I have a problem in sorting
Please send me codes for sorting alphabets in ascending and descending order
If your using windows:
Open cmd.exe (program files>accessories>command prompt)
use the sort command in this syntax:
sort "path name and or file name"
you may also use file exports like this for example:
sort birthdays.txt > sorted birthdays.txt (single forward will write over old files and make new ones)
sort birthdays.txt >> sorted birthdays.txt (use double forwards to made amendments to the file)
the "/R" function will reverse the sort order, for example:
sort /R birthdays.txt
thats all, hope this helps. I cant do much else with the information given.
Posted on Jan 28, 2009
How to calculate median
Sort the data into ascending or descending order. If there's an odd number of data points then the median is the one in the middle. If there's an even number of data points then the median is the average of the two in the middle. Add the two together then divide by 2.
Mar 05, 2013 | HP 12c Calculator
When I save a word document file to "Documents" they are no longer being saved in alphabetic order? Whats gone wrong and how do I fix it?
When you open that folder ( or any other), you have the option to sort by file name, file type, date, etc... Click on name at the top, and it will switch to sorting that way. Click it again to change from ascending to descending and vice versa.
Nov 12, 2012 | Acer Aspireā„¢ T180 PC Desktop
I'm following all of the steps to sorting a list - but when I go back to look at it, it did not sort. Please help!
Enter the data in any order in your list. Press [2nd][Quit] to exit the data editor.
In Main screen, press STAT, select SortA( for ascending or SortD( for descending order.
The command echoes on main screen as SortA(. Press [2nd][1] for L1 or 2nd 2 for L2. Close parenthesis and press ENTER. The L1 list or the L2 list will be sorted.
If the list are linked you must sort them together. In that case the syntax is SortA( L1,L2) ENTER.The list will be sorted according to the order in L1.
Sep 10, 2011 | Texas Instruments TI-83 Plus Calculator
How to sort the number data in order in L1 for ex L1 -> L1 3 2 2 3 7 4 4 5 5 7 like that thanks
There are two functions available for sorting lists. Access them via [2nd] [List] "OPS".
SortA(list) sorts the list into ascending order.
SortD(list) sorts the list into descending order.
Jan 21, 2010 | Texas Instruments TI-84 Plus Calculator
Doesn't remember there's a Header Row
You can try to select all data (except for the entire row which contain your header) and try to sort thru columns. This can sorted in ascending or descending order.
Jul 17, 2009 | Microsoft EXCEL 2004 for Mac
Autofilter ceases to work on large Excel 2003 spreadsheet
Sounds like there is a gap between the filter heading and the column data. That's the only time I've seen suggested data missing from the drop-down.
Jun 16, 2009 | Microsoft Computers & Internet
What are the source codes for making records in C++?
i need drivers for Sonny VGN-NS150D : WIN XP PROFFENAL SP2
Jan 08, 2009 | Computers & Internet
Name sorting using c++
Since you haven't replied for a week, I assume you didn't want my help and so I expect that you don't rate this solution. If you still want help, I will provide it, but I won't write what could potentially be a homework assignment. I can give you guidance if you get stuck. good luck
Nov 11, 2008 | Video Game Consoles & Games
Sort incoming time for received e-mails
Depending on what client you are using, clicking on the "triangle" in the date column toggles between sorting ascending and descending.
MM85
Jul 22, 2008 | Microsoft Office Outlook 2003 for PC
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
