Question about Dishwashers
Dishwasher is stuck on the electronic buttons on what looks like a 5hr delay and is locked?? have tried on/off and program button with no luck?
  • Mark Egan May 11, 2010
    Please be more specific with a make and model number.
  • 56 Answers
Kill power to it for a couple of minutes, either in circuit panel or under the botton access panel, sometimes there is an outlet there depending on local electrical codes, trying to reset the board.
Posted on Jan 26, 2009
How do you get the child lock off on a Haier dishwasher?
Just consult the manual. :>)
English
Changing the Wash Program / Cycle:
If at any time during the washing process you would like to change the
selected wash program /cycle;
1. Press and hold the START / RESET button for approximately 3 seconds.
(The START / RESET indicator light will be ON indicating that the unit is
in PAUSE mode.)
2. Select the desired wash program / cycle by pressing the program
button.
3. Press the START / RESET button again, the dishwasher will resume
operation using the newly selected wash program / cycle.
NOTE: If you change the wash program / cycle after the detergent
has been dispensed or the dishwasher has already drained the
water, you will need to refill the detergent dispenser for the newly
selected program / cycle accordingly.
At the End of the Wash Cycle Once the dishwasher has completed the selected wash cycle / program,
there will be a buzzer sound for 8 seconds indicating the end of the cycle.
1. Shut off the water supply.
2. Turn the dishwasher OFF by pressing the ON/OFF button.
3. Open the door slightly with caution to allow any residual steam to
escape.
4. Wait a few minutes (approximately 15 minutes) before unloading the
dishwasher as the dishes and cutlery will be hot. This also aids in the
drying process.
5. The interior of the dishwasher will be wet, this is normal and will dry
naturally.
WARNING: It is dangerous to open the door when dishwasher in
Checking the Water Temperature
For the most effective cleaning and to prevent damage to the dishes being
cleaned, the water supplied to the dishwasher should be at a temperature
of at least 120?F (49?C) and no more than 150?F (66?C).
Child Lock Function
The child lock function will prevent the unit from functioning and the door from being able to open if it is in the fully closed position.
To engage the function, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will illuminate in the display when the child lock function is activated.
To disengage, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will go off in the display when the child lock function is deactivated.
Haier HDC2406TW User Manual At The End Of The Wash Cycle Child Lock...
Jan 31, 2017 | Haier Dishwashers
Delay button stuck on coffee will not brew
Bummer. Pray that this is not a board level (electronic) failure. If you are mechanically inclined and patient, try to disassemble the cover or assembly holding the switch. Hopefully there is a mechanical reason, like a jam or blockage, preventing the switch from working properly. Otherwise, I hope you're under warranty. Good luck.
Aug 21, 2015 | Mr. Coffee JWX27 12-Cup Coffee Maker
My LG Dishwasher is child locked and wont select the cycle to deactivate the child lock. Tried everything but could not deactivate the CL.
Press the "Delay Start" and "Program" buttons simultaneously to deactivate/reactivate the child lock.
Jan 13, 2015 | LG Washing Machines
Purple light is on and cycle won't start
It's possible that you have put the dishwasher into delay mode. Try powering off at the powerpoint as this will force a reset of all programming.
The pause/start button also sets the Delay Start feature which can delay the start of a wash program
from 1 to 12 hours.
To cancel Delay Start
Press the I button.
Dec 30, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have the BE 367 with I button, and wanted to know what kind of Battery is used with it and if i change the battery, will the lock lose its memory or will it stay programmed...
The BE 365 uses a nine-volt battery which, if immediately swapped out with an new one, will not lose the programming. Access it by removing the two screws above and below the thumbturn side.
Replace the battery if there is a delay in unlocking or if the Schlage button is blinking red.
Good luck--and please provide feedback if this helps!
Aug 16, 2011 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
Asko Dryer t760 program menu won't change or is frozen The program menu is stuck on one setting, and the P1, P2, P3, P4 buttons don't change the program. When I try to reset the program (by pressing...
Welcome to FixYa.
By stating "the dryer does work" indicates it is likely an issue with programming.
What are the chances you have the menu lock-out option turned "on"...also referred to as "child lock".
You may quickly rule this out or confirm it is the problem indeed, by trying this.
CHILD-SAFE START
1. Turn the machine off then on.
2. Press ENTER five times, then press P3 five
times. (This must be done within 15 seconds.)
3. “Delayed start” displays with “0” flashing in the
lower right corner. Press the Right Arrow button
to toggle the display to “3.”
**NOTE: Child-Safe Menu Button**
Please note that when you set the child-safe Start
button, the Menu button is automatically
programmed to delay for three seconds before it
becomes active. This prevents a child from
accidentally changing the program settings.
When you want to change a program, press the Menu
button for three seconds to activate the menus. The
Menu button will work normally (without the
three-second delay) until you have completed your
changes. If it is not pressed for two minutes, it will
automatically revert back to the child-safe mode.
Let me know if this indeed solves the problem but either way please keep me posted.
Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Sep 18, 2010 | Asko T761 Electric Dryer
Lock Light Blinking
silly question but did you try holding the control lock button(perhaps its the heated dry button) in for 3 secs???? sonds as if the CONTROL LOCK has benn activated( child lockout)
Jan 14, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
ESL 63010 will not start program
does your dishwasher have a timer button on it? sounds like the switch behind the button needs to be replaced.
Sep 13, 2008 | Dishwashers
None of the Wash Cycles are Working
It's probably the touchpad - commonly used buttons quit working after a while. If not, then it's the electronic control board.
Mar 09, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
Dishwashers Logo
91 people viewed this question
Top Dishwashers Experts
