How to do a system recovery when my cd rom drive doesnt work?
I have a gateway computer that is about 7 or 8 years old. A little while ago the cd-rom drive just went. Then 6 months later it froze up while I was on the web and I shut it down using the surge protector. When I turned it back on a message came up saying boot failure system halted. I cant use my recovery cd because my cd-rom drive is useless. I tried booting it up again and now the same message still comes up only now it says media failure too. Any suggestions as to how I can do a recovery without a working cd-rom drive? And pressing f-11 does not work. Any suggestions would be greatly appreciated.
  • eshortie103 Jan 26, 2009
    Thanks! Would a flash drive work? How could I make it bootable? Would I have burn my system recovery disc?
  • 1,879 Answers
Got to have a new cd-rom drive mate, most practical approach.
other options are network boot (done in offices with many computers), USB boot (if your BIOS supports it & you need to have a USB device with the bootable image of the system disk), etc.
Posted on Jan 26, 2009
How do I download or get gateways 500 gr recovery disc ? I need everything reistalled
To start the systemrecovery:
  1. Restart the computer.
  2. When the Computer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available orfails, recovery of the Operating System will need to be from Recovery Media. Ifyou do not have a set of Recovery Media, you may purchase the set onlinefrom the manufacturer. Note: If your computer does not havean internal optical disc drive, an external optical disc drive will be requiredin order to recover the Operating System using Recovery Media.
  2. When the computer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: Ifthere are multiple Recovery CDs, please insert the first of the Recovery CDs.
  1. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Sep 22, 2011 | Gateway 500GR PC Desktop
My old computer is a Gateway 400 desktop. But I have a different Mother Board. A DFI AZ30-TL. And a newer compatible hard drive. All this was done about 7 to 8 years ago. The only original Gateway devices...
Look at removing the upper and lower filters from the CD drive on Windows, Microsoft has a guide here
CD Rom drives don't have drivers as such, so the drivers you need are for your motherboard. If the drive has failed, you can get any DVD drive that has the same kind of connector (parallel IDE) and replace it.
Jul 24, 2011 | Computers & Internet
Windows could not start because file is corrupt or missing \windows\system32\config\system this for gateway LT2016u Notebook and it has no setup cd-rom to start repair what can I do?
hard drive is shot
you will need to replace it and purchase a cd windows program from Gateway.com for you model computer. I had to do this and the cost was under $25 least year
Apr 21, 2011 | Computers & Internet
Bootmgr is missing on Windows XP System. Gateway
1.Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
2.Click to select any options that are required to start the computer from the CD drive if you are prompted.
3.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
4.Press 1 (One) to select windows XP and then hit enter.
5.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
6.At the command prompt, Type Bootrec /RebuildBcd and then press ENTER.
7.If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type yes. A confirmation message appears that indicates the entry was added successfully. 8.If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command.
Bcdedit /export C:\BCD_Backup
ren c:\boot\bcd bcd.old
Bootrec /rebuildbcd
1.Restart the computer
May 15, 2010 | Gateway ML6721 Notebook
It doesnt rcognise the recovery disc 1 year ago my son formatted the hard drive soi installed windows xp from a new disc, and it worked fine untill now when th pc ceased to work properly. so i put the xp...
probably ur cd/dvd rom drive is down or the cd frm where u r installing is corrupted..copy it from elsewhere n try..or try downloading....
..contact ur system admin/vendor....
Oct 27, 2009 | Computers & Internet
-DVD Drive won't read or burn blank -DVD media
Just replace the drive, that unit is old and it has a bad reputation.
Mar 03, 2017 | Computers & Internet
My New Gateway isn't recognizing the cd/dvd drive :(
PLEASE read all the way through before doing any of the options.Thanks,
Sounds like something in the system files/registry may have gotten corrupt. Perhaps one of the programs you installed caused an issue. Whatever the case, if it's brand new you should have a year,or at least minimum of 60 or 90 days of free tech support from Gateway, this would probably be the most time efficient method.
Just to know in advance: Depending on the computer, if it didn't come with a set of back up disks for the Vista program, ( program file are securely saved/stored on the Hard Drive ) Gateway will recommend you create a back-up set if it didn't come with one. Advisable to do this anyway in case of a complete Hard Drive failure.. They should be able to walk you through the procedure to get it back online.
If calling Gateway tech support isn't an option, then you may be able to try a SYSTEM RECOVERY to a time before the problem developed, I'm not sure if that will work or not, won't hurt anything to try. If that doesn't work, the system may be able to reinstall the files for the dvd/cd rom drive.
To find where to see if this is an option that can be done, ( it will say something like Application Recovery or Gateway Application Recovery ),and to find the SYSTEM RESTORE, and to find the location of where to create the back -up disks if that is a necessary option, and to find how to do any of the other options mentioned, DO THIS---> From your start menu open ALL PROGRAMS > open PC HELP & TOOLS > In that list you should see all of the options mentioned here.
The other option is to uninstall, or rather do a complete system recovery. Just make sure you have a back-up of everything you want to keep that you have saved on it because it will delete everything. If you have the disks for the Vista program great, if not and the program is on the hard drive, make a set of back-up disks for the vista program itself. This is recommended always just in case of a complete Hard drive failure.
If you can't call Gateway for tech support,TRY THIS ONE FIRST, you should be able to go to the Gateway website and find the download for the driver for your dvd/cd rom, try downloading it and installing it before you do any of the other options. A complete System Recovery is a big pain and time consuming, plus you will have to get/borrow from a friend a cd/dvd writer to back up everything before you start a recovery.
Nov 18, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Dell laptop DVD_Rom not detected
well evidently you have a software problem, otherwise your dvd unit is broken, but lets hope not and try this:
you surely have the recovery CD or DVD that comes with your laptop and if you are clueless at computers you have to play attention on the following:
first is to ensure your unit is working and tha can be done by booting from any bootable CD. Just enter the bios if necessary, set the machine to boot first from cd and next from hd... then start with any bootable disc that you know is working. Windows installing disc can be, laptop recovery can be too... if it works now you know the problem is on the operative system and you need to focus on that.
try going to systems properties, then go to the exclametory sign and go properties with right button, navigate that options and if you are shown, ensure to enable DMA access mode. If you cant do this, just uninstall that device by clicking on the right button and selecting unninstal... and then do the same with any devices related to cds and ide devices... finally reboot your system and let windows put all that bach in place.
If this doesnt help you you might need to reinstall OS, so either backup your files and restart using the cd that comes with your computer or get back with more precise information, because yours is a very generic problem and many things can cause that.
Nov 17, 2007 | Memorex CD 482E (CD-482E) CD-ROM Drive
System recovery
It sounds like the boot sector on your main hard drive is corrupted. You should have created an emergency boot disk when you first purchased the computer. Since you don't have the oroginals you should borrow a system CD from a friend and boot up that way and try to a recovery. Selecting F8 during the bootup sequence allows one to start if Safe mode, but I believe (I usually run Linux) you still need the boot sector on the main hard drive to be valid in order for this to work. The F1 gets you to the Bios screen (?) where you can select the boot sequence (hard drive, CD, or floppy first/second/third), among other things. Hopefully someone with more Windows experience than I can assistance better than I can, I just thought I'd throw that out there.
Dec 05, 2006 | Gateway E-2000 Deluxe PC Desktop
Computers & Internet Logo
229 people viewed this question
David Payne
David Payne
