Question about Dell 3000cn Laser Printer
DELL 3000cn Printing Problems - Black text is very light
The black text in my documents is VERY light, although the black in color graphics on the same page are normal. Have just changed the black cartridge. Any suggestions?
  • smack48 Jan 26, 2009
    Thanks, Mikemilw. But I use the same fonts almost all the time - Arial or Times New Roman. I've never seen a 'toner save function', and just checked the menu. Don't see it. Thanks for trying
  • 537 Answers
It sounds like the font that is being used is too light, not dense enough. Is there a default density or toner save function on this printer? Check the settings from the control panel.
Posted on Jan 26, 2009
Even though my black cartridge is full, my black and white documents are so light they are unreadable. My color cartridges are close to being empty. Can this be the cause?
printers use all cartridges to get the correct colour even black
best get a new colour cartridge then realign the printer with a test pattern
Apr 05, 2015 | Office Equipment & Supplies
Dell color laserjet 5110 cn will not print color documents. This network printer was printing color fine until yesterday mid-day when it started printing in black & white only. I tested by printing a...
This has to do with the document printing properties. When you are ready to print a document, choose properties and make sure you go through the printer settings under that software.
The test page only verifies the cartridges. The printer properties of the software control the printer during printing.
Mar 17, 2010 | Dell 5100cn Laser Printer
Dell 3000cn color printer - black/grey line down right side of page. Is it the drum? How to check drum?
Sounds like the black drum. You can't get the part from anyone but Dell so be prepared for the cost. It also requires some disassembly to install on my Dell 5110cn so yours most likely will also.
Jan 27, 2010 | Dell 3000cn Color Laser Printer
Why are documents printing with a black stripe on right side?
You most likely have a defective cartridge. It is also possible that your Charge and/or Transfer rollers have become defective.
Inspect the cartridge for any band of remaining toner.
You should notice one or two long thin rollers, with the cartridge removed. There will be a dark roller that should appear textured, but not dull. And they may also be a lighter colored roller with no marks.
These are the three common problems that create lines.
Lastly
If the band is mostly straight, it is most likely the cartridge
If the band is wavy or broken in anyway, it is probably the roller(s)
Let us know what you find
Apr 15, 2009 | Dell 3000cn Color Laser Printer
My Dell 3000cn is printing slowly
Do the documents have even a little bit of color?
if not, try this. When printing a document, after you press print, select preferences of the printer and at the bottom there is an option for output color. change that to black. Hope that helps
Feb 06, 2009 | Dell 3000cn Laser Printer
Black ink
The PGBK cartridge is a pigment black ink, while the others use a dye for coloration. The pigment black is used when printing text and other documents. The dye ink is used when printing photos and other colored documents. The dye black is used in conjunction with the color (dye) inks to provide tinting and color gradation, and therefore is not used nearly as much as the pigment black unless you use your printer only for printing photos.
If you're printing text and documents, you will need to buy another pigment black (PGBK) cartridge.
Oct 13, 2008 | Canon MP610 Photo All-In-One Printer
Text Not Printing
You are out of black and white ink.
Graphics are printed with the color cartrage
text is printed with the black and white.
Apr 30, 2008 | Brother MFC-8440 All-In-One Laser Printer
Cartridge/Printer problem - very weird (HP PSC 1315)
quiet easy you have to change you print selection to all or everyday printing that way it will print both color and black all together instead of not this and that
Mar 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
Dell 3100cn printing horizontal stripes
Sounds like a bad imaging drum to me...
Aug 14, 2007 | Dell 3100cn Laser Printer
Problems printing black
how many prints have u done with the drum, black.???, if it´s new, just clean the leeds of the black, with a piece of cloth.
Nov 14, 2006 | OKI C5100n Laser Printer
Dell 3000cn Laser Printer Logo
127 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
