Windows Logo
126 people viewed this question
Top Sierra Entertainment Video Game Consoles & Games Experts
James Wishart
Are you a Sierra Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
