Question about Dell 922 All-In-One InkJet Printer
Dell All in One A920
My printer does not print! It has new cartridge.
  • Sanath Kumar V May 11, 2010
    What exactly happens when try to print......
    Does it have any lights blinking on it......
    Does it give any error message on the Computer.......
    Thanku
If your printer has not printed since you changed the cartridge, you either have a bad cartridge, or have not positioned it correctly in its' cradle, or your cable to the cartridges is not aligned/connected properly. Gently push the cartridges cradle to the center (with the unit powered off), and check the cable connection, and the cartridges alignment in the cradle. If all these are correct, try returning the cartridge and replace with a new one (different batch number would also be a good idea).
Posted on Jan 27, 2009
My Dell A920 Inkjet Printer will not recognize my color cartridge which is brand new?
Is it a Dell cartridge or a generic cartridge? No-name cartridges sometimes lack the chip which the printer looks for. Return the cartridge for an exchange.
Aug 28, 2013 | Dell A920 InkJet Printer
How can I clean my A920 Dell printer?
have it serviced by a dell technician if it badly needs cleaning, doing it on your own does more damage to printer.
Nov 15, 2012 | Dell A920 0T0526 All-In-One USB Color...
My Dell A920 prints blank paper.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Mar 01, 2012 | Dell A920 InkJet Printer
Run cleaning utility
  • Clean the Ink Cartridge Nozzles
    • 1 Load printer paper into your Dell A920 Printer.
    • 2 Open the Dell Printer Solution Center on the computer. Click "Start," located in the bottom left corner of your computer. Select "Programs" from the menu displayed. Click "Dell printers." Click "Dell AIO Printer A920" and then click "Dell Printer Solution Center" to open the Dell Printer Solution Center.
    • 3 Click on the "Maintenance" tab and select the option that says, "Clean to fix horizontal streaks."
    • 4 Click "Print." This will print a nozzle print page, which forces ink through all of the nozzles to clean and unclog them.
    • 5 Print a regular document again to see if the print quality has improved. Repeat the cycle up to two more times to improve printing quality.
  • Read more: How to Clean a Dell A920 Printer ' eHow.com http://www.ehow.com/how_6645628_clean-dell-a920-printer.html#ixzz1Dh2DMoc3
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    Feb 11, 2011 | Dell A920 InkJet Printer
    My Dell A920 printer will not print the color blue. I've replaced the ink, 2 times. Changed the quality of print to "Best" and still get only the reds & yellows... Any ideas?
    hi there !
    -try the old cartridge if it will print the correct colour; the problem is the cartridge; otherwise it is the printer.
    cheers !
    Oct 24, 2009 | Dell A920 InkJet Printer
    DELL PRINTER A920 PRINTING IS BLOGGIE
    Hi! Your problem is your printers INK CARTRIDGE alignment, make sure that your printer ink cartridge is properly aligned. Or try to clean your ink catridge. GOOD LUCK. THANKS
    May 06, 2009 | Dell Inspiron 1000 Notebook
    I've installed a new coloured catridge but printer
    did u remove the peel off cover that protects the contacts or the print head on the new cartridge?
    Feb 17, 2009 | Dell A920 InkJet Printer
    Dell A920 Printing Problem
    You should check:
    1. Did you insert correct the cartridge in the holder?
    2. Check if the contacts are clean in the cartridge holder, maybe something is ther and the needle-type contacts from the printer does not push right on the cartridge contacts.
    Feb 14, 2008 | Dell A920 InkJet Printer
    Dell 922 All-In-One InkJet Printer Logo
    47 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
