Question about HP PhotoSmart 7550 InkJet Printer
Need instructions for changing color cartridge
Borrowing use of this printer and need to replace the #57 tri-color cartridge. Don't have manual. Can you help?
    President:
  • 1,901 Answers
Here is a link to HP support:
7550 Ink Replacement
Posted on Jan 26, 2009
  • Wayne Mineard
    Wayne Mineard Jan 26, 2009
    Here is a link to the Setup Guide that may give you some more help:
    7550 Setup
Ican't align print cartridges .I change the color cartridge (57) and now when i start the printer i receive a message "Press OK to print Allign page" . The printer start the operation and...
Your color cartridge does n't print well
in order to have a success alignement
check if the expire date has pass
you need to replace the color cartridge or refill it
by this easy method
Jan 17, 2011 | HP PSC 2410 All-In-One InkJet Printer
What is the print cartridge number
HP Deskjet 5150 Printer uses HP 56 ( Black ) and HP 57 ( Tri color ) Cartridges.
HP Black cost you $23.99 and HP Tri-color cost you $39.99
Click on the link below for more information about cartridges.
Cartridge Information
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 16, 2010 | HP DeskJet 5150 InkJet Printer
HP 6110 won,t print. After initializing, I get error messaage to REMOVE AND CHECK CARTRIDGE. and AFTER CHANGING 56 AND 57 CARTRIDGES many times, still doesn't print.. I ve spent 3 hours trying to navigate...
Hi
your cartridges are not good any more
and need to be replaced
Remove and replace your cartridges
try old ones to see if color or black has the problem
Hope I help you
if i did pls vote me
Oct 13, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Lexmark z2300 eplacing ink cartridges
Go to www.lexmarkz2300.com. There will be instruction on how to replace the cartidges. you will b e able to print out the instructions after you fix the problem.
May 21, 2009 | Lexmark Z2300 InkJet Printer
Printer message align print cartridges,won't print color
You must replace both ink cartridges to get a sucessful alignment.
Jan 04, 2009 | HP PSC 2175 All-In-One InkJet Printer
We are having a hard time adjusting the color on our hp 7660. Color is coming out purplish. We just installed brand new HP 57 and HP 58 cartridges
We found out that the HP 57 cartridge was expired (it had come with the printer when we bought it from someone). We replaced the HP 57 newly purchased cartridge and it works perfect now.
Dec 06, 2008 | Office Equipment & Supplies
Ink cartridges
Click on this link for cartridge installation instructions. There is also an animation link on this page.
PSC2210 Ink Cartridge Install
Make sure you use #56 (Black) and #57 (Tri-color) cartridges.
Nov 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
I haven't the manual for this printer color laserJet 2600n series,
HP Color LaserJet 2600n Printer - Installing Print Cartridges When a print cartridge approaches the end of useful life, the control panel displays a message recommending that to order a replacement. The printer can continue to print using the current print cartridge until the control panel displays a message instructing to replace the cartridge. The printer uses four colors and has a different print cartridge for each color: black (K), cyan (C), magenta (M), and yellow (Y). Replace a print cartridge when the printer control panel displays one of the following messages: Replace yellow cartridge, Replace magenta cartridge, Replace cyan cartridge, Replace black cartridge. The control panel display also indicates the color that should be replaced (unless a genuine HP cartridge is not currently installed). Change the print cartridge
  1. Turn off the printer.
  2. Open the front door. c00315320.gif CAUTION: Do not place anything on the transfer belt (ETB), which is located on the inside of the front door.
  4. Remove the new print cartridge from the bag. Place the used print cartridge in the bag for recycling. c00315322.gif
  5. Grasp both sides of the print cartridge by the blue handles and distribute the toner by gently rocking the print cartridge from front to back. CAUTION: Do not touch the shutter or the surface of the roller. c00315323.gif
  6. Remove the orange shipping locks and the orange shipping tape from the new print cartridge. Discard the shipping tape and shipping locks according to local regulations. c00315324.gif
  7. Align the print cartridge with the tracks inside the printer, and using the handles, insert the print cartridge until it is firmly seated. c00315325.gif
  9. Turn on the printer. After a short time, the control panel should display Ready.
    NOTE: If a cartridge is in the wrong slot or is the wrong type for the printer, the control panel will display one of the following messages: Incorrect yellow, Incorrect magenta, Incorrect cyan, Incorrect black.
  10. Installation is complete. Place the used print cartridge in the box in which the new cartridge arrived. See the enclosed recycling guide for recycling instructions.
  11. If a non-HP print cartridge is in the printer, check the printer control panel for further instructions.
    NOTE: When replacing or changing a black print cartridge, a cleaning page will automatically print. This helps prevent speckles on the front or back of printed documents. A cleaning page can also be generated using the control panel or the HP Toolbox.
Nov 03, 2008 | HP Color LaserJet 2600n Printer
Color Cartridge Failure
You know, I'm not going to read the other solution. I know 100% FOR SURE, when a cartridge fails, it is dead and there is nothing you can do about it, but there is a good side. HP ink cartridges have a year warranty. Call them and tell them it failed, they'll send you a new one!
Sep 18, 2007 | HP PhotoSmart 7760 InkJet Printer
HP PhotoSmart 7550 InkJet Printer Logo
48 people viewed this question
Seeker5211
Seeker5211
