Question about Bosch Classixx KGV28323 Bottom Freezer Refrigerator
BOSCH CLASSIX FROST FREE KGU 30605GB PROBLEMS
RED EXCLAMATION LIGHT ON AND FRIDGE AND FREEZER WON'T WORK
SOURCE: Freezer not working
same problem but electronic temperture on in fridge but keeps flashing
Posted on Jul 20, 2008
SOURCE: Bosch Classixx Frost Free KGU34640GB/06
the freezer is not defrosting at all .How to defrost it ?
Posted on Aug 01, 2008
  • 9 Answers
SOURCE: Bosch fridge not cooling freezer fine
if back wall of freezer has ice or thick build up you may have a defrost problem or if not the evaporator fan motor could be bad, not moving cold air from freezer to refrigerator.
Posted on Mar 14, 2009
SOURCE: bosch intelligent frost free 40
The small drain pipe on the back of the fridge gets clogged, hence no drainage when defrosting, hence ice blocks the airflow between the freezer compartment and the fridge compartment.
Remove the rubber stop from the drain pipe and clean (can be found above the motor)
Defrost the fridge for a few days (it takes at least 48 hours). During this time, if you are not brave enough to remove the internal panels of the freezer and continually clean the water, check for water coming out and clean.
If during the defrost there is no water coming out the drain pipe, use about 2m of flexible and strong wire to clean the pipe.
The aim is to unblock the pipe once the ice has melted.
Posted on May 12, 2009
Illeagle
  • 525 Answers
SOURCE: How to use temperature settings on Bosch Classixx fridge freezer
You can find most user manauls at, www.managemyhome.com, on the right side of the page. You will need the model number off the product information label affixed to the unit.
Posted on Jul 05, 2009
Bosch KGU 34640 freezer not cold enough
I had a similar problem a couple years back with my freezer. Behind the vent cover in the back there were a few lines that ran the cooling or something like that. What happened was my freezer was icing up horribly. I was told to take that panel off and check those lines. Sure enough one of the lines was busted through. That was why my freezer was having problems. I apoligize I don't know anything about the front buttons tho.
Dec 28, 2013 | Bosch Refrigerators
Hi, I have a Bosch Logixx Fridge/Freezer (frost free), works fine apart from large build up of ice on floor of freezer which I constantly have to remove. Any ideas? Many thanks Peter
Hello
check that it defrost elements (heater elements) are working if they working then check if the sensor is working and if the door is sealing when its closed or if the drain is open.
Thanks
Jun 04, 2011 | Freezers
Mar 14, 2009 | Bosch Refrigerators
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
Frost free fridge freezer has build up of ice at bottom of freezer section. i have defrosted many times but problem remains. model KGU 34620/07 Can you help
yes,
you have a defrost problem, three things..
one, defrost heater could be bad,
two, bi-metal could be bad,
and three, the timer could be bad.
any of these three items getting bad would result to one symptom.
ice buid up at the bottom of freezer section.
tnx 4 using fixya,
drcool
Aug 26, 2008 | Bosch Refrigerators
KGU 34641 GB TOP REFRIGERATOR
Hi,I believe you may have a blockage in the intake from the freezer to the fridge as cold air is blown up from the freezer to make the fridge coldhope this helps,mike,
Aug 10, 2008 | Bosch KGU34641 Bottom Freezer Refrigerator
Freezer not working
Jun 17, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch Classixx KGV28323 Bottom Freezer Refrigerator Logo
26 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
