Question about Panasonic Nv-Vp32 Dvd Vcr Combo 110-220 Volts
VCR Recording OK but cant see tape content
Have Checked the AV cables are ok. TV tuned in OK Aerial OK
  • David du Cann
    David du Cann Jan 22, 2013
    Thanks Jerry. there was a HO1 jam and when I got the tape out I think it had dam,aged the recording head or capstan. I will have to get a quote for repair.Thank you for your valuable time.
  • Panasonic Master
  • 3,904 Answers
VCR may not be tuned to the right channel. If you are using your VCR for the tuner then your tv is set to channel 3. Check your cabling again as well. From the wall to the VCR. From the VCR to the TV. You also need to make sure that you programmed the VCR for all of the channels. Just like you would for a TV.
Posted on Jan 20, 2013
  • David du Cann
    David du Cann Jan 20, 2013
    Thanks Jerry. I am coming through my AV2 via dish. All Sky stuff working ok but I am on A1 VCR channel and VCR leads seem in order as is wall connection. VCR does record but just cannot get the tape picture to come through.
snakehead
  • 1074 Answers
SOURCE: vcr freeze frames tv programs when turned on
if the vcr is on warranty take it back to the supplier.good luck obviously you will have to replace the VCR head.
Posted on Jun 16, 2007
SOURCE: Tape wont play then ejects
Hi Slovakia
Thanks for the reply ...but where do I download the service manual from?
Posted on Dec 16, 2007
Dave Duff
  • 30 Answers
SOURCE: Recording on a Panasonic VCR
This problem is undoubtably dirty or worn video heads. Try using a good quality head cleaning tape. If this fails, re-post, and I will explain how to clean heads by hand.
Dave Duff
Posted on Mar 07, 2008
Grubhead
  • 5349 Answers
SOURCE: Panasonic vcr records ok, but turns off while
I would consider replacing the mode switch.
Posted on Aug 31, 2009
Grubhead
  • 5349 Answers
SOURCE: Can you help me with a vcr recording problem?
Sometimes the connection cable between the devices is the cause of weak signals. If you are using coax, to carry digital signals, make certain it is the stuff they use to link up sat dishes. You can tell if it is by looking at the end. With the plastic covering cut away it should have a solid silver foil around a plastic tube which contains the wire. If it has a mesh as a screen (with holes) it should be replaced with the sat cable. This will improve the signal by over 60%.
Sometimes you can tell it's the old coax cable because it's brown in colour.
Posted on Sep 26, 2009
The picture doesn't hold. The picture shows just snow on the tv.
VCRs are analogue. So their tuners won't pick up digital TV signals, and their output from the aerial socket is analogue too. You'll have to make sure your TV is on the analogue TV tuner and then tuned to the VCR output channel if you want to use the aerial connection for viewing. It's probably a lot simpler though to use the VCR's AV output to the TV.
If you connect a TV receiver (Aerial/cable/satellite) to the AV input on the VCR, then switch the VCR to that AV input, you will see and be able to record programmes.
Aug 25, 2014 | Televison & Video
Tip
Digitial channel tune in and set up
if you have a problem getting digital channels (uk) find local channel number digital uk can help enter tuning menu go to manuial tune on tv or digi box. it will ask for channel number start with highest number pess ok or search repeat for each channel number normal 4or 5 depends on aera if still not getting all channels put aerial lead which come for aerial into tv bypassing any equipment such as vcr/dvd recorder then start again if still not all channels may need aerial upgrade .if yo get all channels connect vcr/dvd if some channnels disappear need to reset RF out on vcr/dvd remove aerial .connect vcr/dvd via scart reset RF out on vcr/dvd this can be found in vcr/dvd set up menu reconnect all leads should now work ok
Note do not set RF out to any digi channel numer
on Aug 17, 2010 | Televison & Video
I want to record a TV program and can't figure out how to do it. I have a Fisher HVD-805 model VCR player and a Sylvania HD TV. I have checked the plugs, cables etc and they are ok.
You must also connect antenna/cable to your VCR antenna/cable input, and then tune the desired channel at VCR and start recording, if your TV has video and audio outputs you can use them too, just connect them to line inputs of VCR, select them and start recording, this is more convenient when your VCR has only VHF/UHF but no cable channels tuner.
Feb 20, 2011 | Fisher Televison & Video
HOW DO I CONNECT A VCR AND WHAT DO i SET THE INPUT ON.
If you have connected using the coax (aerial) ten the problem will be that the vcr is analogue and the tv is digital(if you have an older digital tv it should have an analogue tuner so you can set it to analogue and tune to the vcr) I suggest using a scart cable from the vcr to the tv, then you just press av on the remote(on some you can just change the channel down from 1 to the av inputs).
Jan 02, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
I want to set up my video recorder to my tv and have forgotten how to do it. I have connected the two by aeriel but cannot see what else to do.
Youe aerial should be in the rear of the VCR & the other cable (flylead) should come from the output connection of the VCR & into the TV. To easily find the VCR channel insert a film tape into the video & press play, now selecting the VCR channel on the TV (EG. channel number 0) now you will need to go into the manual tuning on the TV & search until it finds the playback film, once this happens, store this setting. An easier alternative would be to buy a scart connector & connect this from the VCR to the TV & then the video channel will show on the AV setting on the TV, this saves you any tuning problem.
Oct 14, 2009 | Daewoo Televison & Video
Setup VCR to TV, using RF plugs & coaxial cable
The solution was both simple and elementary - why didn't I remember it sooner?
The TV needed to be 'tuned' to the video just as it needed to be tuned for each TV channel.
I selected channel 12 on the TV, went into the tuning mode on the TV and with the video playing, cycled through the TV tuning process until, Voila, there was the video showing on the TV.
Oct 14, 2009 | Philips Televison & Video
My son dropped my vcr and now when I record all I get is a bluescreen during playback, was something damaged, can it be fixed or should I just toss it out?
Have you checked that your signal input eg. aerial connection, cable connection etc has not fallen out from the rear of the VCR. If this is ok does it still play pre-recorded tapes ok? Make sure the channel indicator is still showing a tuned channel such as 1 or 2 etc. If still a problem please get back to me.
Jun 06, 2009 | Philips VR330 VHS VCR
How to connect a vcr for recording programs
1 - To start with..
Plug aerial lead into the "RF input" on rear of vcr
--> now you can tape programs (providing vc is "tuned" correctly)
2 - Plug a lead from "RF output" into tv's "RF input"
--> now you can watch programs on tv _independently_ of vcr (ie can be watching 1 program & taping a separate one on vcr)
3 - Plug red/white/yellow cable from vcr's "VIDEO/AUDIO output" into tv's "VIDEO/AUDIO input"
--> now you can
1) play a tape in vcr, & watch it on tv
& 2) change what watching on tv via vcr's remote
* Note: This is for analogue terrestial television (aerial on roof), not digital/satellite tv, connecting to stereo, etc, etc (the "more involved " setups)
Feb 03, 2009 | Televison & Video
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
Panasonic Nv-Vp32 Dvd Vcr Combo 110-220 Volts Logo
103 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
