Question about Slik PRO 700 DX Tripod
How to replace a middle leg section
Brought a new middle leg section need to know sequence to put together
  • Rob Evans Jan 23, 2013
    Thanks for looking but i worked out how to put it all together fully operational again
  • Michael Qui?ones
    Michael Qui?ones Jan 03, 2014
    How did you do it? Having same problem. - Mike
How do I disassemble it to make it easy to move it?
backward of how you assembled it I would assume .
Jun 21, 2015 | Exercise & Fitness
I have a 1987 mobile home with a coleman electric furnace model 3400-812. I need a wiring diagram for the repairman to use to rewiring all the new parts. He has installed a new fan blower motor, new...
5cd0d9d4-9d59-458b-ae93-d14f7aa016ab.jpg728c66bc-7660-4666-bc17-bdfa1b3130ed.jpgded744e2-3c31-4bc2-aec3-aa2d40664be6.png
I mean this respectfully, if the technician cannot wire a unit without a wiring diagram , he is not competent to do the work.
It is really very simple, If you look at the power lines entering a building, ther are but 2 hot legs of 115 volts for 230 volts and a earth / ground, every wire we will ever see are these 2 hot legs or a combination of them.
Every circuit requires 2 sides/legs of power, a device and a switch, begin at L1 go through switch to load return to opposite side of power from where you began, very simple.
If you do not know this a wiring diagram will tell him nothing but how to blindly try to follow some diagram he has no grasp of the theory behind or he would see how simple his dilamna is.
Oct 19, 2013 | Coleman Heating & Cooling
Manfrotto 685B locking problem
I had the same problem with the Manfrotto 685B, and it was due to the grease from the middle section leaking into its locking mechanism. I fixed the problem by: 1. Detach the middle from the bottom section by twisting the metal hub between them counterclockwise. 2. Wipe the grease off from the middle section's locking mechanism, especially from the three gray protrusions. 3. Use a bit of dish detergent to degrease the inside shaft of the bottom section. 4. Dry thoroughly. 5. Reassemble the section back, pressing the monopod release lever to facilitate the insertion. Reclose the metal hub. Ha! Fixed!!1!1!!eleven1!!
Feb 28, 2012 | Manfrotto BOGEN 685B Neotec Deluxe Monopod
I have a Manfrotto 685B monopod that I have had for about a year. Recently I noticed that it has gotten very hard to extend or retract the leg sections of pod. I looks like there is a wax substance on top...
If it was second-hand or pre-owned, the previous owner may have applied some form of lubricant to it. From a look at the images on the Net, it appears that the upper sections are adjusted by twist grips. If this is so, just unscrew them and separate the leg sections carefully, after which they can be cleaned. There may be a bevelled collar within, to grip the section - be careful with it.
The bottom section seems to have a standard lever lock. There should be a couple of screws holding this to the middle section - loosen these, then slide the leg portion out and clean it as well. When re-assembling this part DO NOT over tighten the screws - just enough to prevent the locking collar from moving.
Apr 08, 2017 | Bogen Communication Bogen / Manfrotto 685B...
Proline Piano Keyboard Stand Assembly Hi, I just bought a Proline piano stand for an electronic keyboard, and the first step on the assembly directions is to move the clutch to the middle position....
Normally on my stand like this you PULL the knob outward (not turn it) to disengage the pin from the plate with the holes in it... Works quite well and the stand is moree stable than many.
Nov 28, 2010 | Pro Line Proline Pl 400 Double X Braced...
Screw to leg has fallen off how do I get cage off of fan?
I have not been able to find a large picture of this fan, but I will tell you what I have run into in the past. On some of the fans there are small clips around the grill where the front and back pieces come together. It would be a case of opening these clips and sliding either the front of back grill off. Reverse the process when putting it back together. On others I have found small plastic wire ties holding the two grills together, one at the screw locations where the legs hook onto the fan. These need to be cut with scissors or wire cutters and replaced with new ones when putting the fan back together. New wire ties can be purchased at Home Depot or Radio Shack.
Please let me know how you make out and I will keep looking into this.
Paul
Sep 19, 2010 | Patton U2-1487 Floor / Box Fan
I do hvac but don't do 3 phase i looked at it and the fan motors come on but the compresser doesn't
At the contactor take your electrical meter and on the incoming power to the contactor check all three legs.
Left leg to middle leg should be 220, middle leg to right leg should be 220. Right leg to left leg should be
220v.
Disconnect compressor wires take meter and go from
compreesor terminal, put one lead on terminal and the other lead to ground ,do this for each leg, if
continuity is present on any of the three legs, the compressor is grounded.
If it checks out ok,check the fuses, if they are ok
replace the capacitor
Jun 24, 2010 | Heating & Cooling
Any gm techs out there that would know the torque
Start at the middle and work your way criss crossing outward using 35 foot pounds of torque. All intakes use the same technique. Never start at the ends, alsays the middle section working your way out
Feb 04, 2010 | 2001 Chevrolet Blazer
Reassembling telescopic sections for a 676B monopod
Each leg lock has a leg locking lever and a screw that hold the clamp assembly tight to the leg. Unlock the leg lock lever, loosen the screw above it that holds the clamp tight to the leg. The legs should fit into each other sice each leg is slightly larger or smaller then then next one. Slide the clamps in the approprite places and tighten the screw enough to hold the clamp assembly tight, but do not over tighten it. Over tightening will damage the 679 tubes.
Dec 25, 2009 | Manfrotto 679B Monopod
How do I solve number 009 one poor pooch
Get the two inside legs and put them in the little spaces by the corners of the backs so thay look opposite. In the end the dog will look like it is squashed on the ground.
Dec 31, 2008 | Nintendo Professor Layton & the Curious...
Slik PRO 700 DX Tripod Logo
35 people viewed this question
Top Slik Photography Experts
Greg Cann
Greg Cann
JP Services
JP Services
Tony Parsons
Tony Parsons
Are you a Slik Photography Expert? Answer questions, earn points and help others
