Question about Toshiba Satellite A60 Notebook
I have keyboard problem with my toshiba lobtop
When ever i press on a key, some other programs get executed without demand.
i thought it was a virus sign, i have formated my system, and nothing changed, and i have reformated with low level format again and still there is the same problem.
i cannot use my onboard keyboard and even not an external one.
please help me to solve this problem.
do i have to disamble the entire system and re-assamble it back????
  • 85 Answers
Formate ur laptop ur problem will be solved
Posted on Jan 26, 2009
Why has my mouse stopped working, also the touch pad on computer has stopped?????
Janice, This is info from Tomsguide.com
1- Turn off computer, disconnect the power cord, remove the battery.
2- Press the Power On button for 10 seconds
3- Replace battery and/or connect power cord.
4- Turn On computer + immediately press F2 key repeatedly
5- Press F9 then press Enter
6- Press F10 then press Enter
May have virus or corrupt driver, run your anti virus and try reloading divers for mouse and touch pad, you may have to use system restore to an earlier date when thins were working OK.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://ccm.net/forum/affich-689275-toshiba-satellite-mouse-pad-stopped-working
Toshiba Satellite keyboard and touchpad don work
Toshiba Satellite Cursor is not responding
Jul 31, 2016 | Toshiba Computers & Internet
How to screen shot on toshiba
Press the "Print Screen" key, usually found on the top row of keys on a keyboard on the right hand side of the keyboard. Then open the Paint program in windows, and press Ctrl-V or paste. Then the screen shot will be in paint to be saved.
Aug 31, 2014 | Toshiba Computers & Internet
No Keyboard Access
Hi , some laptop have separate keyboard and mouse access key,
try to find it on key board and press it with or without <fn> key
some laptop support keyboard shortcut and if you know the shortcut
win 7&8>start >type on screen keyboard find it and double click and try to press the shortcut key
some laptops use some 3rd party software try to find it on start all programs
if you have problem with it try usb mouse and key board
if you still face problem with it maybe you have some hardware issue with your key board so try to send it to certified repair shop or ask from toshiba website or online care
Dec 15, 2013 | Toshiba Satellite(R) L655-S5157 Laptop...
Remove virus
Insert your USB drive in the appropriate USB slot in your computer.
If the Autoplay dialog box appears, select "Take No Action" and click the "OK" button.
Launch your anti-virus program, such as AVG Antivirus or Anti Malware.
Select the USB drive for the program to scan.
Click the "Start Scan" button or option.
Open the scan history for the USB drive when the scan is complete to see a list of viruses and warnings identified by the antivirus software.
If desired, select the options to "Heal All Infected Files" or "Move the Infected Files to the Virus Vault" to ensure these files are quarantined from your system.
Highlight each infected file in the scan history.
Write down the file name of each infected file identified on the USB drive.
Minimize the application's window.
Select "Run" from the Windows "Start" menu. In the Run window, type "e:/" at the command prompt to switch to your USB drive (or type the drive letter for your USB drive).
Press the Enter key.
Type "attrib -s -h -r -a *.*" at the command prompt to remove the system, hidden, read-only and archive file attributes.
Type "del ####.+++" where "####" is the file name of the infected file and "+++" is the file extension, at the command prompt line.
For example, "del terriblevirus.exe" will specifically delete the Terrible Virus executable file. Repeat for each infected file on your list identified in Step 4.
Close the command prompt window; that is, exit the Run utility.
Maximize the window for your anti-virus program (which is still open) and repeat Steps 2 to 7 until no virus is detected on your USB drive.
Exit the anti-virus application.
or Click start click on my computer you should see your usb drive right click then select format.
another way is to control panel administrative tools computer management disk management Right Click on your drive select format
Oct 22, 2013 | Toshiba Computers & Internet
Toshiba laptop/satellite
Hi There,
With the viruses gone you need to do a little cleanup. I believe your browser is probably clogged with temporary files and that you registry needs tuning up. Here's the link for a wonderful little application that can do the job for you.
http://www.piriform.com/ccleaner/download
Ccleaner is a quick install and does not conflict with any other programs. Install it, run the Cleaner first without changing ANY of the settings, then click on the Registry square on the left side menu and just run it and say yes to every prompt. Then reboot.
