Question about Jenn-Air 24 in. JDB2150AWP Built-in Dishwasher
Jenn-air 1250 AWP won't start- lights don't come on
Dishwasher won't start...it happened a few weeks ago, and I was able to unlock it, but not this time.
  • 5 more comments
  • jeffmgr Jan 26, 2009
    when I press the type of cycle the lights don't come on, and when I press start the lights also don't come on...
    Mark, Thanks for taking the time to help out...I also thought of that, and reset the circuit breakers that go to the dishwasher...we've had the unit for about 2 years, and about a year ago, we noticed that the lights (LED'S) wouldn't always come on, but the washer worked. About a week ago when we tried to use it, the same thing happened...I consulted the manual and it mentioned about 'unlocking' the unit...so I tried and after pressing the 'heated/dry' button the lights came on and the unit started up. It's been working fine every day until tonight.
    Mark,
    I looked inside the unit and here is the info: JDB1250-AWP. Made in Newton, Iowa. Looks like serial # E 39927 LR 111720.
    Jeffmgr
    The manual that came with it lists the model as JDB-5...but it's the pro- model with the pro handle to match our Jenn-air refrigerator.
    that bad connection should be covered by the Jenn-air warranty, right?
  • Mark Egan May 11, 2010
    Sounds like power has been removed from the unit. Have you check the breakers or fuse?
    Please describe the symptoms of "won't start".
    President:
  • 1,214 Answers
I am going to say it sounds like either bad connections on the controller circuit board, or a failing controller.
I can't find you model on the JennAir site not on SearsPartsDirect, so can't help you much further. If you want to confirm your model number, then I'll look deeper.
Posted on Jan 26, 2009
  • Mark Egan Jan 26, 2009
    Found a manual. I am thinking your going to find a bad connection/connector at the board, or the door close switch.
    If there is not a bad connection, then it's probably a failed board (could be a bad solder joint.).
    If you've got warranty, then I would expect it covers any part of the failure, although I don't know what the details of JennAir's warranty is/are.
    I've never heard of a warranty over a year though, and you indicate this unit is over 2 years old.
Jenn-air dishwasher will not start
it is usually the panel that fails
Apr 12, 2015 | Jenn-Air Dishwashers
I have a Jenn Air dishwasher and the door latch mechanism has been "locked" but teh door is in the open position, how do I unlock the mechanism. I have pushed the het button three seconds but this me
This happened to me. After replacing the board for $100, still happened. I messed with it myself... Reach under the counter to where the "catch" is. Mine is white plastic. Mine had a bit of movement side to side (like 3mm). Try sliding it to one side or the other and see if the door will shut. I spent $100 I did not need to spend and hand washed dishes for 6 days waiting for the part! Good luck
Jan 05, 2013 | Jenn-Air 24 in. JDB1100AWS Built-in...
Dishwasher won' t start. None of the lights are coming on
dishwasher wont start. none of the lights are coming on.
Nov 09, 2012 | Jenn-Air 24 in. JDB1080AWS Built-in...
Leaking at the bottom of the door and unsure where plastic door seal goes.
This dishwasher will leak if there is to much water in the unit.
I have the same dishwasher with a different problem.
Mine won't circulate the water. I have not use it for a while and some water will back feed from the sink and fill the dishwasher, so if I don't check for that problem once in a while I see it start to leak.
It never has done that when the unit was working....
Aug 28, 2011 | Jenn-Air 24 in. JDB1100AWS Built-in...
The electronic controls click out with in just a few minutes after starting the oven. The light does not go on and nothing works. This problem started within one week of install and use and have had the...
Unfortunately this seems to be a problem with several of the jenn air models. I have replaced quite a few and have also talked to thier tech line for servicers and they don't have anything else to offer other than replacing the control board. Each time I ran across one I found no other problems and I tested everything. If you replace 3 times you can usually get them to give you a new one.
www.appliancehelponline.com
Mar 18, 2010 | Jenn-Air JGW8130DD Gas Single Oven
Hi i have a jenn-air dishwasher JDB8910AWW about 10 yrs oldand started to have problems that it wouldn't drain now I can't get it to turn on..any advice??
I have a Jenn air dishwasher JDB8910AWW It fills with water but will not wash also i hear a clicking sound and the control panel blinks
Nov 18, 2009 | Jenn-Air 24 in. JDB8910 Built-in...
Smell in a new dishwasher
run bleach through it. if your on well water then this will happen often
Jun 22, 2009 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Jenn air jdb8910 does nothing
Had a similar problem with mine a few weeks ago. It was intermittent in not working on delay. My first thought was that the close switch was not working. Upon disassembling the door, and fiddling with the switch, I heard some sizzling on one of the circuit boards. A little more digging revealed some cold solder joints on a couple of board mounted relays.
I removed the board, re-soldered the loose relays, and everything has worked fine since.
Oct 23, 2008 | Jenn-Air 24 in. JDB8910 Built-in...
Jenn-Air 24 in. JDB2150AWP Built-in Dishwasher Logo
1,076 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
