Washer off balance often.
You say the springs under the tub may be worn or broken. How do I get to these springs? Lay the washer down or can I get to them by removing the front panal? And what is the proper name for them? Example ( spring, motor pivot) etc.
  • henmar614 Jan 29, 2009
    Thank you very much for your help. Your information saved me lots of money. You have a fantastic service.
  • 112 Answers
They are drum stabilizer springs.
You can take the back off or look underneath.
If you turn it over, make sure all the water is drained out completely.
Any residual water can mess up your circuit board on the fascia panel.
Posted on Jan 26, 2009
  • Steve Draper Jan 29, 2009
    It was nice to be of service to you.
    Thank You for the nice comment.
WASHER SPINS LIKE ITS OUT OF BALANCE ALL THE TIME
Rex, probable broken balancing springs. Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
GE Washer Top Loader Out of Balance Shaking Repair Tutorial
http://forum.appliancepartspros.com/washer-repair/6812-spin-cycle-badly-out-balance.html
How to Fix Shaking Washing Machine
How To Fix And Stabilize An Unbalanced Washing Machine
Mar 09, 2016 | Washing Machines
I just asked about my washer vibration and did you answer my comp. kicked out and I did not get my answer
Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Apr 11, 2015 | Washing Machines
Drum wobbles when empty
Apr 02, 2015 | Whirlpool Wfc7500vw Washer
I have a Samsung washer model number wf338aab/xaa my tub is off balance
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
By the way my advice is free cuz God is good!
Sep 17, 2014 | Samsung WF328AAW Front Load Washer
My washer is very very loud during its spin cycle
There are a number of things that can do this. For a top-load machine, an out-of balance load can get noisy. Many GE washers have bungee-cord type straps at the top of the tub to dampen out-of-balance gyrations. If these break, you get a lot of rattling. Other washers (some older Kenmore models for example) have a spring-and-bar arrangement under the tub. If this freezes up due to rust, or something breaks, your washer will bounce a bit. Older Maytag washers may dance around if the baseplate is worn out. In all washers, bad tub bearings can make a racket; you will often have leakage as well.
Sep 09, 2014 | Washing Machines
Tub is crooked, could a balancing spring come loose
Feb 12, 2014 | Estate Washing Machines
My kenmore washer is banging really loud during the spin cycle
there are springs on the suspension of the tub if one of them is broken r worn out the tub will not balance and will bang had to replace them on my washer and it fixed the problem instantly just make sure that you take a picture of how they are placed on the drum because the frame for the washer is universal and fits different tubs that have different spring placements
Nov 17, 2009 | Washing Machines
Kenmore Elite tub shaking badly
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 10, 2009 | Kenmore Elite 45986 Front Load Washer
My top load washer stays off balance.
one or 2 of the springs under the tub are worn out or broken loose
Jan 26, 2009 | Washing Machines
Empty washer tub wobbles during spining, plus burning smell
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
