Question about Arris Touchstone 450a (CM450) Modem
ARRIS Modem + D-Link router = no internet
I have cable modem with an Arris modem and we tried to use our D-Link 2310 router but it doesn't work we can't get the net (I ain't using the wireless and don't care about it btw). I've changed the router twice and switched the modem once and it didn't change anything.
Plugged directly into my computer the modem provide internet just fine and my modem has been tested at a friend's place (who's with the same ISP) and it work perfectly.
I call D-Link they say that the problem is my modem, Videotron (my ISP) says that the problem is my router. They all evade their responsibilities and I really don't know what to do anymore. I've tried everything thing I found on the net but it doesn't help.
  • 3 more comments
  • sebastienchi Jan 26, 2009
    already tried that but it doesn't help
  • Jake Cornjo
    Jake Cornjo Feb 19, 2009
    I have got a dlink dir-320 router and a telstra 2 wire modem
    It used to be fine with everything working but my bro pressed the resetbutton on it i cant connect to the internet even on the computerthe ethernet cable is connected to... and my wii and ds cant connect toit either
  • Jake Cornjo
  • ansegne Mar 09, 2009
    I couldn't get an Arris tm502g modem to work with a DI-524 router. I followed the advice from 'ohms' (clone MAC address and re-boot router), worked perfectly. (Hint: on the DI-524, the button for cloning the MAC address is on the "Home" tab, then hit "WAN" among the left-hand buttons. You might then have to scroll down a little to see the MAC info.)
    Prior to that, I was working solely through the DI-524 wizard and getting nowhere -- process kept coughing up errors (internal error, 'not connected to a di-524 router', can't get to internet) and I couldn't figure out if I had a bum router, bad modem, wrong info from the ISP, etc.
    So if you're experiencing this: skip the wizard, go straight to the GUI and try ohms' trick. Even if your router already has a MAC address assigned, give it another go.
    Also: Updating your firmware might be a good idea. Go to your router's manufacturer site.
  • Anonymous Mar 19, 2014
    Have bought this modem and have now read that I will need a firmware upgrade. I use the modem in with a D-link dir-601 router. I am told that arris provides firmware upgrades to ISP's only. what can I do if anything to get this resolved.
  • 1,879 Answers
When you are on Cable Internet with a "modem" only connected directly to the computer, what the ISP see is the computer's MAC Address (command prompt -> type ipconfig and hit enter).
put a router (which has it's own MAC Address) in-between and the ISP wont let you cause it sees the router not the computer.
check physical connection: cable modem -> router -> computer(hard wire for this troubleshooting)
access the d-link gui and locate the “Clone MAC Address" button (supposed to clone the computers MAC Address - verify if it's the same), save settings & reboot the router.
Posted on Jan 26, 2009
Ohms method (Clone MAC Address) works well for me. Thanks
Posted on Apr 18, 2009
Is my 802.11g router Model #cm550A c Router wireless
Posted on Sep 11, 2011
After cable co. split cable and installed another modem, D-Link WBR 2310 router no longer works with its original modem. Tried resetting, unplugging, etc. Can't get wireless.
Use an Ethernet cable to connect your computer to one of the LAN ports.
Click Start
Click Run
Type CMD
Press Enter
Press Enter
Look for a line of output like:
Default Gateway . . . . . . . . . : 123.468.32.1
Start Internet Explorer
Type http://123.468.32.1
Press Enter
Login to your router
Click to run the "Wireless Networking Setup Wizard", to:
1. set an SSID
2. set an encryption-level, e.g., 'WPA' or 'WPA2'
3. set a password for your network
Click OK to restart your computer
Use your wireless device to connect to that SSID, using that password that you set.]
Jun 06, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
Comcast installed Arris TM602G/CT Modem yesterday. Attempted to link modem to MAC AIRPORT wireless router. Have net access with my PC cabled to modem. If I hook the modem to the AIRPORT, the PC indicates...
first its a mac so no wonder its broken second its not your modem it would be your router settings. you may want to restore your device back to its defualts then try again.
Apr 13, 2011 | Computers & Internet
We have an Arris wireless modem. We have lost the adapter that goes with it. My husband purchased a Belkin Wireless adapter, but it would not work. We went back to the same store and they do not carry...
If you meant you lost the power cable, then you should contact Arris to buy it.
If you mean you lost your router that was hooked with the Arris modem, the you can buy any router for house like D-Link, Linksys... and get it configured to work properly with the Arriss modem where you buying at.
Feb 28, 2011 | Computers & Internet
D-Link router does not connect to my laptop
remove the cat5 cable end that goes from your internet connected computer to your router; remove the end of this cable from your router ; remove your modem to router cable end from your modem put the internet computer cable into where the router cable was in the modem; unplug then: plug in your modem; wait for the modem to reboot; verify that the internet computer is online then swap the cables back where they were
you should now be able to connect your laptop wirelessly to the internet.
Jul 15, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Cannot access the 'net through the wireless router.
u need to configure your router. insert your broadband cable into wan port and then can connect ur 2 laptops through lan
Oct 22, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
We have just signed up for cable TV/high speed internet/cable telephone. The modem provided is an "Arris" version 1.5. The cable tech said I could connect my Belkin G router so that more than one computer...
Plug the ethernet net cord into the arris ethernet port. plug the other end into the router where it says "internet"
Plug a ethernet cable from one of the router ports to the computer.
First start up the arris modem, then power up the router, then start the computer.
Oct 22, 2009 | Belkin 802.11g Wireless Desktop Network...
How to secure my d-link wireless adapter with my Arris 550a modem
To make your wireless router secure you need to use your browser and type in the router's IP configuration address.
Then you need to change the default Admin password,
change SSID and turn off SSID broadcast,
setup the encryption (use WAP or WAP2 if your wireless card supports WAP) if not use WEP 128 bit encryption
and for added protection use MAC address filtering.
Apr 15, 2009 | Arris Touchstone 450a (CM450) Modem
Link light blinking
On these cable modems the link light is supposed to blink when you are connected to a router/pc. If you are hooking up a wireless router new you need to power cycle/reset your cable modem before you hook up the wireless router so that way it can refresh its ip address.
Mar 21, 2009 | Arris Touchstone 450a (CM450) Modem
Can't seem to hook up D-link router to my Arris cable properly
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
May 29, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Connecting dlink WBR-2310
hi greci6,
Does your laptop have wireless access?
You may have to buy a wireless chip for your laptop, Give me a little more information on your error you get.
Also tell me how your router is setup, and cord placement.
Dec 31, 2007 | D-Link RangeBooster G WBR-2310 Wireless...
Arris Touchstone 450a (CM450) Modem Logo
5,734 people viewed this question
Top Arris Computers & Internet Experts
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
