Question about Chass Jumbo Jet Mini Clock
How to replace a battery for a chass miniature clock?
  • joycedevore
    joycedevore May 02, 2013
    I cannot get the face frame off my chass clock!
  • Anonymous Aug 24, 2017
    Looking at the back, put the crown (where you adjust the time) at the top (call that 12 o'clock). At 3 o'clock there's a tiny indentation on the ring that you could get a thumbnail into, or better a very small screwdriver into. Lever that spot, and the bezel will pop off.
    Top Expert:
  • Chass Master
  • 23,236 Answers
Use a plastic blade to avoid scratching!
Posted on Aug 24, 2017
Battery cover is stuck-can't remove to replace battery.Tried small screwdriver to no availe-will not fit into top
A "dollar store" set of miniature screwdrivers will have what you need, although I often find the only one that fits is the smallest.
Apr 13, 2017 | Watches
What is the battery replacement # for a pulsar n944 6a00 ?
BATTERY CHANGE The miniature battery SEIKO SR927W which powers your watch should last approximately 2 years. However, because the battery is inserted at the factory, its actual life once in your possession may be less than the specified period.
Mar 24, 2016 | Pulsar Watches
How to change battery
Either the remote control is regular size or miniature like the remotes for cars. The only real difference is the type and size batteries it uses. The regular size remotes usually use 1 or 2 "AA" or "AAA" batteries, or occasionally, a 9 volt battery. The miniature remotes take "button" batteries that are available at Radio Shack or the big-chain drug stores like CVS. Whether the batteries are the regular type or miniature here's what you do: On the back side of the remote there will most likely be a small phillips-style screw in the middle. Remove this screw and then you will be able to open the battery compartment door. Write down or take pictures (better) of how the batteries are configured and note this as you remove the old batteries. Radio Shack has a battery tester. If ALL the batteries are still good, then the remote is defective. If ALL the batteries are dead or very weak, then most-likely the remote is working fine & will come right back to life. Enjoy!
Jun 10, 2014 | Sanyo RCS-SH1UA Wireless Remote Control
Replace ribbon cable going lcd compaq presario screen
Please replace it with a brand new flex cable. Please post the "4 tiles miniature screen".
Feb 12, 2014 | Computers & Internet
Boot warning chassis opened
disable the chasses intrution detection in bios setup.
Dec 23, 2013 | Acer POWER APS290-UC4201P MT CELERON M 420...
How to replace power supply
unscrew the screws on the back and open the chass. then draw a map about the connections where those power cables went into inside the chass. then unplug all the power connections and unscrew the screws on the back which fasten the power supply to the chass. remove other components if necessary to alow space for the power to come out. then replace the power and anything else in reverse order and reconnect the power cables according to the map.
Mar 02, 2012 | Acer L410G PHM19 3GB 160GBDVDR X1250...
New battery?
Yes. It takes a Rechargeable Li-polymer 280mAh
battery. Just unscrew the back carefully with a miniature Phillips-head screwdriver and replace.
Mar 01, 2009 | Philips GoGear SA178 MP3 Player
Fuel problem
I drive that car every day and have been chassing this problem for a long time. Check the ground strap from the battery to the gear box below the battery left side - clean it real well and keep it well tight. While you are it do the same battery ground strap to the body near the battery. Scratch off the paint where the strap seats...
How does you idle sound: smooth and a bit high or jurky and a bit slow? This is caused by the fuel pump surging for its 5Amps due to ground strap above.
I too was getting misfirings from these Coil Over Plugs (COP) so at one point I decided to over drive them under 17VDC. I was getting better spark all right but it was still not perfect the problem was the mixture.
Check that your TPS reads 600mV +/-2mV at idle. I had my throttle body replaced by Acura because the gas pedal what sticky and the replacement was factory misadjusted big time. Take a quick look: the TPS adjustement screws need to be about in the center of the slot. Search under my ID I have made some postings that will help cure driveability issues with our cars.
Like you I was chassing my tail for a while swaping parts (fuel pump, fuel filter, fuel pressure regulator, COP, MAP and O2 sensor...) until I became real familiar with the darn ECM behaviors. THE CLs INJECTION IS REALLY SENSITIVE and quick to detune the engine to keep emissions low.
Jan 08, 2009 | 2001 Acura 3.2CL
Car radio clock
YOU NEED TO REPLACE THE MINIATURE BULB THAT LITES UP THE DISPLAY, YOU WILL HAVE TO REMOVE THE RADIO FROM THE CAR AND THEN REMOVE THE TOP SHEET METAL COVER ON THE RADIO, YOU WILL SEE THE BULB SOCKET PLUGGED INTO THE BACK OF THE DISPLAY.
Aug 21, 2008 | 2003 Pontiac Grand Am
Chass Jumbo Jet Mini Clock Logo
95 people viewed this question
Top Chass Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Chass Office Equipment and Supply Expert? Answer questions, earn points and help others
