Question about GE Profile WPRE6100G Top Load Washer
New hook up for drain on a GE WBB4500GOWW.
This top load washing machine came with out a drain hose. The drain outlet is just a flat rubber hole, as if a female instead of the usual male connection. I don't see how to secure the old drain hose???
  • Anonymous Feb 28, 2009
    what is the fix? I need an adapter to get the hose on.
  • Thomas Malailua
    Thomas Malailua May 11, 2010
    i cant see what your seeing but you need to get a new drain hose connected to the pump.the front comes off at the top crease with a putty knife pushing in on the rt/lt end of the front pannel
    Scholar:
  • 42 Answers
On some models, their is a female drain hose that you can purchase from your local appliance parts dealer that should be inserted only. Not your traditional clamp type. Runs about $9 dollars or so and tycally has a triangle collar that is connected along with the drain hose. Does this help?
Posted on Jan 26, 2009
Water can't out from macshine went i want to wash
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Jun 21, 2011 | LG WFT1071TP Top Load Washer
New washr leaking from drain hose what do I do
The hoses are not hooked up right ...
Here is a tip that tells you how to fix that problem...
Water will not stay in Washing Machine
heatman101
Oct 10, 2010 | GE WBSR3140DW Top Load Washer
No spinning and no draining and i get code e20
  • Get the washer laying on it's side and using the access hole on the bottom carefully remove the screw clamp holding the large hole of the rubber housing to the tub drain (it will be obvious all other clips are green compression clips).
  • Carefully work the strainer out of this flexible rubber drain housing through the large hole.Clean it out and replace you will be good to go. Also remove all the hoses and check for a buildup of gunk. Hope this will fix your problem.
Thank you!!
May 19, 2010 | Frigidaire ATF6000ES Front Load Washer
NEED TO KNOW HOW TO INSTALL DARIN HOSE
Washer should come with a drain hose, which is just inserted into the hole at the bottom of the back side of the machine, and held in place with two screws (about #8 x one inch long screws) Make sure the pipe the outlet of the drain hose goes into is at least 30 inches above the floor and is not sealed to the hose.
Apr 01, 2010 | GE WBB4500EWW Top Load Washer
Waher will fill with water and then drain it out
Your drain hose is too low or there is no air gap at the drain outlet where the drain hose enters the wall.
Mar 26, 2009 | GE WBSR3140DW Top Load Washer
Why does my washing machine have 2 drain outlets?
This is a water saver or previously known as a suds saver model. The bottom one is the drain. The top one would go to a suds tub. If you set the machine on save, the wash water is pumped out of the top hose into the holding sink next to the washer. The rinse water goes out the bottom hose to the drain. The next cycle you could set the washer to the very beginning of the main wash cycle and the washer would pump the water from the tub back into the washer to be used as wash water for the second load of laundry. Yea, used water. But the first load would be lightly soiled stuff, and the next load would be old barn clothes or play clothes. It was designed to save water (about 65 gallons used for 2 loads vs. 90 gallons) and soap. (now, front load machines with larger tubs would use as little as 25 gallons for two loads.) Just hook up the bottom hose to the drain. Leave the save / drain switch set to drain and you'll be fine. To be extra safe (in case the switch was accidentally set to save) disconnect the wires at the solenoid where the drain hose splits into two at the back bottom of the washer. (right where the hoses exit the machine.)
Oct 15, 2008 | Washing Machines
Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Apr 22, 2008 | GE WBSR3140DW Top Load Washer
GE Washer won't drain or spin
this is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
No connection for discharge hose
WH41X374 is the part number you will need to purchase. This part is 34.30 from Marcone.com. Check www.partstoday.com for more pricing and availability or ask around a local parts dealer.
Apr 16, 2008 | GE WDSR2080D Top Load Washer
GE Profile WPRE6100G Top Load Washer Logo
133 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
