Question about Fuji FinePix J10 Digital Camera
Zoom lens is stuck on my camera
I dropped my digital camera and now the zoom is stuck, it wont come all the way out or go back in either, is there anyway of fixing this as i can no longer take photos with my camera because it comes up with zoom error
  • 2 more comments
  • ekanning Jan 27, 2009
    I have the same problem! It seems as if the lens is coming out a little crooked, so i dont know if thats why it can go in or out. Ahhhh help!
  • Anonymous Feb 02, 2009
    I put the camera on a tripod, but one of the legs gave way and the end bit of the zoomy thing that sticks out hit a cupboard. It is all crooked now.
    HELP!!!!!!!!!!!!!!!!!!
  • lcervera65 Feb 13, 2009
    The same thing happened to us when it was dropped.  Help, anyone?  Thanks!!
  • bcvd Apr 06, 2009
    please help i droped it and now the zoom thingiemabober wont go in or out can someone help me? email me at kevin.pwns@live.com
Hey, my husband just fixed it! You just wiggle/bend the zoom lens, and you feel a "pop", and then the zoom retracts and you're fine! I was afraid to "break" it, but someone on vacation had the same problem and told him this solution a few weeks ago. So don't be afraid to use a little force-at least, in our case, it worked! Good luck.
Posted on Feb 13, 2009
My camera been dropped and now it has a zoom error and wont close the lens back it stuck in one place - how much it will cost me to repair it? is it expensive?
To repair this model of camera requires a complete strip down to get at the lens unit. Lots of carefull desoldering etc.
The lens unit is just a larger version of a compact camera lens unit. Lots of gear gogs to release before you can un jam the lens its self.
Price will depend on where you take it and what damage has been sustained
Nov 18, 2009 | Fuji FinePix S1000FD Digital Camera
Zoomlens stuck
Examine the lens carefully. you will see that the outer lens is out of line with the inner lens. . hold the camera firmly with one hand using the fingers of the second hand firmly nudge the outer lens back in line. reinsert battery and test.
Good luck,
Luwangula
Sep 15, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Zoom error, Fujifilm J150w
I just pulled apart the camera, everything inside was intact. No cogs broken. couldnt find anything to fix (not a camera expert by the way).
In desperation even put some WD40 on the lens barrel - still no luck.
Camera turns on - barrel is stuck out. Wont zoom, wont go back in and wont take a photo.
Daughter's camera and she says she didnt drop it but just saw it on her desk with the lens out...
Would be good if someone could shed some light on the problem.
Jul 05, 2009 | Fujitsu Cameras
I have a casio exilim ex-z60 and i accidentally drop with the lens was on, and now its stuck it wont going back(close) dis align the lens, what can i do?
try taking the battery out, and then putting it back in, and hit the power button a few times.
i drop my camera all the time.
make sure your battery is charged before you declare it broken.
[hahah, i did that once]
Nov 26, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Jammed digital zoom lens
For whatever reason, the lens has failed. This can be caused by many things: the lens motor has failed or is stuck, the gears involved in driving the lens have jammed, or, as pointed out previously, the lens itself, a series of tubes which fit into one another has become stuck. You can try GENTLY pressing down on the lens when you first power the camera to see if you can free up the stuck lens. If that doesn't work, I'm afraid you are going to have to get the camera serviced.
The clicking sound you're hearing is the lens trying to move itself. Unfortunately, it's probably not going to be fixed by pushing on the lens. You are going to have to get the camera serviced. Sorry!
Oct 27, 2008 | Polaroid Cameras
Zoom error
worked on allot of fuji's. first detease, a gear is slipping in the lens retract assembly due to a crack or wear or jam
2nd guest .. zoom errors means its really stuck tight
the gears can be ordered and replaced and one more possibility is that the motor that drives the gear is bad
Also if dropped or zoom lens jammed hard... lens assembly needs total realignment or replacing..
May 23, 2008 | Fuji FinePix F460 Digital Camera
Zoom error
I'm not sure if this will work as I have yet to try this for my self. But according to others who have had this problem pulling lens out while camera is off and then restarting camera works. If this does work please notify. Or just tell me what happens when this is done
Feb 18, 2008 | Fuji FinePix A900 Digital Camera
Zoom Lens
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but they're still worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 11, 2008 | Fuji FinePix A303 Digital Camera
Zoom and shutter not functioning
that is a symptom of being dropped and stuck in a mode.
it requires total dissemble of the camera to fix or replace the lens. your lucky it takes pictures at all. most cameras refuse if the lens is stuck.
Jul 28, 2006 | Panasonic Lumix DMC-LC33 Digital Camera
Fuji FinePix J10 Digital Camera Logo
1,554 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
