Question about Samsung HCN553W 55" Rear Projection Television
I tried to mess around with the...
I did try messing around with the color settings, the coverting settings, they all do affect the tv but does not seem to make the ziggy zaggy lines get worse or better. Is there anything else that I could do at home before I call in someone that charges me a lot of money just to look at the TV. One other thing is that it seems to have a lot of yellow color around the boarder of the tv. Please help!
  • Bryant lentsch Jul 20, 2007
    hey there.. I see that the part you are telling me to replace is a sanyo.. my tv is a samsung. Is that going to matter! Also where is the item located in the TV.
    President:
  • 3,130 Answers
You will need to replace or have replaced the two convergence amp IC's on the convergence board in this set. They are the STK-392-040 IC's and the original replacement numbers are available at MCM electronics. Go here to see.http://www.mcminone.com/search.asp?keyword=STK392-040&btnSubmit.x=16&btnSubmit.y=11&btnSubmit=GO Or you can call PTS corp, as they have rebuilt complete convergence boards or can rebuild yours for you at 1-800-844-7871 Good Luck
Posted on Jul 16, 2007
SOURCE:
I am having lines running through my TV and It got worse, now the colors are all messed up. When i shut it off for awhile and turn it back on, it seems ok, a few lines but color looks good. After about...
The problem you are experiencing based on the symptoms all point to the T-Con board. This board is located right above the panel, it controls the cells of pixels on the screen. What happens is once this goes bad you will normally tend to have lines on the screen as well as psychedelic colors. To replace the board does not take very technical skills but there is a lot of screws in between so I would recommend taking your unit to a certified repair center to have this board replaced.
Oct 05, 2010 | Polaroid FLM-323B Television
My screen to my RCA 56" HD TV is messed up. The picture seems to be bowed inward and the colors are all mixed up. I tried to do the convergence but it is not on the menu and I remember it being there...
t is the problem of convergence setting or convergence IC.
Comment by ready2helpu, posted on Oct 21, 2008 IF THE PROBLEM OF CONVERGENCE SETTINGS then check out this link
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
if the problem of convergence IC THEN check out this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
you can do it manually.
thanks.
Oct 21, 2008 | RCA R52WM24 52" HDTV Projection Television
Picture is messed up.
Ur tv have a convergence problems,it dead.U must have soldering tools,solders and know how solders to fix convergence problems.U must replaced 2 STK convergence ICS,and some or all it resitors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 07, 2010 | RCA HD52W58 52" TV
Hazy and messed up color
Ur tv convergence are dead.U must know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 22, 2010 | Hitachi 50UX57B 50" Rear Projection...
When moving the 51pw9363 will the color be affected by weather and movement, TV's color was good and then moved to the basement now the color is all messed up tried the convergence seem to have no effect
Usually temperature will not have a big affect but high humidity will. I would suspect the convergence amps have possibly developed loose solder joints from the move. They are mounted on heavy duty heat sinks that can move a lot and crack joints. Hard to say. Thanks for using fixya.
Dec 22, 2009 | Philips 51PW9363 51" Rear Projection...
RCA 27R410T Television colors are distorted
If you`re talking about colored spots in the screen, then you may have a degauss problem. It was frequent for those sets to have bad solder joint on the degaussing coil connector or thermistor next to it.If you`re handy with a soldering iron these connections would be near the a.c line input. good luck and don`t forget to unplug
Nov 01, 2009 | RCA 27R410T 27" TV
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Slanted picture
Your deflection yoke (a coil around the neck of the picture tube) must have gotten turned. Your can turn the picture upside down by rotating this coil. If your set is in warranty, you should return it. When this "yoke" is adjusted the color is affected too. If you try this yourself you'd void the warranty and mess up your color. Stargazer
Nov 05, 2006 | Philips Magnavox 20MT133S 20" TV
Red color
No easy fix for a TV. If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. As long as there's no burning smell, and the set is okay even when hot, after running for awhile, it's possibly bad connections on the convergence board. If you have some decent soldering skills and a familiarity with the insides of a TV, you may even save yourself a repair bill by getting some bad solder connections cleaned up. If its not the connections it could be the STK chips, or the board itself. It might also be caused by having the set placed close to another electrical device that causes a magnetic field that overtime messes with the colors on your tv. Its more noticeable sometimes after you take the device away, because the TV learnt to compensate for the effects of that field. If separating the TV from all other devices for a few days(while letting it work from time to time) doesn't affect the red tinge, you could try to degauss it manually. Some shops sell a degaussing wand that you wave around the TV to fix such problems. You can also build one yourself - tape a small samarium cobalt magnet (much stronger than your average magnet) to a pencil, then spin the pencil with your fingers while moving past the monitor. Note that if not done properly this can make things worse. Take care
Mar 09, 2006 | Panasonic PV-C2010 20 in. TV/VCR Combo
Samsung HCN553W 55" Rear Projection Television Logo
163 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
