Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
How to locate and clean the mirror on philips projection set
Locating mirror on philips projection set
Remove upper back. The mirror is right there facing down at 45 degree angle to the three projector lenses and the screen. It is a silver polyester film laid over a backing board. I cleaned mine successfully with very soft paper towel (Bounty) and 70% alcohol. Rub gently in small circles until the alcohol is dry. If you just wipe the alcohol across the surface it will dry with a bad white haze. You have to rub it dry and then keep moving on until whole mirror is cleaned. This is only necessary if there are smokers in the house. Cleaning gets the nicotine film off the mirror. Best to not clean if possible.
Posted on Jan 30, 2009
MIRRORS NEED CLEANING
Remove the cover around the front screen...this is the best way to get to the mirror. You may need a service manual if you can't figure it out how to get it off...but in most cases the trim will snap off.
Jun 09, 2012 | Philips Magnavox 51MP392H Rear Projection...
Do I need to clean the screen on a DLP television? I have only changed the bulb. I feel like the picture is getting less sharp.
Not the screen so much as the projection mirror which is located on the rear wall of the Set. If the mirror gets dull it can make the picture dim and dull looking. Cleaning the mirror will help. Some models have a small mirror which projects the image back onto the rear mirror. Dont use windex, just a damp cloth then dry good.
Jul 21, 2011 | LG Televison & Video
51" Philips Projection Wide Screen. Want to know
Almost all the Philips projection sets have a large black plastic shroud on the top half of the back of the set----it can be removed--most of these sets use torks type screws (star shaped).
With the upper part on the back removed you will find the mirror is suspended---do not try to clean it--it is film like handy wrap and will not need cleaning.
I use a swiffer type duster to reach inside the set to remove any spider webs etc, If dead insects or dirt inside the screen use a very soft cloth with water (just dampen the cloth slightly)
Usually you are seeing spider or cob webs and the duster will get them all--DO NOT APPLY FORCE IF YOU WIPE THE INSIDE OF THE SCREEN AS IT IS EASY TO SCRATCH IT!
If this information helped you, rate this solution as I do this here for free.
If you have questions make a comment here and I will do my best to answer them.
REGARDS, SD TECH
Aug 18, 2010 | Philips Magnavox 27MS343S 27" TV
The picture is dull, what i have to do for the TV?
The usual cause of the DLP's geeting dull is the front small projection mirror gets dusty and needs cleaning. The mirror is located dead center in the front after removing the screen assembly. Its a small mirror directly in front of the lens assembly of the light engine.
May 10, 2010 | Mitsubishi WD-62531 Projection Television
Mirror cleaning Philips 60pp9363h-17
dont try to cleen .
this part of the set is in an air tight section of the set
and dosent ever need cleening.
it req compleet disasembly of rear set and removel of the chassis inorder to get to it.
this is not to be done by consumers.
regards,
daniel.
Jan 16, 2009 | Philips 60PP9363 60" Rear Projection...
Philip RPTV
There are a few malfunctions that can cause such.
ONE: Mirrors out of location. But it usually throws the picture off center, also. This can be caused if the set is dropped or kicked badly.
TWO: Out of focus. Can be caused by drift of the circuits or from a malfunction of the video drivers. You can check this by going to the crosshairs and see if the lines are sharp and narrow. If not, then the focus is off badly - most likely the blue gun. You may be able to set the focus and other levels for brightness and contrast and color to optimize this weakness as these are all somewhat interrelated, especially in the extreme settings. You can make adjustments for these above what is available from the OSD by getting into the service mode. See this web site for instructions on how to enter it. http://www.fixyourowntv.com/servicemenu.php
THREE: Worst case is the blue gun or projection tube is failing and needs replaced - which I don't recommend due to the very high cost of doing so.
FOUR: And it is possible the blue gun/tube has been knocked out of alignment by dropping or moving the set.
I favor the focus adjustment as the first remedy to try. You can do that yourself. But if it turns out the mirror is out of location or the blue gun is defective you will need a technician for help on those items.
Nov 13, 2008 | Televison & Video
Philips 64P8341 64 in
Sounds like you need to clean the lenses and reflective area inside your set. It is easy and all you need is a screwdriver, windex and a paper towel. UNPLUG YOUR TV.   Take off your screen and screen protector and safely set them aside.
Clean only the lenses ( glass part) and the reflective mirror type area on the top of the inside of your set.  It will look like new. You need to do this at least once a year.
Aug 03, 2008 | Philips 64P8341 64" Rear Projection...
Wd52525 capacitor replacement
There are 2 mirrors in this set. the small mirror located in front of the lense is the most important. it collects dust and grime.clean it thoroughly.not only will this dull your picture it can also cause small blotches in your pix usually noticed on light colored scenes.
Jun 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Color lights show thru screen
check for loose wires and check that all the connectors are tight.
Jan 09, 2008 | Philips Magnavox 51MP392H Rear Projection...
Picture get blurry on right hand side
if the convergence is also off suspect convergence ic problem
Nov 27, 2007 | Philips 43PP9202 43" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
112 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
