Question about GE GSH25JFR Side by Side Refrigerator
GE Refrigerator model GSS22WGPH whines loudly!
It sounds like it might be when it auto defrosts or something but it goes on forever and its so loud. Is that what its doing and is there a way to stop it
  • 1 more comment
  • jacey_76031 Jan 26, 2009
    Its loudest in the freezer. Sounds like its behind the ice maker.
  • dave_padley Mar 24, 2009
    When the freezer fan come on (probably defrosting) I get a low pitch "whistling" noise similiar to what you would hear if a window was open a crack on a windy day. It has done this since it was new.
  • Mark Egan May 11, 2010
    Where does the noise come from? Inside the refrigerator, or outside?
    Please state the origination point of the noise more clearly.
    President:
  • 1,214 Answers
Sounds like the evap fan motor has a bearing going bad. Best to replace. Easy to for anyone who can use a screw or nut driver to do.
Posted on Jan 26, 2009
I think GE knows it has a problem with this. I had the mother board (which supplies the DC power) and evaporator motor replaced. Since my unit was only 2 years old, GE picked up the cost of the parts and I paid for the labor.
Posted on Apr 13, 2009
Ice forms on fan...fan can't function...makes loud noise ...refrigerator ge 6 years old ...been doing it forever
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 18, 2010 | Refrigerators
My GE Fridge PSS26SGRD has a moaning howling
The fan is hitting on ice buildup...unit is not defrosting...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Loud noise from GE Side by Side
That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Oct 07, 2009 | GE GSS22JF Side by Side Refrigerator
Loud continuous ticking sound, freezer cold but refigerator warm
heatman101
Sep 27, 2009 | GE Profile Arctica Stainless Steel Top...
GE GSS22WGPH WW won't defrost
I am sure you can do this yourself, Jeff. The test procedure is as follows. Bypass the defrost thermostat (round thingy strapped to evaporater ) place the frig into defrost by manually turning the timer with a screwdriver clockwise untill you hear a loud click. You should be in defrost mode now. If the heater element comes on then you have a bad defrost thermostat. If they do not come on then the element is bad. You can check element for continuity with an ohm meter. The defrost timer rarely goes out but they occasionally do. Wait to see if the timer comes back out of defrost on its own. Takes about five to ten minutes .If it does not, then you can visually inspect timer. There is a sight window on the back of timer that should be spinning if motor is good. Hope this helps
Jul 29, 2009 | Danby (DAR604BLS) Refrigerator
Fridge isn't cold
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 28, 2009 | Refrigerators
GE side by side has a whinng sound goes loud and low
Need to unplug and remove the back panel in freezer to see if there is a defrost problem or whats going on with evaporator fan. Let me know for sure if your model is a HSM25IFTSA so we will be on same refrigerator. Thanks, Sea Breeze
Apr 20, 2009 | Hotpoint (HSM25IFTSA) Side by Side...
Whineing noise\and leak on freezer side in the bottom of it
yes the water in the bottom is because your drain tubing is cloge thid is the small hole in the frezer area defrost your fridge use a wire to clear out the debri that clogs your tubing the water should drain in the pan where the compressor is thanks from gilles
Feb 10, 2009 | GE GSS20IEP Side by Side Refrigerator
Ge eterna refrigerator loud humming
suspect you have a problem with the defrost system and hence the noise with the fan. take back panel off inside the freezer and if i'm right, melt ice off with a hairdryer. get back to me to say the results if you want
Aug 23, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE GSH25JFR Side by Side Refrigerator Logo
427 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
