Question about Dell Computers & Internet
Dell e1709w stuck in power save mode
I open my computer today but suddenly the monitor says " entering power save mode" and its stuck there. ive tried to do simple ways to fix but still nothing. can someone help me? im using windows 7
3 Suggested Answers
  • 4090 Answers
SOURCE: Problem w/Dell E176FPf monitor stuck in power save mode
Ok if it the monitor works fine on another unit discount it out of the equation as a monitor problem.
I would suspect the driver on the PC that delivers the problem, especially the video card.
. Check that the cable is also on tightly. remove it and even clean the pins and replug it .the plug on that PC may be dirty
You May need to replace the video card as the communication to the monitor is intermittent and that is why you get the amber light.
Open the box with power off. clean the card if it has a lot of dust on it ( most do and its always a shock) wipe it over ( BOTH SIDES) and then try to start it up as usual with the monitor connected to see if that fixed it ( sometimes works) if not get another card and replace it. Best I can offer without being there to help on the spot.
A new card should allow you access to install and configure it and these days they are pretty cheap to buy
Please rate this help to keep the service online
Posted on Aug 20, 2009
SOURCE: LG Flatron W2252TQ Monitor stuck in digital power saving mode
Raymond, (did) you solve the problem?
i've got exactly the same problem and i've read more similar complaints on the internet
gr
iris
Posted on Jan 30, 2010
Switch off and remove the power cable then put in the power cable again and switch on again...try to disable the power saving mode once it is on.
Apr 05, 2013 | Dell Computers & Internet
Dell E207WFP Display Problem
check your system vga out put is working or not, conform this by connecting another monitor or connect monitor to another computer.
May 11, 2012 | Dell E207WFP LCD Monitor
My desktop monitor direct go in power save mode.so please solve it as soon as possible its urgent
power save mode indicates no input signal. Check the input signal with a known good monitor. if the signal is good then dell monitor is faulty. Power cycle (unplug the power then plug it back in) the monitor to reset to factory and if it still goes directly into power save mode the unit is faulty.
May 01, 2011 | Dell E1709W Monitor
Hello, Hi, I've just got myself a brandnew Dell desktop with windows 7 32 bit on it. Everything seemed to work fine, but my computer enters Power saving mode at completely random times while im actually...
The simplest thing to do, as it is a desktop computer, is go to the control panel, power options and set everything to never so the computer never goes into standby mode.
If this does not prevent the machine going into standby mode then we need to perform further troubleshooting.
Jan 29, 2011 | Computers & Internet
How to deal with "entering power save mode
-that message usually appears if there's no signal coming from the CPU. If you have another CPU, try plugging this monitor to it.
Dec 22, 2010 | Dell E207WFP LCD Monitor
E172FP (Black) 17 in. Flat Panel LCD Monitor: Dell monitor problem, its the power save mode agai...
First, try it on another PC, check or try another VGA cable, if it still does not work then you need to open it up. Dell monitors are known to have bad solder connections, bad caps. See my photo albums of failed Dell monitors to get some idea what to look for.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd: www.lcdrepair.us
May 18, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Dell Monitor is stuck in power save mode. tried
Hmmm...Stuck in power save. I guess when you push the power button, the monitor says power save, then blanks to power save, no matter if the Computer is on or not.
This means the monitor does not see any signal from the computer. I would suspect the computer first. Try a different monitor (borrow one).
If the size of the monitor picture is too high and the monitor is an older LCD, you may have set the image size too high (1280x1024 will not work with this monitor and it will do this very thing).
A broken or damaged connector cable to the monitor can also cause this. Was the monitor unplugged from the computer just before this problem?
Mar 30, 2010 | Dell E173FP 17" LCD Monitor
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
My Dell monitor is stuck in Power Save Mode. Any
The monitor is not receiving signal from the computer. Verify the computer is on and the monitor input is set to the correct mode or auto. Try another monitor if possible.
Aug 10, 2009 | Computers & Internet
Power saving mode
go to comtrol panel and change the settings in the power saving control options... everything wi be fixed without any big problem
Feb 20, 2008 | Gateway FPD 1730 17 in. Flat Panel LCD...
Computers & Internet Logo
64 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
