Question about Dryers
Kenmre dryer electrical connections
Kenmore dryer I have 218V 30 breaker. I have red wire and black wire giving me my 218 and a ground copper wire. but no neutral. can I still get my dryer to work.
  • 2 more comments
  • rmaka Jan 26, 2009
    is it still to code i live on a float home, so if i dont have neutral do connect the ground to the neural post of just take the ground to the box
    I have 2 wires and a ground, so if i understand for the short time a week, and have bought dryer recptical and armoured cable with a red, black, white and a ground. But just so i can do few loads of drying shoud the ground go to the ground or to the neutral. i would say that i could ignore the neutral for now if i could get away with that just until next weekend. and use robber gloves and boots when I turn the dryer on.
    Got it Thanks
  • rmaka Jan 27, 2009
    I tried exactly how you suggested and it works now. I see the benefit if have the 4 or neutral for the return and the ground in 4 wire armoured format.
    so far the is no power going to the chasse the first time the ground gave current to the chassis then I change the ground to the other connector.
    Thanks again for your help it gave me confidence to proceed.
    President:
  • 1,214 Answers
Yes. Ground and neutral connect to the same point in the breaker panel, and neutral is not needed for an electric dryer.
Posted on Jan 26, 2009
  • 1 more comment
  • Mark Egan Jan 26, 2009
    Do you have 2 wires and a ground, or three wires and a ground, coming to the wall plug (forget the dryer side just now.) from the breaker/fuse panel?
    You need at least 2 wires and ground to be code, and more important, safe. You can use a water pipe for ground, but then you say you are on a "floating" home? I assume a home floating on water? If so, I would run a new 10-2 or 10-3 with ground.
    If you've got a good ground between the dryer and the fuse box/breaker panel, then you won't need to worry about runner boots and gloves. Whether that ground is through the neutral, or ground.
    Remember, neutral is tied to the same point in the breaker panel/fuse box as the ground is. Either way, either go to ground, and you will have ground.
    Thanks for the rating!
    By the way, you will have ground as long as the breaker panel/fuse box has ground as well. And you probably have that if you are not getting shocked from other devices powered from that panel.
Voltage for ge jp326 wiring diagram
That's the correct way to hook it up. Check the wires for possible insulation missing.
Jan 04, 2012 | GE 30 in. JP340 Electric Cooktop
Wiring of the 2-5-10-15 timer to a jucuzee bath tub it has three wires black blue green. Thanks. Terry.
First thing to consider is size of Load.
Leviton countdown-timer Load rating is 1800 Watt, 120Volt.
Look inside Jacuzzi at rating plate on motor.
Rating plate on motor should give Volts, Watts and Amps.
Formula Volts x Amps = Watts.
Sometimes motor shows VA which is Watts
Is Jacuzzi on 240Volt breaker or 120V breaker?
Leviton countdown timer is not for 240V load.
A) If 120Volt electric Load checks out, here's how to wire timer if 1 cable enter box.
Timer-black-wire connects to jacuzzi-black
Timer-white-wire connects to ground.
Timer-green connects to ground.
Timer-red connects to jacuzzi-blue.
B) Here's how to wire timer if 2 cables enter box.
120Volt cable coming from breaker box has black, white and bare copper wire.
Timer-black-wire connects to black-wire-from-breaker
Timer-white-wire connects to white-wire-from-breaker-box.
Timer-green and jacuzzi-ground connect to ground
Timer-red-wire connects to jacuzzi-black-wire.
Jacuzzi-blue-wire connects to white.
I am puzzled why this wire is blue if circuit is 120Volt.
Nov 26, 2010 | Leviton Timer Switch 2-5-10-15 Minutes, 4...
I just bought a jp328sfss and need to know how to wire it to the breaker panel the way it is wired now it only heats water to 120 degrees F the handyman that hooked it up said there was no way to wire it...
It sounds like you better be careful for starters. I also suggest your handyman sticks to painting. In older homes a 208/240 circuit onlt had three wires. New construction and remodeling requires a four wire system. Per code, a black wire is 120VAC, and a red wire is 120VAC. In a 240VAC circuit they would be called L-1 and L-2 respectively. In order to provide 240VAC they must be on seperate phases. The bare wire in your bundle is the ground wire and is at the same potential as neutral, or the white wire in current four wire systems. If you know how to use an electrical test meter, you should show 120VAC from black to bare copper, 120VAC from red to bare copper, and 240VAC from black to red. If this is not the case, I strongly suggest you have an electrician come in and take care of it in your breaker panel. *****Electricity is nothing to fool around with if you are not absolutely sure you know what you are doing. A loose connection, a wrong connection can result in fire, serious injury or death. It's worth a service call to a licensed electrician or qualified appliance service technician to give you peace of mind, and years of safe use of your new cooktop.
