Question about Toshiba 65H82 65" Rear Projection Television
Does not turn on. Only the red light otherwise it is dead....
TV is unresponsive. If you push the power switch, the red light just comes on and the TV never powers up. Could it be a circuit breaker inside the unit? It started getting a little flakey the last 2 weeks but now it does not come on at all. Can you offer any suggestions? Thanks!!!
  • Paul Myers Jul 22, 2007
    Techman,
    Thank you very much for your reply! I am probably going to call out a service tech since I am not comfortable soldering to a PCB. Probably not like the old Heathkit days...
    You do seem very knowledgeable and I will call on you again if I need any help!
    Thanks alot!
    Paul
  • Anonymous Sep 29, 2008
    I have the same problem. The red power indicator light comes on, but there is not video. I fiddled with the board in the rear and temporarily had audio come on, but I touched something and that turned off too. What do the capacitors look like on this?
    President:
  • 3,130 Answers
Yes, first check the main fuse, if it is blown, before you replace this fuse you will need to do two things. Locate two capacitors on the power supply board, they will be labeled C 809 and C 810. You will need to resolder the negative connections on these capacitors. If you do not , the set will work when you replace the fuse, but will end up blowing out the capacitors or the regulator in the power supply. If you do not understand how to do this or you do not have any printed circuit board experience, play it safe and call out a tech to fix this set for you. Good Luck
Posted on Jul 16, 2007
SOURCE:
What would make a crosley 42" lcd tv not turn on
check the psu, if you can manually switch the power the power then its going to ease your work
May 27, 2014 | Crosley C42hdgb
Relay clicks when applying power. Yellow light comes on. TV is dead otherwise. Power supply is outputting +5, 12, and 24 volts Mainboard (3647-0282-0150) has +5 and 12 volts always applied. Checked...
Amber light on means standby voltage is high. IF amber light does not go white when power button is pushed the its one of two things.
A. No power on command from main board. Usually labeled PS-On. Should go high from 3.3v or maybe 5volts. If not present Main is defective.
B. If the ps-on line is going high then your problem is a defective power supply.
Oct 15, 2013 | Vizio XVT472SV 47 in. HD-Ready LCD TV
Green LED always on, power switch has no effect
if using a box or receiver in line with the set unplug those as well. I assume the red light on the set is not coming on or a light is blinking?
Dec 18, 2012 | Sony Grand WEGA KDF-50WE655 50" Rear...
Vacuum head stopped working, unresponsive to on/off switch and light bulb is out. Canister otherwise works fine. Help!>?
Power head on/off switch could be faulty, Wires running through hose may be broken, electrical connections may be burnt.Motor in Powerhead could be dead.
Nov 17, 2009 | Vacuums
TV will not turn on. Red light so power is on.
Ur video inverter board it dead.
U need a new one.
Aug 23, 2009 | Televison & Video
InFocus ScreenPlay Projection HDTV does not turn on
try accessing the service menu and doing a factory reset on it
Jul 30, 2009 | InFocus ScreenPlay 61" Rear Projection...
The screen will not come out and the unit will not play. The blue light comes on to switch from radio/cd/tv, etc. and the red light comes on when you push cd eject, but otherwise it will not play any
MAKE SURE YOU PRESS THE SOURCE BUTTON AS THE SCREEN WOULD NOT COME OUT FOR THE RADIO BUT WHEN PRESSED AGAIN WILL PROBABLY COME OUT FOR THE TV
May 04, 2009 | Car Audio & Video
Red power light is unlit, TV is unresponsive
This has most probably blown an internal fuse in the power supply. Most have a surge protection type fuse. It is best to have a repair engineer have a look at it as the fuses are specially rated for safety.
Mar 28, 2009 | LG 42PC5DC 42 in. Plasma HDTV
Toshiba 65H82 65" Rear Projection Television Logo
121 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