After reboot, one last thing;
Hold down the Windows Logo key on your keyboard and press the R key. A Run Command window will appear. Type in %TEMP% and hit the Enter key. Your Temp File folder will appear. Left click once inside the folder window then use the keyboard command ctrl+A. All the files will highlight at once. Hit the delete key and let Windows delete as many files as it can. If it says one is in use and can't be deleted, just let it stay.
You should notice a difference after following these steps.
Good Luck!
Jul 14, 2010 | Toshiba Satellite A215-S4747 Notebook
I need an explanation as to the secondary function of the keys on my NB305. Mainly the top row of 'F' keys, but the remainder of the keyboard as well. What do all these little symbols on the keys mean?
F1 through F12 are called function keys because they execute programmed functions when pressed. Used in combination with the Fn key, keys marked with icons execute specific functions on the computer. The function executed by individual keys depends on the software you are using.
1. Sound Mute: Pressing Fn + ESC in a windows environment turns sound on or off. Press Fn + Enter to simulate Enter or the enhanced keyboard's numeric keypad. 2. Instant security: Press Fn + F1 to blank the screen to prevent others from accessing your data. To restore the screen and original setting, press any key or press the Touch Pad. 3. Power save mode: Pressing Fn + F2 changes the power save mode. 4. Standby: When you press Fn + F3, the computer enters Standby. 5. Hibernation: When you press Fn + F4, the computer enters Hibernation. 6. Display selection: Press Fn + F5 to change the active display device. Hold down Fn and press F5 again to change the device. 7. Internal LCD screen Brightness: Pressing Fn + F6 decreases the display brightness in decrements. 8. Internal LCD screen Brightness: Pressing Fn + F7 increases the display brightness in increments. 9. Wireless setting: If your computer has both Bluetooth and Wireless LAN functions, you can press Fn + F8 to select which type of wireless communication you want to use. 10. Touch Pad: Pressing Fn + F9 in a windows environment enables or disables the Touch Pad function. 11. Press Fn + F10 or Fn + F11 to access the integrated keypad. When activated, the keys with gray markings on the bottom edge become numeric keypad keys (Fn + F11) or cursor control keys (Fn + F10). The power on default for both settings is off. Press Fn + F12 (ScrLock) to lock the cursor on a specific line. The power on default is off. 12. TOSHIBA Zooming Utility (reduce): To reduce the icon size on the desktop or the application window, press the 1 key while holding down the Fn key. (13. TOSHIBA Zooming Utility (enlarge): To enlarge the icon size on the desktop or the application window, press the 2 key while holding down the Fn key.
Jun 15, 2010 | Toshiba 310CDT Keyboard
Keypad problem: abcdefgh51230n6*qrst4vwxyz
I pressed the number lock and the problem went away.
Thanks for sharing your solution.
Mike
Feb 28, 2008 | Computers & Internet
Toshiba Laptop Keyboard Malfunction
If you boot a XP cd and select repair will it let you type?
Sep 21, 2007 | Toshiba Satellite A85-S107 Notebook
Toshiba Equium Laptop Keyboard Problem
Yo, I think I got this one.
Someone brought this model of laptop to me and the keyboard and mouse were shot. Totally unresponsive. So I downloaded the driver found here
http://support1.toshiba-tro.de/tedd-files2/0/butsu-20070709123021.zip
which is described on the drivers section of the toshiba site here
http://uk.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=UK&selCategory=2&selFamily=382&selSeries=173&selProduct=667&selShortMod=477&language=13&selOS=26&selType=all&yearupload=&monthupload=&dayupload=&useDate=null&mode=allMachines&search=&action=search&macId=&country=8&page=1&startPage=1&prevCl=true
to be the button support.
I did this all with a USB keyboard and mouse by the way.
OK, so now that I can actually use them, I start to test out the touchpad and keyboard and had the same problem all you lot did. I looked at the keys which were giving me greif and saw that they are all keys that had alternate settings when used with the function (fn) key. Turns out that there was a fn lock on the keyboard which I cleared by holding the fn key and pressing f11. This turned off a little LED just above the "9" key and voila, working laptop again.
To test if this is the problem with your laptop, press and hold down the "fn" key and press any of the keys which are coming up incorrectly. If while holding it down (cancelling out the lock, like how shift and caps lock work) the correct character appears on screen, then you too are suffering from funct-itis (tm)
Sep 03, 2007 | Computers & Internet
Toshiba Satellite A60 Notebook Logo
73 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
