Question about Frigidaire ATF6000ES Front Load Washer
Whirpool dishwasher Dishwasher is about 7 years old. I have this black stuff all over the bottom, sides and door. I have clean the stuff numberous times, and it just come back in less thatn a week, Can it be repaired or Do I need to get a new one I have a fridgedair dishwasher that's not even a year old and there's black, waxy stuff at the bottom. It gets on the plastic dishes and smears when touched. What the heck is it? How do i get rid of it?
  • kristenabbou Jan 26, 2009
    The black stuff doesn't get on our glass dishes only the plastic plates my kids use. I use regular dish detergent, it's called seventh generation. I heard that it could be coming from the sink so I am going to try drain cleaner so hopefully it will go away.
    President:
  • 1,214 Answers
Ours does the same thing. I have been suspicious that it is the melting plastic stuff used in the dishwasher tabs that the wife uses.
Let me know if you use that same tab to wash you dishes.
We dont have any problem with the stuff getting on dishes (and we use all white diner type dishes.).
Posted on Jan 26, 2009
Older Whirlpool dishwasher dp840cwdbs not fully draining.
Hello, unfortunately we are not trained to give repair information but we would suggest having a certified technician out to diagnose the problem that you are experiencing. If you would like further assistance you can send us your name, phone number, address, model/serial number and the date on which you purchased the Dishwasher to Whirlpool_Reviews@Whirpool.com.
Apr 17, 2017 | Whirlpool Dishwashers
Black mold in broken Dishwasher
bleach is always good i suggest you cover the dishwasher with a good plastic film after you spay it with bleach to keep the mould inside it till you can remove it
Dec 17, 2009 | Dishwashers
Leaking at the bottom of a GE dishwasher
If it's under a year old, it's under warranty, just call 1-800-GECARES and they'll send someone out to replace the door gasket. If it is over a year old, you need to replace the door gasket. There are small black lines that extend beneath the door into the body of the dishwasher that will be replaced when you install the new gasket. This will seal the door so that you no longer have anymore leaks.
Jul 11, 2009 | GE Dishwashers
Usermanual for old ADMIRAL dishwasher model number BDUR 41400
right. first of all there are usually three settings one is intence 2 is normal and three is pans. or the other way round. cannot remember. but put nothing in and turn it on by closing the door. turning the knob and pressing the start button when selection is made if no button to start it just select a program and see which one lasts the longest thats the pan one. use dishwasher tables either in the little basket hanging in there or in the door there is a slide thing. put tablet in there and fiddle till it stays shut. then close the door. after loading with stuff. at the bottom will be an unscrewable white knob put some dishwasher salts in there every few months. it keeps the water soft. there is also a filter in the bottom you can lift out to clean a round thing within a mesh grid. that must be reg checked for bits of dinner and stuff. try and get the bets off first. dont put beans and things left on plates and pans in cloggs up. try contacting supplyer for instruction manual. if you cannot thats all you need to know really. hope that helps. liz
Mar 24, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher is leaking
Gasket probably became dislodged, replace door gaskets, at 4 years old I would replace the gaskets, they are not expensive.
Feb 17, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher leaking
There is a front door seal that may be the issue. It seals along the door sides/top and continues under the door to seal the bottom surface when closed. Mine pulled out of the seal channel under the open door where you can't see it without a small mirror. The seal took a "fixed set" out of the channel so now it will not stay put. It requires replacement.
Hope this helps.
Jan 26, 2009 | GE Nautilus 24" Built-in Dishwasher
Bosch dishwasher approx 14 years old
modek no is usually on a label on side of door or etched in on side or top of door.
black staining not due to heater but possibly from rubber door seals
Nov 20, 2008 | Bosch Dishwashers
Black stuff in the bottom of the dishwasher
That black or gray stuff you're talking about is actually a combination of old food particles and soap deposits. The stuff builds up in the corners of the lower front areas of the tub and right under the inside of the door where it closes over the tub front. These areas can develop "scungy" deposits because these are areas that the dishwasher doesn't always clean and/or water remains pooled. A little routine cleaning about once a week around the bottom lip of the door and the door gasket with a damp sponge will prevent this build up. Hope this helps you.
May 11, 2007 | Whirlpool 24 in. DU920PW Built-In...
Frigidaire ATF6000ES Front Load Washer Logo
289 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
