Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Ice and water dispenser
My ice and water dispenser are working fine but the area under the pull out tray(where you would put a glass to fill) is hot. We have just noticed it over the past week
    Scholar:
  • 146 Answers
Some companies have installed a small heater that keeps the water lines from freezing. If you notice there are a lot of problems with side-by-sides and not water to the dispenser. Companies try different ways to correct the problem. I know Whirlpool has installed a heater behind the ice maker drop that keeps ice from forming in the chute. This is more than likely what you are experiencing. Freezers also have a self-defrost that comes on every 8 to 12 hours that can cause a warm condition. If it is not causing a problem I wouldn't worry about it.
Posted on Dec 26, 2007
SOURCE:
My Kenmore Elite frige model 106.5779*703. Door ice dispenser is not dispensing whenever glass is used. The sound of the motor is running but no ice comes out. Cleaned caked ice from bin. not working
EDITED OK! I found THIS:
"This dispenser ice chute door and motor assembly opens to let ice through when dispensing into a glass or other container. The assembly may include multiple parts; refer to your parts diagram for a complete list of parts included."
I SEE that assembly, it's motor AND associated gears for the FLAP!
You can hear the motor so I suspect the mechanics next. Could be the gear from the motor shaft is loose or worn?
https://www.ebay.com/i/192508879235?chn=ps
Please know this MAY NOT be your specific part! But the photo is very useful!
Ahaaa! Check the tray "water fill tube"! It's usually rubber and the insides sometimes FREEZES and BLOCKS with ice!
ALSO, I've seen similar problems when the WATER FILTER is too old! Internally it's compacted and blocked so water flow is restricted... SO as the tray TRIES to fill, the water just dribbles into the tray then freezes in the fill tube ~ rather then a true FILL/STOP action.
Anthony
May 20, 2018 | Kenmore Refrigerators
Water leaking from Icemaker fill tube near the back wall
It probably is not the water valve. More likely it is the ice maker itself. Nothing else in the machine controls the flow of water to the ice maker except the ice maker itself. It is recommended that both the ice maker and the water valve needs to be replaced when trouble such as this.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 12, 2012 | Refrigerators
I have a kitchenaid 23cd.Icemaker doesn't work has 40# water pressure 5 deg in freezer water works to fill glass no water in ice tray unpluged for 24 hours
If the water dispenser is working and fill glass function is working but the ice maker section there is no water in the tray then its faulty ice maker valve.This is a twin valve.The valve is one unit,but has two sections one for water and one for ice dispenser.This valve is got faulty and not working for both sections so water is not entering the ice maker tray.
There is a water valve at the back of the ice maker.This valve controls the flow of water in the ice maker chamber.If this valve is not functioning as required then water will not enter the ice maker.This valve is at the back of ice maker connected to the water fill tube.It has to be replaced to clear this problem.
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Feb 01, 2011 | Refrigerators
Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool Side by Side Bad Water Taste
Most "new" fridges with water dispensers and ice instruct the consumer in there manuals to "bleed" the reservoir by running a couple of large pictures of water thru it. I usually recommend dumping the first few harvest's of ice as well (I believe this is also mentioned in most manuals too). once that is done the water should be fine as any contaminants in the system/reservoir should be gone. you may try changing the filter after this, but it shouldn't be necessary. most ice makers do not have there supply water travel thru the water dispenser reservoir however. the water filling the ice tray should have no baring on the water you dispense into a glass to consume.
hope that helps.
good luck
Sep 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water leaking through ice maker
check out the temperature inside of the freezer your probebl going to have to clean the condenser coiul underneith the unit
May 23, 2009 | Whirlpool ES5FHAXS Side by Side...
Just installed ice maker cords, no water filling ice trays
Hi make sure that the arm on the ice maker is in the down posistion as it will only put water in the ice maker in this posistion. It will take a little time to fill so be patient as the timer in the front on the ice maker needs to cycle first. Make sure you have connected it all correctly to...
Dec 29, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice Dispenser Doesn't work...
sounds like the water coming into the icemaker is spilling over or leaking into the ice despenser bucket.... check for ice build up or plugging of water chut into ice maker
Aug 08, 2007 | Whirlpool GS6NBEXR Side by Side...
Rs21dcns
there is a double valve at the back bottom lhs. check continuity of both valve coils but doubtfull this is the problem. the fault may be that the filling tube is frozen. try looking in this area
Jun 11, 2007 | Samsung RS2630SH Side by Side Refrigerator
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
105 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Paul Carew
Lawrence Oravetz
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
