Question about Porcher 41200-00.001 White Archive Two-Piece Elongated Toilet 41200
How do you remove cistern lid - Porcher 41200-00.001 White Archive Two-Piece Elongated Toilet 41200
To remove lid on the cistern Mrs wants to put a loo bleach block in it for fresh flush
Hi,some of these lids open by turning the out side silver ring anty clockwise as it attaches to the pump inside,hope this was some help,all the best.
Feb 26, 2017 | Lid Home
Grohe service
toilet will need syphon replacing. the lid should lift of the cistern, some have the push buttons screwed down to the syphon and to remove them just turn the ring around them anti-clockwise.
Aug 22, 2014 | Home
Toilet keeps on running with water after it is flushed, we used to be able to stop it by pressing the flush button but that no longer works. we have tried running the cold water taps, that only worked a...
ok:) i was with you until you said the cistern (tank lid) was sealed down. what do you mean and can you see anyway to remove the lid because we have to in order to fix the problem:)
Jul 27, 2011 | Home
How do you get the lid of the cistern?
Dear i_mckie224,
Most toilets you will find that the cistern lid should lift off without the need to remove any screws, nuts or bolts. some on the otherhand, such as the Dudley Elite, sometimes has a screw on the top of the cistern that you need to turn in order to remove the lid, but generically, as said, they should either lift or slide off. If you can provide me with more details about the toilet itself, then I will be able to assist you in finding the answer
Yours sincerely
Oz
Feb 28, 2011 | Toto Home
Cant get the lid off a push button cistern
There are some dual flush cisterns where you have to depress one button to reveal a cavity in the second button. Put a screwdriver in that cavity to left out the second button, then release the first button and pry that out.
Underneath the buttons is a screw which must be unscrewed to release the cistern lid.
Not sure if this will apply to you... but if not, good luck anyway.
Feb 01, 2011 | Duravit 0910100005 Happy D Toilet Cistern ...
Cannot remove top of cistern
There are some dual flush cisterns where you have to depress one button to reveal a cavity in the second button. Put a screwdriver in that cavity to lever out the second button, then release the first button and prise that out.
Oct 29, 2009 | Duravit 0910100005 Happy D Toilet Cistern ...
Need instructions and Switch for twyford close coupled cistern
i presume with lid of u can flush toilet by pusshing switch with finger if so buttons must be spot on when replacing lid can be adjusted inside systern any probs get back
May 07, 2009 | Toto CST414M-51 Aquia Dual Flush Close...
Porcher 41200-00.001 White Archive Two-Piece Elongated Toilet 41200 Logo
Top Porcher Home Experts
Donni Steen
 John
John
ray gallant
Are you a Porcher Home Expert? Answer questions, earn points and help others
