Toyota startlet 1998 - what is the h-lp relay switch located with brown cover in the fuse box?
SOURCE: no tail lights and no dash lighting
You can find the fuse box either under the Driver's side of the dashboard or in the Engine compartment.
Try this solution, hope you can find the right one.
SOURCE: 2001 Toyota Corolla high beam lights are not
Your switch must be working since your indicator is telling you when the high beams are on, so my guess is that your bulbs are faulty. The high beam part. They probably burnt out one at a time, so you didn't notice until the second one went. Change your bulbs, and see if that solves it. If not, let me know.
SOURCE: where is the flasher relay located for 1998 Toyota 4- Runner
Toyota Pick-ups, Land Cruiser, and 4 Runner 1997-00
Flashers -REPLACEMENT
The turn signal flasher
is usually located in the convenience center, under the dash, on the
left side kick panel. In all cases, replacement is made by unplugging
the old unit and plugging in a new one.
Hope helped with this (remember rated this help) Good luck.
