Question about Philips 190S7FB 19 inch LCD Monitor
What's your problem?attention security flag off
TA flashing on dash
It comes from RDS (Radio) - TA, TP (traffic announcement, traffic programme) The receiver can often be set to pay special attention to this flag and, for example, stop the tape/pause the CD or retune to receive a traffic bulletin. The TP flag is used to allow the user to find only those stations that regularly broadcast traffic bulletins whereas the TA flag is used to signal an actual traffic bulletin in progress, with radio units perhaps performing other actions such as stopping a cassette tape (so the radio can be heard) or raising the volume during the traffic bulletin.
Feb 14, 2015 | 2004 Citroen Xsara Picasso
Peper jam sensor arm has dislodged how do you get it back in
Peter Smith:
You'll have to open the body of the machine, (it's pretty tricky so pay attention to how the machine body goes back together). Once the cowling (cover) is off, you should be able to use a pair of tweezers to gently put the sensor switch arm (known as a sensor flag) back into position.
Sep 22, 2012 | Lexmark X8350 All-In-One InkJet Printer
Hp 35 s flags
There's a full description in the "Flags" section of the manual (beginning on page 14-9 in my copy), including a programming example.
If you need a manual, you may download one here.
There's a number of training aids for the 35s available here. One of them is titled "Using HP 35s Flags".
Mar 01, 2012 | HP 35s Scientific Calculator
Nakido flag
Make sure you turn off your anti viruses as some can conflict with it. If that doesn't work, you should try this with a different browser, for some reason when I was using it, Nakido Flag couldn't be detected in the Opera browser. I hope this helps.
Feb 24, 2012 | Nakido Flag
Load paper/remove output led 'flashing'
normally has a little flag or flap hanging out at the exit push it down be care ful it is a sensor or if it is gone you can just replace the flag by googling the exit flag senor and buy it online and replace it.
Sep 29, 2011 | Dell 1720dn Laser Printer
How do I reset the counter for the drum unit on a Brother MFC 9840-CDW. It says to replace the drum but the unit is printing flawlessly.
On the TN-155 toner cartridge, a mechanical 'flag gear' that will reset the counter for each individual cartridge when first 'triggered'.
After each page print, the appropriate counters are incremented regardless of toner content (that is why it is still printing 'flawlessly') and after a pre-determined count has been reached, you will get a warning to change the drum as is will then be notionally (not actually) empty.
Before you decide to reset the 'flag gear' on the drum, make sure you are not actually nearing the physical empty state ... it might be a wiser decision to purchase a refill kit which should come with instruction on how to fill and reset the 'flag gear' (this needs some dismantling of the drum cartridge) or buy a compatible or genuine toner drum cartridge.
In any case, Google 'Brother drum flag gear' for more information.
Sep 20, 2011 | Brother MFC-9840CDW Laser Printer
HOW DO I RESET THE 'MAINTENANCE NEEDED' LIGHT?
SERVICE INTERVAL REMINDER
If equipped with a service reminder flag, the oil and oil filter service interval reminder flags will activate after every 7500 miles of operation. To reset indicators, insert ignition key into slots below indicator flags at lower right corner of instrument cluster. Push key in until reminder window changes from Red to Green.
Jul 04, 2011 | 1991 Honda Accord
My copier/fax machine says it is out of toner. It is NOT. I have tried unplugging it and then plugging it back in, but it still will not print. What can I try next? Thanks so much Shevelia McGuire The...
If a cartridge filled with toner you need to check the status of the flag. The flag is under the side cover the toner cartridge. Partner code flag in the cartridges that came with your printer. In cases when filling bolshtnstve forget to pay attention to the position of the flag, and he is responsible for identifying the printer of a new cartridge.
Jun 28, 2011 | Brother Office Equipment & Supplies
Ineed blacklight tango down product key
Serial: http://fileups.net/1h9tg do a small surveyCHEAT CODES:
Al13nwa4re5acasE - Alienware Symbol
Alienwarec8pestU - Alienware Black Dog tags
AMD3afrUnap - VISION square tag (red)
4MDB4quprex - VISION square tag (blue)
AT1hAqup7Su - ATi square tag.
E3F6crAS5u - Grey/Orange Dog tags
Denek1Ju3aceH7 - Yellow Teddy Bear
Fam1tsuprusWe2e - Tag with ingraved-writing/picture.
Bl4ckl1ght2Ru7uS - Couldn't get to work.
Ch1pBLuS9PR - Blacklight logo chip.
Ch1p1GN1u0S - Lighting bolt chip.
Ch1pMMRSc0rp - Blacklight "W" logo chip.
Ch1p0RD3Ru02 - Order logo chip.
Ch1pZ0MB1Et7 - Zombie Studios logo chip.
H4rtBr34kerio4u - Pink Brass Knuckles.
SKULLCLUB9rAVaZ2 - blue skull square tag.
J4ceH4llstuFaCh4 - Couldn't get to work.
StormLion9rAVaZ2 - Dinosaur thingy??
St0rmLi0nB4qupre - Dinosaur thingy?? tag.
R4z3erzu8habuC - green and black tag.
UPGr0undWupraf4u - Black square tag with design.
UPGr0undv2FUDame - Black square tag with design.
AUS9eT5edru - Australian Flag
AUTF6crAS5u - Austria Flag
BELS7utHAsP - Belgium Flag(?)
CANfeprUtr5 - Canada Flag
DENdathe8HU - Denmark Flag
FINw3uthEfe - Finland Flag
FRApRUyUT4a - France Flag
GERtRE4a4eS - Germany Flag
HOKYeQuKuw3 - ???
INDs4u8RApr - India Flag
IRE8ruGejec - Ireland Flag
ITAQ7Swu9re - Italian Flag
JPNj7fazebR - Japanese Flag
KORpaphA9uK - Korean Flag
MEX5Usw2YAd - Mexico Flag
HOLb8e6UWuh - Holland Flag
NZLxut32eSA - New Zealand Flag
NOR3Waga8wa - Norweigien Flag
PORQ54aFrEY - ???
R41nB0wu7p3 - ???
RUS7rusteXe - ???
SINvuS8E2aC - ???
ESPChE4At5p - ???
SWEt2aPHutr - Sweden Flag
SWIsTE8tafU - ???
TAW8udukUP2 - ???
UKv4D3phed - United Kingdom Flag
USAM3spudre - United States Flag
May 20, 2011 | Computers & Internet
Philips 190S7FB 19 inch LCD Monitor Logo
112 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
