Question about Bosch SHU5315UC Dishwasher
Not cleaning dishes
Our Bosch dishwasher, model shu531uc is not cleaning dishes properly. We think there may be a problem with the dish detergent dispenser. There is often food and grime left on dishes.
    President:
  • 1,214 Answers
Our Bosch does a pretty good job of washing dishes. But we rinse most of the time. Not a hard rinse, but a rinse.
Are both spray bars rotating? You can test by seeing that the bars rotate easily by hand, and also by starting a cycle and opening the door real quick when you hear the spray hit the door.
Make sure the spray bar nozzles are all clear.
Has it ever done a good job of cleaning dishes?
DI you leave a heavy build-up of food on the dishes, and allow it to dry before washing?
Posted on Jan 26, 2009
Detergent lid opens, but undissolved detergent streaks down door and dishes aren't clean.
5 results (0.58 seconds) Search Results
    Support - Dishwashers DW80F600UTS/AA ' Samsung ...
    www.samsung.com > Home > Support > Dishwashers
    Samsung ElectronicsVisit Samsung today for DW80F600UTS Top Control Dishwasher with Stainless Steel Tub (Stainless Steel). You'll find product and support information for our ...Missing: black ‎undissolved ‎streaks
    Dishes still dirty - dishwasher ' Ask MetaFilter
    ask.metafilter.com/145865/Dishes-still-dirty
    Feb 13, 2010 - If they use dry dishwasher detergent, some of the undissolved dishwasher ... (part of the pump of the dishwasher) breaking down or some piece ofblack plastic (often a ... Every single dishwasher I've ever worked on had a built inwater heating element. ... That's all we use and never get spots on our dishes.Missing: samsung ‎dw80f600
Jan 19, 2016 | Samsung DW80F600 24" Black Built-In...
Dishwasher not cleaning dishes
DISHWASHER NOT CLEANING WELL??
Here are 5 common reasons why not.
Here are Improper Water Temperature
I can tell you from personal experience that water temperature has a direct impact on how well your family's dishwasher operates. If the water entering your dishwasher is not hot enough, your dishes are likely to come out coated with grease and dish detergent residue. As such, you will want to make sure that the temperature of the water inside your dishwasher is somewhere between the range of 120 degrees Fahrenheit and 140 degrees Fahrenheit. If it's not it could be a faulty heating element.
Dirty Pump
Based on my experience, a dirty dishwasher pump will also cause your dishwasher to produce less than stellar results. Therefore, you may want to consider cleaning your dishwasher's pump every six months. In many instances, it is an easy task to complete. In order to clean your dishwasher's pump, you'll most likely have to remove the dishwasher's spray arms. Once the spray arms are removed, you'll want to clean and inspect the pump's impellers, blades and pump guard. I should also mention that there are appliance companies that sell dishwasher pump repair kits should you notice that a part needs to be replaced. A basic dishwasher pump repair kit will tend to cost you $20 to $60 depending on your dishwasher's unique needs.
Dirty Spray Arm
Dirty spray arms may also be to blame. After all, if the spray arms' holes are clogged, the hot water won't be able to reach the dishes properly. A dishwasher's spray arms are very simple to clean. In order to clean them, you will need an old toothbrush and a bread twist tie that has been stripped of its paper. Use the toothbrush's bristles and the wire from the bread twist tie to unclog all the holes.
Broken Dish Detergent Dispenser
A broken dish detergent dispenser is another likely culprit when it comes to dish cleanliness problems. Sometimes the dish detergent dispenser's door will not open or shut properly, which prevents the dishes from getting nice and soapy. The good news is that most dish detergent dispenser problems may be solved relatively inexpensively. The cost of a replacement dish detergent dispenser will vary based on the make and model of your dishwasher. There are also instructional videos online that will help you with the installation of your dishwasher's new detergent dispenser.
Dirty Filter
A filter has an impact on a dishwasher's effectiveness as well. Hence, you will want to inspect your dishwasher's filter for obstructions. The location and type of filter will vary based on your dishwasher's make and model. I would recommend that you check out your dishwasher's operator's manual. It should contain instructions on how to clean your particular unit's filter as well as where you can order a replacement part if need be.
Dec 16, 2013 | Dishwashers
Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
Instructions Things You'll Need:
  • Vinegar or lemon juice
  • Gel dishwasher detergent
  1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
  2. Rinse aid in solid form
    Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
  3. Vinegar or lemon juice
    Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
    After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
  4. Gel dishwasher detergent
    Switch to a liquid or gel dishwasher detergent. Any brand will do.
  5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
    Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
Feb 02, 2011 | Dishwashers
My Asko D1976 dishwasher is not cleaning dishes properly. There is a lot of clumped detergent left in the dispenser after wash cycles are complete, and many of the dishes have dried-on food left on them. ...
First of all, don't pre-rinse the dishes. Check the water temperature, it should be between 120 and 140 degrees. Be sure you are not partially blocking the dispenser door so that it isn't opening.
Sep 18, 2010 | Asko D1976 Built-in Dishwasher
Residue on dishes/glasses - Hard water? How to clean?
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Mar 01, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Our shu66c05uc Bosch dishwasher does not dispense the detergent.
Most likely the solenoid that operates the lever on the detergent door is faulty. Only solution is to replace the whole dispenser, unfortunately. It is possible that the controller is not activating the dispenser but less likely.
Jul 21, 2009 | Dishwashers
Dirty dishes
If you have a water softener, you should use about half the recommended amount of soap. Never use a wet or paste detergent. As mentioned before, this unit should be under warranty.
Gene, in AZ
May 24, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch diswasher detergent dispenser doesn't open during wash cycl
I've been told we can replace the dispenser. See AppliancePartsPro.com. Part AP2834000
Dec 24, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Detergent trouble
hi there,
sounds like the detergent dispenser is not working properly.
are the rest of your dishes clean? in other words, is there any food residue on them?
check the dispenser and make sure that there is nothing visibly wrong with it.
if the problem still persists, replace the dispenser.
Mar 11, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Bosch SHU5315UC Dishwasher Logo
545 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
