Question about Star Logic 17" LCD Monitor
Starlogic monitor speakers don't work
Can't get speakers on monitor to work. When I plug in bose speaker headphones on tower i get sound, but no sound from speakers on monitor.
  • 558 Answers
Do you have a cable hooked into the audio port on the back of the monitor? this will go to the audio out on the back of the desktop box. let me know
Posted on Mar 21, 2009
  • Mark Zielinski May 16, 2015
    no cable plugged in on back, still doesnt work.??
How to i connect my bose companion 2speakers to my computer and get sound
hi, first Identify what computer you have. Is It A Mac or PC?
If it is PC
There should be 2 small 3.5mm coloured sockets on the back,front (or both ) of the main box (tower/desktop unit). You should find that they are coloured Green and Red. Green is for sound output (Headphones/speakers or hifi) and the Red is for sound input or Recording. Used for things like microphones. Some will accept line sources such as mixers and Ipods pr cassette players, but please check your sound manager, mixer settings in your opperating system to make your you have an adjustable input setting for Mic and Line input attenuation as not all do and you may end up with a distorted mess. You may also find there is a small diagram of headphones or a microphone to indicate sound "in" and "out" ports.
If you have a mac
Appart fom me being envious :-) there are two sockets. On laptop types, on the side or on the tower types on the front,back or both. They have a diagram of a microphone and headphones. Hadphones is for audio output to headphones, speakers, hifi, dj mixer. The Microphone is a sound input. Please read above for microphone port usage. Hopefully this answers your question. Please also bear in mind that if you have no sound once plugged in, you may need to adjust the audio properties in the system in the system and/or program you may be using
Dec 29, 2010 | Bose Companion 2 Series II Multimedia...
Can I hook up the Bose Companion 2 series speakers to my HDTV and get acceptable sound?
Well if you currently find the sound of the Bose acceptable and your inbuilt HD TV speakers poor, then the answer is yes. Should you not like the sound of the Bose, plugging them into an HD TV won't make them sound any better :-)
Just use the headphone out of your HD TV to connect. You may find you need to enable the headphone socket/volume via the menu settings on your HD TV
Dec 14, 2010 | Bose Companion 2 Series II Multimedia...
No sound from this monitor. I have everything plugged in , volume icon is turned all the way, mute is off, adjusted speaker levels, etc on my desktop.
Firstly,
You need to check if the green cable from the computer tower is blugged into the back of the monitor (The cable looks the same at both the ends) this is for the output to come through the monitor.
If that is plugged in and if not working, Try a headphone on the tower and check if the sound is coming from the headphone, If yes, You will have to adjust the volume on the monitor or the speaker of the monitor might have gone bad. If there is no sound coming in, Then the problem is with the tower and not the monitor.
Dec 02, 2010 | Acer X193W LCD Monitor
Bose Companion 2 Speakers won't work with Sony Vio Laptop
You don't write which operating system you use, but generally you should be able to choose where the sound output goes in the Sound Properties in Control Panel.
If however Sony decided to put some special software that does the thinking for you, and directs the sound output via the HDMI when connected, then you have to dig deeper...
Oct 30, 2009 | Sony Audio Players & Recorders
Can 2.1 pc speakers work thru headphone jacks?
No it's not possible to have a sound. Because the HDMI and the Headphone (3.5mm jack) are on two different technologies.
The monitor does not have a way to convert the sound from HDMI to Headphone.
There could be a converter that might convert the sound signal from HDMI to headphone (but I'm not sure).
Aug 30, 2009 | Logitech X-540 Computer Speakers
Bose Companion 3 series II speakers aren't producing sound (imac)
from what I've read, the imac has a 3.5mm (.138) jack while the Bose jack is 1/8 (.125). very small difference in size (.013), but enough to cause problems.
Dec 26, 2008 | Bose Companion III Computer Speakers
Starlogic monitor - no sound
Did you plug in a sound input into your monitor? It will be a separate wire from the video input.
If it has a 3.5 mm stereo input jack then it probably has speakers, and you should connect that jack to the green headphone jack on your PC. If it has no input jack then it probably has no speakers.
Of course, the sound input might be included in the VGA cable, in which case that would divide near the PC with a green jack-plug on the end. Again, plug that into the green socket on your PC.
Sep 08, 2008 | Computers & Internet
Interference with headphones
Have a look at the three plugs on the front tell me how it went my e-mail JAyden.mills1@education.nsw.go.au
Apr 30, 2008 | Logitech R-10 Computer Speakers
Connecting Bose Companion 3 to HP Pavilion Desktop (Elite m9150f)
you have to configure your sound at control panel; you have to switch from computer speakers to external, with or without a woofer. Easy shreazy.
Mar 09, 2008 | Audio Players & Recorders
No Sound
DO I HAVE TO GET NEW SPEAKERS FOR VISTA TOWER
THEY WORKED FINE ON MY OLD COMPUTER
NOW NOTHING
I HAVE IT TURNED UP HIGH ON THE MONITOR SCREEN BUT NOTHING.
Feb 23, 2008 | Logitech X-540 Computer Speakers
Star Logic 17" LCD Monitor Logo
323 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
scj103
Jerry Umali
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
