Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Makes a loud buzzing sound when washing
Kenmore dishwasher makes buzzing sound when washing rest of time it sounds normal
    Scholar:
  • 42 Answers
This buzzing sound can be from a couple things. A lose a lose kick/access panel when the motor and pump is in operation can cause a slight vibrating noise. Try tightening securing the dishwasher and kick/access panel.
Second, (most likely) their can be an obstruction or debris in the water pump. You may see a plastic grid (4" x 6"; filter like) in the right rear of your dishwasher; Try removing the grid (1 or 2 screws 1/4"/cross tip), then use a dry-vac to remove any debris. *
Safety: As a beginning, please remember to perform the repairs with the power-off and ensure you have water in the dishwasher before restarting the water pump cycle (the water-pump can become damaged while dry-spinning and water enters the pump suddenly)
Posted on Jan 26, 2009
Dishwasher is making a loud noise
Sounds like there is something in the filter trap that is right before the mini disposal that is a fan blade, on top of the motor.
Aug 04, 2012 | Frigidaire Professional Series 24 in....
Loud sounds
Many Frigidaire dishwashers come with the promise of being the "quietest dishwasher in its class," according to Frigidaire. However, a quiet dishwasher doesn't necessarily mean that the dishwasher is silent, as some noises are normal. It can take some troubleshooting at times to determine if a noise coming from the dishwasher is typical or if it indicates a larger problem Listen for the sound of water filling and draining throughout the wash cycle. These sounds are normal and do not indicate an issue.
  • 2 Pay attention to the drain motor, which operates at the beginning of each cycle. This noise should be fairly quiet and should not sound like a loud, grinding or banging sound.
  • 3 Note that the sound will change when the wash cycle moves between the lower and middle spray arms. This sound should be temporary and fairly quiet.
  • 4 Look for hard items in the dishwasher grinder or filter if a loud crunching, buzzing or grinding sound is heard. The dishwasher can typically grind up these items within one or two cycles, but the item may be lifted out and discarded to eliminate the sound.
  • 5 Remove the bottom rack and spray arms from the bottom of the dishwasher if there is a loud noise coming from the dishwasher that does not resolve itself. Look inside for the impeller, which is round and spins. Remove any debris that may be clogging up the impeller or pump.
  • Oct 07, 2011 | Frigidaire Professional Series 24 in....
    I have an kenmore elite "ultra wash" model 665. not sure the rest.. about 7/8 years old, making loud buzzing sound during wash cycles,starts about 5 minutes into the normal wash cycle. i removed the inlet...
    I have the same problem as those who stated their dishes are not getting clean. If you listen to the wash cycle you should hear water sloshing around inside. If you hear just a humming sound the washer has no water. I have this problem. I had a tech come and he told me the water is syphoning out my drain and I need to change my plumbing, then he charged me $65. I have lived in this house for ten years. 6 with the washer that came with house and 4 with this Kenmore Elite. This problem started about 6 months ago. So what I have been doing is opening the door, after the humming starts and the sloshing stops, and adding about 2 L of water. It seems to wash just fine after that.
    Jan 12, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
    Our Frigidaire Ultra Quiet II dishwasher loud buzzing noise- wash
    No longer "ultra quiet" huh?
    A sound during certain cycles indicates a broken part. By the information provided sounds like a pump may be the problem. You may need to contact a service tech about this issue. If the appliance still under warranty, the service should be provided for free.
    Every time when you hear noises (other than the normal ones) in the appliance, it indicates there is something wrong and it will worsen over time, so as soon you hear something is not ok, get assistance.
    Aug 30, 2009 | Frigidaire Dishwashers
    Loud Buzzing Sound from Dishwasher
    have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
    Jul 30, 2009 | Dishwashers
    Kenmore elite dishwasher making loud buzzing sound when washing
    it sounds like a broken empellar in the pump like there is a piece of it broken off and ratteling around in there... change the empellar
    Feb 21, 2009 | Dishwashers
    Buzzing sound
    a loud buzzing sound it is probably a faulty control/timer module.
    If the appliance works the same, you can keep it like this, if it still under guaranty, call the number listed on the owner manual to get repair.
    If you got the sound only recently, that means that the control is going to fail soon, in that case call a repairman and have the control assembly replaced.
    You find diagrams and parts here,
    just enter the model number.
    Oct 10, 2008 | Kenmore 24 in. 15079 Built-in Dishwasher
    Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
    643 people viewed this question
    Top Kenmore Dishwashers Experts
    Ken Johnston
    Ken Johnston
    Level 1 Expert
    Fred Sops
    vince
    Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
