The bulb doesn't seem very bright - Office Equipment & Supplies
    Genius:
  • 1,669 Answers
As bulbs age, especially projector bulbs which get very hot, they produce less light. That is normal. Change it if is not satisfactory, and, while you are at it, polish the mirrored surfaces and the lens with appropriate cloths!
Posted on Jan 20, 2013
204b backlight getting dim
change the inverter if it does not work ,you will have to change the backlight bulbs or you change the screen
Jun 22, 2013 | Samsung SyncMaster 204B 20.1" LCD Monitor
Bright light not coming on
TAKE A BLOW DRYER AND DRY WIRE AND TERMINALS IF THAT DOSENT WORK NEED TO REPLACE THEM
Jun 16, 2013 | 2006 Derbi GPR 125 Racing
Panasonic hdtv 1080i picture bright
It could be your main board going bad.
Jun 01, 2013 | Televison & Video
First doesn't turn on, now it does but have NO immages, just sound
I would expect that the bulb has failed.
Toshiba DLP Replacement Lamp Toshiba DLP Bulb Part 1
If you decide to replace bulb I suggest that you replace with the best quality bulb. I found the brightness between good and best bulb was significant. I have ordered from the internet and have had great results.
There are other possible causes of lost video. The bulb is only the most likely.
Good Luck
Jan 29, 2013 | Toshiba 53HX71 53" Rear Projection...
I have a 2006 mazda 6 and my headlights are messed up. only one headlight works, the other one is on but extremely dim so it doesn't help with driving, with high beams off. But when i turn my brig
2006 mazda 6
That looks like an issue with wiring. You can fix it through reliable-store.com
Wiring, schematic, electrical diagrams etc are basic contents of these online books they sell here on this website link I have attached. Must check it out, it'll surely help you
Dec 25, 2017 | 2006 Mazda 6
I have a panasonic pt-61hx42 tv and the picture is dark and hard to see night sceens Is there another bulb besides the three colored bulbs
have you already check in the menu adjustment with the brightness,how about cleaning of the reflector inside doesn't work?
Sep 27, 2012 | Hitachi 46F510 46" Projection HDTV
Drivers side head light is way dimmer than passenager light even after new bulb replacement
When looking from the outside of the headlight at the bulb, can you see the bulb clearly??
These lenses are notorious for dulling very badly. If it has you can use a regular headlight 'restoring' kit sold at most auto part locations.
If it is not a lens issue, you may have a wiring/supply issue.
Then you would need to find the troublesome wire/connection.
I am not the best at wiring issues, but I would try to find a power source wire with the same amperage rating, run a bypass jumper from a known good voltage source and see if the light changes. If no change, your problem may be the harness or plug at the rear of the headlight bulb.
Hope I could help
GL
Dec 31, 2011 | 1999 Plymouth Voyager
My high beams will go on but not the low beams. How do i fix?
if the indicator light on your dash appears to be working, you probably just need new bulbs. No, they didn't both burn out at once. You probably drove a while with one headlight and didn't know it. If the indicator light doesn't come on and off, you will need a new dimmer switch, but since they work on bright, I am assuming that works.
Aug 22, 2011 | 2008 Hyundai Sonata
Hello, I have an Echo SRM-3100 weed wacker 2-cycle that i can start but can't get it to run. i checked the fuel lines and they are clear, i took apart the carb and eveything is clean and in good...
Just to clarify, the purge bulbs actual purpose is to purge the carburetor of air and old fuel and help to pull fresh fuel from the tank to the carburetor. Some units have a purge bulb located on the carb and some have the bulb remotely mounted. I think on your model, the bulb is atop the carburetor on the primer base assembly. If the bub doesn't release, then there possibly is a problem in the fuel tank fuel cap vent. Check the cap and make sure the little duckbill vent is clean and clear. A vapor lock type situation can develop when atmospheric pressured air can't enter the fuel tank. You may also want to remove the purge bulb cover and the bulb and spray the top of the primer base with WD-40. You can remove the fuel lines and spray some into the carb as well. This will maybe clean and lubricate the sensitive check valves that may be sticking in the carburetor, causing your problem. Try this more than once if it doesn't seem to help at first. Internal check valves control fuel flow in and out of the carburetor and they do occasionally malfunction.
May 15, 2011 | Garden
k24674
jasbo
jasbo
