Question about Samsung VP-L800U Hi-8 Analog Camcorder
Camcorder will not run from the charged battery but will run from the power pack
Have tried two new batteries which charge up ok but the red charge indicator still flashes
techman
  • 3130 Answers
SOURCE: Samsung VP W95D Hi 8 Camcorder
are you trying to charge the battery while on the camcorder??? does the camcorder work when you plug the camcorder into the charger?? If the battery fails to charge while its on the charger it can only be the charger but most likly the battery. If the camcorders dead it could be the dreaded pana cap think thT HAPPENS TO MOST CAMCORDERS AFTER A LITTLE AGE. good luck
Posted on Apr 14, 2006
  • 5 Answers
SOURCE: Samsung SC-D363 won't charge battery
well , just make sure that the camera is set to the off position when charging , otherwise i dont think it will charge properly.
hope this helps
Posted on Jan 03, 2008
dthompson
  • 98 Answers
SOURCE: Charging the battery on Samsung Upstage sph-m620.
Well if it's new, then I would take it back to the store from where you bought it. It will be under warranty so, if something is wrong you should be able to get it swapped out with a working one.
Posted on Sep 12, 2008
arian07gapa
  • 62 Answers
SOURCE: Works on ac power only-battery does charge
Try to change your batery..
Posted on Oct 03, 2008
SOURCE: Samsung NV10 Charging problem
I had the same problem while charging the camera with the cradle. I tried charging directly with the camera and it looks good. Problem seems to come from the cradle itself. Phil
Posted on Jan 01, 2009
I have a new Dyson V8 Absolute When I try to charge it nothing happens. When I pull the trigger I have one flashing blue light. HELP
not trying to be a smart a** but which of the two do you have?
1. A flashing blue light indicates that the battery is running low on charge.
2. A fast flashing blue light indicates no power or a temporary fault (e.g. check filter or for blockages).
FYI....A solid blue light indicates that the battery is charging. No light indicates the battery is fully charged. A solid amber light indicates that the battery is not charging due to a temporary fault (e.g. too hot/cold). A flashing red light indicates that there is a fault, call the Dyson Helpline.
Best to you.
Feb 20, 2018 | Dyson Vacuums
I have a compaq nx7400 and the battery won't charge new battery and new charger.all it says is charging any ideas how to fix this
good day!
did you give it 24hrs to finish a charge?
the PC has a charging chip inside.
new battery from whom>?
the line pack is not a charger its line power pack,
it converts 120vac (or 240 outside usa) to 19vdc.(Or your spec)
the 19vdc runs the PC perfectly with no battery installed DOES IT>
that is the first test. the power pack must be the the correct pack
for:
voltage
current (never lower spec)
and watts.
if not the correct power pack it will now work correctly
the watts can be higher no problem,
if it runs ok on line power no battery
then we try the battery. (give it 24hrs for stubborn old batteries)
if the power pack is ok, it will charge, (spec pack as HP tells you)
if the battery is bad it will not.
if the charger chip in the PC is bad (MOBO BAD) then it will not
testing takes, skills and tools, one tool is a voltmeter
lacking that tool, one can only guess.
what not get your PC repaired by a TECH.???????
here is your HP page, its non trivial, no>?
see that they have 5 power packs used
that is BECAUSE they HAVE many power levels of CPU/GPU
faster rated CPU'GPU need more power.
https://support.hp.com/us-en/product/hp-compaq-nx7400-notebook-pc/1847094/how-to
you never once said
it runs perfectly on AC power only
not once
nor it does not overheat. nor if the fan works and vents all are free of lent.
Mar 29, 2017 | Compaq Computers & Internet
Show me how and where to hook up power cord, to charge battery for camcorder, omni2
many camcorders have a power pack that attaches to the camcorder and then the battery attaches to the power pack you can also put the plug in and run the camcorder when everything's attached
Feb 26, 2015 | Video Cameras
Battery charger red charging light blinks once then goes out
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
Oct 24, 2017 | Hilti Drills
Dewalt de0245
These de0245 chargers are designed to detect certain problems that can arise with battery packs which would be indicated by the red light flashing at a fast rate.
If this occurs, re-insert battery pack. If problem persists, try a different battery pack to determine if the charger is OK. If the new battery charges correctly, then the original pack is defective and should be returned to a service centre for recycling.
If the new battery pack gives the same trouble indication as the original, have the charger tested at an Authorised Service Centre.
If you need new battery for this tools
Mar 23, 2014 | Drills
Camer will not power on
If your battery does not seem to charge, then you need to carry out some tests on the device, the battery and the charger. First you insert the battery into another cam corder then you try to charge, if it charges, then it means the battery is okay and if it does not charge, then it means the battery is bad and need to be replaced.
Then i will advice you take the charger and try to charge another device to see if it will work, if it works, then it means the charger is alright but if it does not then it means the charger is bad and need to be replaced.
Finally, test the camcorder by plugging a well tested charger and battery into it and trying to charge it, if it does not charge then the problem is from the camcorder.
Feb 12, 2014 | Canon MVX20I Mini DV Digital Camcorder
Canon Vixia HF M41 doesn't charge battery - red light flashing rapidly
If you don't use the battery for a long period of time even a new battery may become dead. You can try a new battery. If it still doesn't work then the problem is with the charging IC. u can also try a desktop charger instead of direct charger.
Mar 04, 2013 | Canon VIXIA HF M41 Camcorder
Charging woes
The replacement power pack could be defective.
Sep 21, 2017 | Video Cameras
I just bought my 11 year old an ultra hd 2 hr flip video, we cannot even get it to power on, any suggestions?
You need to first Charge your camcorder battery pack.(mine had to charge over night) the first time.  Plug the little arm that extends from the camera into a USB 2 port on your computer and make sure your computer stays ON during the charging, otherwise the camcorder will not charge.
A red light will come on during charge and goes off when charged. If it does not come while plugged in try a different USB port.  Screen should light up temporarily and Red light showing charging on front of camcorder.
IF YOU HAVE ALREADY DONE THE ABOVE, and are having the problem, pull the battery pack out and reseat it back in there again.  maybe connection not good.  OH, and I think mine had plastic covering the metal connections you may want to check that too -remove if so----- BUT the entire white plastic around the batteries STAYS IN PLACE do not remove that.
If that still doesn't work I would try regular AA batteries in it if in fact you have The FLIP ULTRA HD it will take regular batteries too.    IF they work - then maybe you got a defective Rechargeable Battery pack and should contact Flip Video at   http://www.theflip.com/en-us/
Feb 13, 2011 | Pure Digital Flip Video Ultra Camcorder
CHARGER PROBLEMS
The flashing light indicates the charger is charging the battery (or attempting it) and if it never finishes charging you should try to charge a different battery, if the charger charges that one ok then the battery is bad.
Jun 18, 2010 | Dewalt 18 Volt Compact Drill Kit
Samsung VP-L800U Hi-8 Analog Camcorder Logo
14 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
