Question about Refrigerators
Broken hose at the bottom of refrigerater door that feeds into
This is a 2003 whirlpool side by side and i need to get into the freezer door to replace the broken hose that goes to the water despincer. How can i open this up?
    Sniper:
  • 50 Answers
To remove door there are screws at top door hinge, them and door should lift right off. fold back gasket and you will find a lot of screws under gasket remove them and inner door panel should lift off exposing hoses .
Posted on Jan 26, 2009
  • mike murphy Jan 26, 2009
    it's really not that hard, but i can see your concern. if you are mechanically inclined it is just a matter of repeating the steps in the reverse order. what i do is lay the parts or screws in the order you take them off. if you feel you might screw it up then yes call a reputable repair person
My refrigerater is still iceing up ,in the freezer part,causeing the refrigerater too be warm ,and i have already changed the heater and the thermostat.
if you have a full freezer and a not so full fridge a brand new one will do that but check your door seals as well
Apr 23, 2012 | Refrigerators
My water hose line is broken inside of the whirlpool side by side fridge, how can I get inside door?
In most side by side fridges the water tube goes up through the bottom of the hinge on the ice dispenser door.Where is the tube broken?
Aug 07, 2011 | Whirlpool Refrigerators
Why won't the water filter turn so i can change it on my whirlpool refrigerater
If its mounted under the freezer door it might be easier to remove the toe plate grill
Oct 01, 2010 | Whirlpool ED5VHGXM Side by Side...
I have a ge gss22kgpacc side by side, the freezer is working, lights, etc. all working, but the refrigeratoe side is not working, any insight? thanks, mike
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hope this helps good luck ron
Dec 12, 2009 | GE Refrigerators
Model gss20iepcbb freezer side works fine ...fridge
freezer is cold enough so compressor is ok hopr this helps good luck ron
Dec 10, 2009 | Refrigerators
Refrigerater is not cooling
The refrigerator gets air from the freezer. Look in the freezer for frost. If you have frost in the back or bottom the you have a defrost problem. Could be a timer or heater that is bad. If no frost do you hear a fan? You should have a evaporator fan running. Maybe thats out and it not circulating air for the refrigerator. You can check this out.
Hope it helps
Aug 17, 2009 | Whirlpool Refrigerators
Loose freezer door handle on my whirlpool side-by-side refrigerat
you should be able to pull straight up on the handle (with force) and it will come loose from the retaining screw. usually its just the retaining clip that comes loose from the door but sometimes you will have to replace the entire handle to repair the unit. if your not having any luck getting it off message me with a complete model number for your refrigerator and i will see if i can get you a little  more detailed information. thx peyton
Jan 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerater Light
Hi there check plastic angle bracket on bottom of door is not broken as it pushes the fan/light switch.Hope this helps
Dec 12, 2008 | Kenmore 53642 / 53644 Side by Side...
Hose from door dispensor hook to refrigerater
it should hook up to a water line with a coupling at the bottom of the freezer door. take the kickploate off and then look underneith the refrigeraqtor and there should be a clear plastic tube there3 to hook up to.
Aug 04, 2008 | Maytag MZD2669KE Side by Side Refrigerator
Frost buildup in ice-dispenser tube
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced. The problem you describe is almost always air laekage around that flap. Post back if you need more help.
Oct 18, 2007 | Refrigerators
Refrigerators Logo
225 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
