Question about Hitachi 27FX49B 27" TV
The tunning method of Hitachi TV set model C2172FSN
I cannot find any method to set the frequency in the TV set.
Ask the technican located in the shop for help,
Posted on Jan 26, 2009
Service mode bpl crt model no FYR 60YA2
Since BPL uses Sanyo kit, service mode entry method to Sanyo should work with it. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts. Service mode entry method to many brand TVs including BPL models are given.
Dec 04, 2013 | Hitachi C25-RF35S 25" TV
Lg lcd service menu code
Press Volume -ve button on the control panel to TV, and while holding it, press the display button on the remote control. This must make the TV to service mode. Procedure to different models will be different. If you wish to get more details about how to enter other service mode entry methods, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the Brand name to your set in its search box, or view it in Mosaic /Timeslide option.
Jul 22, 2013 | Televison & Video
Clear cable tv picture which fades to snow, then snaps to good picture again....video 1 has a dvd player attached and picture is fine. 2002 KV27FS13
The problem will be in the AFT (Automatic Frequency Tunning) circuit
Check and replace any faulty parts .
May 12, 2011 | Sony KV-27FS13 27" TV
Fluttering sound when trying to tun set on, never comes on and shuts down. Sounds almost like a motorboat sound, but not quite. Recent bulb change. Made sure all vents and air filter were cleaned. Took the...
Maybe the fan is going out. Since you said bulb change I assume your tv is a projection tv. If so I think those tv's have fans to help keep it cool. If the fan is not working properly or failing, the tv may be shutting itself off so further damage does not occur. Check the fan. What is the model number of your tv?
Mar 08, 2010 | Hitachi 43FDX01B TV
Toshiba Color TV CF306 - Can it receive digital, with converter
The short answer is yes. The method is to set the TV to receive either channel 3 or 4. The converter will receive the digital broadcasts and "re-broadcast" them on either 3 or 4 analog for the TV to receive.
Let me know if you need anything else.
Dan
Mar 14, 2009 | Toshiba Televison & Video
Hitachi Television Connection in Germany to a Skybox
Germany does not use NTSC frequencies. Use either video unput.....never the output. In any case, you'll only get a black and white picture and maybe no sound.
Jun 08, 2017 | Hitachi C3390FSP 33" TV
Cant tune my Hitachi TV
please check web site for any thing in remote. www.remotes.com and give model name in search. hopr this will help. good luck.
Sep 30, 2007 | Televison & Video
Some channels missing...
Try to tune the tv in manual search method. If you get means store it manually. Nothing to worry. This is due to malfunction in AUTOMATIC FREQUENCY CONTROL COIL weak. Even you won"t get channels in manual tunning method. Change tuner and afc coil. Problem solved.
Sep 04, 2007 | Mitsubishi CS-27205 TV
Pulsating power LED. No picture. No sound
Either the main smoothing capacitor or the voltage regulator are faulty. You may find that the power LED will stay on after pulsating for several minutes, at which time you can switch the TV on.
Aug 08, 2007 | Hitachi C25-RF35S 25" TV
Hitachi 27FX49B 27" TV Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
