Question about Airlink AWLH3026T 802.11g/b Wireless Adapter
Wireless not picking up
I have been using the Airlink PCI adapter AWLH3026T 802.11 for some time now, and only recently, one day when I turned on my computer the wireless icon, and the Airlink monitor icon did not appear as usual in the tool bar. I checkin the the network connections and there was also no wireless connection available. I reinstalled the software and still nothing. I am almost positive that the problem lies somewhere in the card. Any help is greatly appreciated.
  • 611 Answers
At first your card its detected or not if not then replace it if yes then go to the right click to my computer there option is there manage in that device management is there in that your card has yellow mark in the other option just double click on it then re-installed the driver option is there put the card and the cd in the computer then you get it
Posted on Apr 02, 2009
Linux driver / cheapset / firmware
Which version and kernel of Linux are you running? That does make a difference. Post back with more info, please.
Sep 17, 2013 | Airlink 101 AWLL5088 Wireless N 150 Ultra...
Mywifi signal won't come on and my adpater will not pick up my signal
which wireless adapter you are using ? what is your desktop or laptop model ?
Apr 10, 2013 | Computers & Internet
Awlh3026 on dell dimension 8300
here's a link at end of this message u can use to read or obtain the 3026 card's manual. or just go to manufacture's site ,,airlink.com, click tab to go to support page and do a search for ur model , then find and download the zip file for the OEM drivers and setup/config utility, extract the compressed file to ur hard drive, be sure u pay attention as to where it is going to be extracted to, then turn ur PC off, power down all the way ,, insert card into the board slot, secure it properly,, restart PC, and when new hardware install screen pops up for the auto detection asking u if u want to install drivers, be sure to click cancel, do not continue with install at this time,,, the window will close,,,then go to folder where u extracted the software files, click setup icon, when it finishes,it will close and restart PC, when it reboots, u should see the Windows lan network connection icon on lower right of screen.. left click it , go to config tab, and remove the default check from box on upper left corner of that window to disable windows from doing any of the card install or config of the wireless connection, Very important**,,, note,,, absolutly no way,, that, both of the utility programs can be enabled or run at same time,, will not work with 2 bosses,, meaning both the airlink setup/config utility and the default windows networking program.,,, this link to read smaller 4 page manual it will explain in detail,,, or u can also locate and download the original larger 20+ page instruction manual at the airlink site as well,,, I just installed same card into a Dell Dimension 8200 last night,,,, had a hell of a time myself,, totally failed at figuring it out per the usual/norm standard installs,, that is,,until I finally did the research,, determined the error was made when initially installing the drivers at detection using the plug n play from windows instead of clicking "cancel" button , as required,,at time of detection of card...then doing the complete install, setup, . and config using only the downloaded OEM Airlink software. Be sure to download the awlh3026_util_drv_winme/xp zip file download that is clearly marked for XP operating systems, two are aailable for xp,, u will need both the drivers and the utility as well as the manual download,,, and only trust software downloads if obtained from the official manufacturer's site ,, heres one set of instruction manual u can go read right now without downloading it to help explain quickly
hope this helps
http://manualslib.com/manual/206893/Airlink-Awlh3026t.html
Sep 27, 2012 | Airlink AWLH4030 (658729080430) 802.11g/b...
Airlink adapter and att router access problems
Make sure you have the most up to date drivers for both your mini usb adapter and your router.
The 64 bit version of windows 7 may not have the right driver for your equipment.
Will get better with time.
Good luck.
Jul 04, 2010 | Airlink (AWLC3025) Wireless Adapter
I have a laptop running 802,11 g/b and vista and I Cant connect to linksys wag160n wireless router(802,11 n). laptop sometimes recognises network but when I try to connect it wont. could you help ?
Hi, You cannot connect across wireless protocols. In other words to connect to 802.11 n you need an "n" adapter.
Now, the router should be backward compatible & provide wireless g/b but you may find that when you search for networks it will be listed as a seperate network name (from the same router)
Try searching for this other network. Your router documentation should advise you of its default name & any set up process
Dec 23, 2009 | Acer Computers & Internet
I need a driver for Airlink AWLH4030 working with windows 7. The original driver starts error mesages about wlanapi.dll Thanks Rafi
had the same problem(awlh4030). The chipset on the adapter is mfg by Atheros.
If you use the Atheros ar5005gs wireless network adapter driver that comes with windows 7 it works with no problem.
Dec 20, 2009 | Airlink AWLH4030 (658729080430) 802.11g/b...
My Wireless connection status page is blank. Same with the wireless connection properties page and the "view available networks page"(or wireless network connection page) can't open, all it has is the top...
The AWL number was what I was looking for, thanx.
If the AirLink utility is running, there is where you would check the status. The way to set it so that the connection shows in the 'network connections '
Go into your Control Panel, then go into Network Connections
Right click on your AirLink wireless adapter and click “Properties”
Click on the “Wireless Networks” tab
Put a check in the box next to “Use Windows to configure my wireless network settings”
Click “OK”
If you wish to go back to using the AirLink101 802.11g Cardbus Utility, go back into the “Wireless Networks” tab in your AirLink adapter’s properties and remove the check mark next to “Use Windows to configure my wireless network settings”
Aug 03, 2009 | Computers & Internet
I need driver for pcmcia airlink awlc4030 wireless cardbus adapter
http://www.modem-help.co.uk/AirLink101/AWLC4030-Super-G-Wireless-Cardbus-Adapter.html
go to his site and download it
May 06, 2009 | Airlink AWLC4030 Super G 802.11g/b...
I can't get it to work.
To view the wireless network connection dialog box, follow these steps:
  1. Click Start, Run, and type ncpa.cpl, and then click Ok.
  2. Right-click the Wireless Network Connection icon, and then choose Properties. (Or you can right click the Wireless Network Connection icon and choose View Available Wireless Networks from the shortcut menu.)
  3. Click the Wireless Networks tab.
  4. Under Available networks, click the View Wireless Networks button.
From the wireless network dialog box, you can refresh the network list. This performs another scan of wireless networks within range. The wireless network connection dialog displays the following for each detected network. The following shows the new connection box.
When the wireless network adapter displays the detected networks, you'll able to select a wireless network name and attempt to connect to it. The antenna icon indicates an infrastructure mode wireless network. The icon that shows two wireless client computers indicates an ad hoc wireless connection.
The lock icon and the "Security-enabled wireless network" label indicate that the wireless network has security enabled. The gold lock means you need a network key in order for you to connect to a wireless network. If it's not security enabled, you'll be able to connect to the network without a network key.
Apr 28, 2009 | Airlink AWLH3026T 802.11g/b Wireless...
Dad just gave me a wireless DI624s router/modum. just wondering if i need a network card or something like that to plug to my pc usb port to pick up the signal, or should it pick up the signal its self.
to contect to your wireless you need to click on your wirless icon search for networks..the router your using should come up ...connect to that...it might ask to enter comfirmation key code..
Nov 13, 2008 | Computers & Internet
Airlink AWLH3026T 802.11g/b Wireless Adapter Logo
242 people viewed this question
Top Airlink Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you an Airlink Computer and Internet Expert? Answer questions, earn points and help others
