Question about Toshiba Satellite A75-S211 Notebook
Adding memory to Toshiba A75-S211
I need to add 512 MB. How can I go about this? I have no experience in this type of thing. I want to know if I can add an additional 512 MB, or replace what's there with 1GB?
  • p_mcbear Jan 26, 2009
    Thanks for the info, but what I need to know is: can I ADD memory, or do I need to REPLACE what's in there with a larger card?
    Thanks
  • p_mcbear Jan 30, 2009
    HELP, I have the laptop open, and I see the memory. But I do not see the extra slot for additional memory... although I was told that there was an extra slot. Does anyone out there know about the Toshiba A75 S211? Where is that extra memory slot located?
    Problem Solver:
  • 13 Answers
You buy the memory here for a great price or anywhere online instructions are on the page
it replaces the 512
http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    Desktops
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    Laptop
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    Posted on Jan 26, 2009
    • 1 more comment
    • eric gieseke
      eric gieseke Jan 26, 2009
      hi ok i see,
      it would add to the memory that came with the system
      but replace if you had any expansion allready,
      in this case you would add it nothing to replace
      hope that helps?
      eric
    • eric gieseke
      hope that helps,
    • eric gieseke
      eric gieseke Jan 30, 2009
      hi there might find some specs and manuals where to find the memory on this page
      http://eu.computers.toshiba-europe.com/i...
      thik is the closest model but it has a ton of info
      expore
      e
    I have a toshiba satellite a75-s229 i want to add more hard drive space. how much can i? and what model?
    You can virtually add any amount of hard drive but I would recommend you to keep it low from 512GB. A 320 GB hard drive in my opinion is a very large one and should work out perfectly.
    For the model you can install any company's hard drive until its appropriate to the type you have.
    I personally would recommend SeaGate. I have had a very good experience with them.
    Hope this helps, Please feel free to ask me for further assistance.
    Apr 09, 2010 | Toshiba Satellite A75-S211 Notebook
    My Toshiba A75 S211 os XP Home microphone is not working, is there a switch or something else?
    Hi, from the "Start" search window: Type: microphone, select to open and configure to specification. "If the solution helped, rating it is appreciated , thanks.
    Mar 17, 2010 | Toshiba Satellite A75-S211 Notebook
    My Toshiba Satellite A75-S211 computer, will suddenly shut down.
    Mine did this and I thought it was overheating and vacumed the back vents. This fixed the problem.
    Nov 20, 2009 | Toshiba Satellite A75-S211 Notebook
    When i try to boot my toshiba a75 laptop i receive a boot last good ... it won't boot i removed memory module i installed 2 yrs ago and it boots ... i purchased new memory module and get same error- it...
    Below are the specs to the type of memory that can be installed in the A75...it is very specific and cannot be anything else then what is listed. You have 512 mb built onto the motherboard, with one expansion slot. That slot can only hold up to 1 gb stick if the BIOS has been upgraded. Go to Toshiba support and make sure the BIOS on the machine is up to date so it will accept the larger stick of ram memory and make sure all the specs are right on the stick that you have.
    Each memory slot can hold DDR PC2700 with a maximum of 1GB per slot.*
  • Maximum Memory: 1536MB
  • Slots: 1 (1 bank of 1)
  • Standard Memory: 512, 768, or 1024MB (512MB non-removable)
  • USB Support: 2.x Compliant
  • Oct 20, 2009 | Toshiba Satellite A75-S231 Notebook
    Toshiba laptop a75-s209 maximum memory capacit 2.5 mb
    1.5GB total maxium, if I read the toshiba litature,correctly. So the answer is no, you may not. THe BIOS will only be able to read and use the max it was programed to read.
    http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=835414&rpn=PSA70U&modelFilter=A70-S259&selCategory=3&selFamily=1073768663
    Jun 29, 2009 | Toshiba Satellite A75-S209 Notebook
    Adding memory to a a75-s211
    How much memory did it have before you removed the 256Mb RAM?
    If it had 756Mb RAM then the memory in the laptop has 512 Mb plus 256 Mb RAM modules, the 256Mb in the slot you can see and possibly 512Mb in a slot under the keyboard or soldered on the motherboard.
    Therefore by removing the 256Mb and replacing with 1Gb memory module will give you a total of 1.5Gb
    Jun 22, 2009 | Toshiba Satellite A75-S211 Notebook
    RAM increment
    yes just pur chase 1 128 MB or 512 MB or 256 MB ram but check first *********** bord ram module
    check your old 64 Mb ram if it has 1 notch it is ddr1 or ddr2 if it has 2 notch it iks sdram
    then pur chase from shop.
    then fix it on secodn slot
    Apr 24, 2009 | Compaq Presario 5000 PC Desktop
    Toshiba A75-S211 memory
    I'm showing a base memory on that unit of 256 so your max upgrade is 1gb to 1.2gb total.
    1GB (1x1GB) Toshiba Notebook 2.5v PC2700 DDR333 SODIMM
    Apr 14, 2009 | Toshiba Satellite A75-S211 Notebook
    Toshiba A75-S211
    You can do either.
    I suggest that if you want to double your memory capacity is to buy another memory module with the same specs and size as the existing one, preferrably from the same manufacturer.
    Jan 26, 2009 | Toshiba Satellite A75-S211 Notebook
    How do I replace a keyboard on a Toshiba Satellite A75-S211 laptop computer. I cant see any way to get it out. Also, the power button needs to be repositioned... same problem.
    How to take apart Toshiba laptops. Instructions with pics ... 10 posts - Last post: 21 Mar 2006 Toshiba Satellite A70/A75 Toshiba Satellite P25 Toshiba Tecra A1 .... Toshiba Portege 3500 Tablet PC manual. How to remove and replace the ...
    www.thinkcomputers.org/forum/showthread.php?t=632 - 76k -
    Dec 31, 2008 | Toshiba Satellite A75-S211 Notebook
    Toshiba Satellite A75-S211 Notebook Logo
    841 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
