Question about HEWLETT-PACKARD Hewlett Packard Photosmart eAllinOne D110a AllInOne InkJet Printer
Paper doesn't feed through the printer - HEWLETT-PACKARD Hewlett Packard Photosmart eAllinOne D110a AllInOne InkJet Printer
    New Friend:
  • 110 Answers
Please click Out of Paper Error Message and the Printer Does Not Pick Up or Feed... to access steps that should resolve the issue.
Posted on Jun 28, 2014
Canon ip4300 manual
hello,maybe the paper feed is jammed try to see if it has something that stops the paper to go in and if you are asking for the service manual for the ip4300 printer you can download it from the below link:
http://goo.gl/ZYxxU
Good luck
May 25, 2013 | Canon PIXMA iP4300 InkJet Photo Printer
Doesn't feed paper....shows "P" on screen.
Verify and clean the paper feed rollers and the paper fee drive mechanism.
Feb 15, 2013 | Canon NP 7130 Black and White Copier
Paper jam but no paper is jamed in printer
I have had this issue before. I hope this helps you. Try these steps:
1) Open the the top cover; then close it..read the message on the screen. If it doesn't resolve..
2) Remove paper and insert a fresh stack of paper. Making sure that edges are smooth..no creases or wrinkles.
3) Open paper feed area. If you have pipe cleaners available, clean each opening. You can use the fine hose attachment from a vacuum to do the same thing, if needed. Proceed to close the paper feed compartment..read the message on the screen. If it doesn't resolve..
3) Turn off the printer for a few minutes; then power it back on. Printers 'read or sense' the paper as the printing job occurs. Even the smallest shred of paper can cause the printer to identify it as a paper jam
I hope this helped you.
Apr 02, 2012 | OKI C3530N Color MFP Printer
ADF wont feed the paper through the printer
You can load up to 30 sheets of plain paper in the Artisan 800 ADF. If the ADF doesn't feed the paper, check the following.
1. Make sure that you are loading plain paper only without a holes. 3-hole punched paper is not supported by this printer.
2. Load paper not exceed 30 sheets.
3. Open the ADF and check for any jammed paper or foreign object that is blocking the paper feeding path.
4. Check if the BIG GREEN ADF indicator is lit when you load paper in the ADF.
If the issue persists, your printer will require service. You can contact the Epson for warranty if your printer still under warranty. If your warranty expires, look for an a service center that can repair your printer.
Oct 29, 2011 | Epson Artisan 800 All-In-One InkJet...
My Epson 1400 wont pull the paper through when I hit the print button. But when I insert a sheet of photo paper and hit outside printer button it will pull thepaper through but wont print
Hi
First off, the simplest solution is to try to clean the rollers of dust. If you can access the rollers, especially while they are spinning, this would be best. Get a damp cloth either with water or rubbing alcohol and wipe the rubber down, and retest your machine. Most of the time this is cause by the paper pickup rollers, which are made out of plastic or rubber, getting too dirty/slick to properly pick up the paper. Remove all the paper and the paper tray if you can. Using a long qtip, clean the rollers with alcohol. If that doesn't work, or can't be done with your printer, take all the paper out but one sheet. Spritz some alcohol on the bottom of that sheet and smear it out so it covers the entire width of the paper up about 2 inches. Then try to print a document that is a blank page. After either of these methods wait at least 4-5 minutes for all the alcohol to dry before trying to print again.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 15, 2011 | Office Equipment & Supplies
PAPER DOESN'T FEED THROUGH
check on the panel of the printer if the selected paper tray is the lower tray or the upper tray put paper on both tray mark the paper so you can see which tray is being feed,
Aug 04, 2011 | Canon LaserCLASS Fax 710 Printer
Paper jam
Restart the printer so the paper that is jammed will be feed out from the printer if this doesn't work. Remove the paper that is jammed inside your printer by pulling the paper manually and restart again the printer.
Jul 02, 2011 | Office Equipment & Supplies
Paper won't feed from both tray and manual feed tray...motor starts, attempts to grab paper, but doesn't
THERE IS TWO REASONS. PICKUP SENSOR PROBLEM OR IN THE FIXING UNIT HEATER SECTION PROBLEM. SOMETIMES HEATING ELEMENT BURNED. CHECK THE BOTH ITEMS .
Jun 18, 2011 | HP Office Equipment & Supplies
The printer won't feed the paper in properly. It turns crooked and then doesn't load in. Printer thinks there is either no paper or a jam. Can see anything physically in the way blocking the...
Hi Trevo
First, check the the paper guide in the feed tray is up against the edge of the paper. If it is not snug then the paper will skew.
If it is OK then check with a torch both sides of the paper path - where it goes in and where it comes out.
I've found bits in the path before now that are not seen at first.
This printer may have a removeable panel at the back where you can check a bit more easily.
May 25, 2011 | Canon PIXMA MP600 all-In-One InkJet...
HEWLETT-PACKARD Hewlett Packard Photosmart eAllinOne D110a AllInOne InkJet Printer Logo
73 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Victorman
Victorman
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
