Question about Genelec 8020B Monitor Studio Active
Genelec 8020B Monitor Studio Active - Genelec 8020B Monitor Studio Active
What can I do about my flood-damaged monitors?
I would strongly suggest putting an insurance claim and replacing them. Water damaged cabinets may swell and come unsealed over time, as well as the speakers themselves and the electronics degrading faster than you might expect.
Feb 07, 2016 | Yamaha MSP5 Studio Monitor Studio Active
What is ella3011s password on msp?
remove all cords on powerplug on speaker!! short the nutual and hot for 50 seconds that resets rom to default, then resetup speaker like new! works on cars to!
Jul 11, 2014 | Yamaha MSP5 Studio Monitor Studio Active
Mackie hr624
I suggest either replacing these OR taking them to a professional to be serviced. Fuses blowing are a sign of serious malfunction and inexperienced DIYers should not attempt to induce the Darwin Effect
Feb 04, 2014 | Mackie Hr624.mk2 Active Studio Monitor
I have the power 8030 that I bought in London. I've been using them with my step up & down transformers. I moved to another studio and a kept the same configuration but now the wont power up using...
Compare the power inout voltage listed on the BACK of the speaker and compare that to your current power supply. You have not told us wheree you are or what your power there is... or the voltage listed on the back of your speakers. Giv us this info so we can better help you. These are expensive speakers to get things wrong...
Sep 12, 2011 | Genelec 8030.LSE Power Pak Active...
I have a Yamaha is 50m studio monitor.Is there any way to open the back of these something is rattling around inside a loose wire or something
you can either drop out the woofer by removing the screws holding it in or remove the back panel ( #2 phillips screwdriver ) those are the easiest ways into the cabinet.
Sep 04, 2011 | Yamaha HS50M Active Studio Monitor (Pair)
Very loud ground hum when turned on
If nothing is pluged into the speaker and it makes that noise. It is not a ground problem. You either have a blown amp or remotely some bad connection at the large filter caps.
Nov 30, 2010 | Mackie MR8 150W 8 Active Two-Way Studio...
I have a pair of Behringer B2031A Active Studio Monitor. All is functioning perfectly and automatic power is set to off. . After 5 minutes on, one monitor shut off unexpectly, which is not to be suppose...
This sounds like an internal failure, probably something overheating since it takes time to recover. Behringer OFTEN puts thermistors to sense temp on heatsinks that shut down in the event of overtemp.
If you are not electronically adept, best to take this in for repair. If you are able to work on electronics, try using circuit cooler to isolate the failure. First a good visual inspection followed by the finger test searching for hot components... Do use care where high voltages are involved, mainly in power supplies and input power leads, etc..
Nov 29, 2010 | Behringer B3031A 2-Way Active Studio...
Genelec 8020B Monitor Studio Active Logo
27 people viewed this question
Top Genelec Music Experts
Michial Gueffroy
Are you a Genelec Music Expert? Answer questions, earn points and help others