Nov 18, 2010 | GE 30 in. JP328SFSS Electric Cooktop
I have a 3 wire dryer and need to convertto a 4
The following link explains how to correctly install a 220VAC appliance cord:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Match the corresponding colors at the terminal block, making sure the Neutral (White) and Ground (Green or Bare Copper) wires are NOT terminated together.
If you have any questions, please post back and let me know. I hope this helps you.
Feb 03, 2010 | Kenmore 62602 Electric Dryer
Dryer did not come with electrical cord so I bought one.
The following link explains how to correctly install a power cord on your dryer:
The main difference between the 3-wire and 4-wire configuraiton is how the Neutral (WHITE) wire and Ground (GREEN or BARE COPPER) wire are terminated on the terminal block in the back of the dryer:
- In a 3-wire configuration, these two wires are connected together via a ground strap at the terminal block.
Terminate the wires at the terminal block by matching the corresponding colors:
RED to RED (HOT) 120VAC
BLACK to BLACK (HOT) 120VAC
WHITE to WHITE (Neutral) 0VAC - Neutral should also have a ground strap attached that grounds it to the equipment cabinet or ground lug.
NOTE: Newer homes built after the year 2000 REQUIRE a 4-wire configuration to be in complaince with the National Electric Code. In addition, some newer appliances may not work correctly without a 4-wire power cord.
If you have any questions, please let me know. I hope this helps you
Dec 23, 2009 | Kenmore 62602 Electric Dryer
Fridgeidaire clothes dryer
I will try this again i don't think i posted it properly.
On the power cord where it connectes to the dryer make sure the red and black wire goes to the outside screws (L1& L2) the white goes in the middle and the green goes to the dryer cabinet.
If you have the red or black going to the middle one it will trip the breaker.
Oct 06, 2008 | Whirlpool LER5636P Electric Dryer
Running 10/3 wire and wiring clothes dryer directly. The dryer does not have a ground connect for the bare copper ground. Can it be connected to the white neutral at the dryer?
NO!! use the green screw on back where cabinet ground goes red to red white to white black to black remove cabinet ground wire and connect it up to white neutral on dryer connect bare ground to cabinet ground screw ..but wouldn't it be better to connect wall plug to house wiring and correct cord to dryer? always hate working on hard wired equipment since a lot of breakers are never labeled or relabeled correctly
Jul 15, 2008 | Dryers
I HAD GAS DRYER AND I JUST CHANGED OVER TO ELEC AND I WAS TOLD TO USE THE NEW 4 PRONG SO I WIRED IT IN AND I DIDN`T HAVE A ONE PIECE BREAKER SO I USED TWO 15 AMP TOGETHER AND I HAVE NO HEAT IN THE DRYER....
You need a 30amp double pole breaker and be certain that the fuse box is a grounded box, so that your white neutral wire is separated from the green ground wire.
On the dryer your wiring should be as follows:
Red.....left or right terminal
Black...Left or right terminal, (or remaining end terminal)
White...Center terminal
Green: Attached to dryer frame or chassis terminal
In the fuse box:
Black to 1 breaker terminal
Red to other breaker terminal
White to neutral terminals in the box
Green to the ground terminals in the box
If you have no green or ground terminals in the box, then the green wire at the dryer should be connected to an active ground source, i.e., a copper water line or preferrably a copper ground rod.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 23, 2008 | Dryers
Connecting to ground or neutral
SOMETHING DOENST SOUND RIGHT ABOUT THAT AT ALL. i would contact an electrician, would not even want to venture a guess as to whats goin on . let alone advise to hook up a ground to a nuteral and cap the nuetral.theres somehtin up there . i would call in a pro on that one
Mar 08, 2008 | Kenmore 30 in. 42701 / 42702 / 42709...
Jenn-Air JED8430 Electric wiring confusion
On Cooktop From Box
Black to Black
Red to Black w/red stripe
White to Ground
Green to Cooktop frame
Nov 16, 2007 | Jenn-Air JED8430 Electric Cooktop
Dryers Logo
41 people viewed this question
Top Dryers Experts
