Question about Whirlpool LER4634J Electric Dryer
MY DRYER DON'T TURN ON!
I HAVE A ELECTRIC DRYER THAT IS A WHIRLPOOL
MODEL # LER4624BQO AND SERIAL # MD2320807.
I WAS DRYING CLOTHES FINE... AND THEN I TRIED TO START IT AGAIN FOR A SECOND LOAD AND IT JUST DON'T WANT TO TURN ON. NO NOISE NO NOTHING. PLEASE PLEASE SOMEONE CAN THEY HELP?
IS IT THE FUSE/ IF SO WHICH ONE AND WHAT DOES IT LOOK LIKE?
  • lyndapeyton Feb 21, 2009
    dryer will not cut on.
  • Whirlpool Master
  • 3,361 Answers
There are 2 thermal fuses inside your dryer.
The one that stops it from coming on is located on the exhaust duct on the rear of the dryer.
Unplug the dryer, remove the rear panel.
Look down low at the exhaust duct.
You will see a black and white part about 1 inch long held in by 1 screw.
Replace it.
Posted on Feb 21, 2009
    President:
  • 1,214 Answers
Chances are an element failed and shorted to ground.
Any fuses or breakers for the unit will be located in the fuse panel in thehouse, not inside the dryer.
Posted on Jan 26, 2009
My Whirlpool clothes dryer model GEW9200LW0 stopped drying completely. The drum turns but no heat. It began slowing down the heating process approx. 2 years ago. Any suggestions?
Electric Dryer Does Not Heat
  • If your Whirlpool electric dryer is having trouble heating, you should check all of the thermostats, the thermal cut-off, all fuses and the electric heating element for continuity and proper connection.
Apr 18, 2011 | Whirlpool GEW9250 Electric Dryer
Dryer stops running and displays E1
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
redarrow.gif Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
Aug 11, 2008 | Whirlpool GEW9200L Electric Dryer
WHIRLPOOL DRYER MODEL # LER4624BQO DRYER TURNS BUT NOT HEAT AT ALL... WILL NOT DRY THE CLOTHES.
could be the element or fuse kit on the top of the element. Also check you ventilation to be sure it is not cloged or blocked somewhere
Jan 17, 2011 | Dryers
Whirlpool dryer gold not drying clothes
  • Check for proper air flow
  • Check the ignitor
  • Check gas jet
  • Test the gas valve coils
  • Check the flame sensor
  • Test the safety fuse
  • Test the thermostats
  • Test the centrifugal switch
  • Test the timer motor
  • Test the temperature selector switch
  • Here is a website to aid with these tests
    http://www.acmehowto.com/howto/appliance/dryer/diaggdryer.php
    Nov 11, 2009 | Whirlpool GEW9250 Electric Dryer
    Whirlpool electric dryer LEQ8611LG1 not drying on sensor dry.
    Check your lint trap and the vent. make sure that there are no obstructions in either of them. Then take a look at your timer to since it is not stopping when you tell it too.
    Feb 11, 2009 | Whirlpool LEQ8611L Electric Dryer
    Whirlpool dryer model LE5795XPWO
    does it run ..if it runs and do not heat check thermal fuse.if it dont run check lid switch..alway unplug first
    Dec 10, 2008 | Whirlpool LER5636P Electric Dryer
    Whirlpool ler4634jq0
    The gas das't start tere for dryer goes for long time without drying the klotnes
    Nov 06, 2008 | Whirlpool LER4634J Electric Dryer
    Whirlpool LER4634J Electric Dryer Logo
    124 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal De
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
