Question about GE Refrigerators
Ge gsh25kgrb not getting cold
    Top Expert:
  • GE Master
  • 9,472 Answers
Is the compressor working?
Posted on Jan 20, 2013
  • 4 more comments
  • geoff Jan 20, 2013
    yes
  • Richard Roth
    Richard Roth Jan 20, 2013
    Is the freezer working?
  • geoff Feb 09, 2013
    Yes but the bottom on the refrig and the bottom of the freezer get get a little cold when on high. Top does not get cold. Not
  • Richard Roth
    Richard Roth Feb 09, 2013
    Is the fan running in the freezer section? Do you see any ice buildup on the back wall of the freezer?
  • geoff Feb 10, 2013
    Yes the fan is running and there is ice buildup
  • Richard Roth
    Richard Roth Feb 10, 2013
    OK, you will need to replace the defrost thermostat located on the coils in the freezer. Here is the part to order.http://bit.ly/YkdQt9 Here is a video to show you how to replace the thermostat.
GE TFX20R runs non-stop.
Have you sat and watched it constantly? Or just notice it running every time you take notice? I ask because a lot of people say it runs all the time when it doesn't really. Is it staying cold? or getting too cold? Or is the temp normal?
Jan 02, 2010 | GE Refrigerators
Ge sxs model GSH25KGRB BB. We have water and ice in the door and when using the water in the door, the water doesnt stop running out even after you pull glass away and we have started to see water frozen...
your water valve might be bad it locate behinde the fridg on the bottom you need to pool out the pip from it to see if it still leak..
contact me at www.911servicetoday.com
Dec 30, 2009 | GE GSH25KGR Side by Side Refrigerator
MY GE GSH22JFTABB WONT GET COLD
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 09, 2009 | GE GSS25LGM Side by Side Refrigerator
GE refrigerator model GSH25KGRB # HG256690 NO WATER OUT DOOR.
I use a hair dryer to defraust the door. This refrigerator is very sensitive to tempature change. When it gets cold out and you have the tempature on high, the water freezes in the door.
I cover the opening of the freezor with a piece of plastic cut to fit. I tape it in place with blue tape. I tape the door switch down so the you can test the water to see when it is running again. I use the hair dryer With the door open I concentrate the heat on the right side center section. It usually takes about thirty minutes. I put a glass in the water compartment and I try the water every few minutes until it flows. Finally, I run the water for two or three minutes after it starts to flow to make sure all of the frozen water is clear. Thom
Sep 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Artica icemaker does not make ice. model # PSC235GNA. We still get cold water .
use a thermometer make sure freezer is normal operating temp if freezer is cold enough and water is filling ice maker you may have bad ice maker very simple system make sure your getting water 1st thing to check is for water if you have water and freezer is cold youll have ice
Aug 18, 2009 | GE Refrigerators
Side by side refrigerator problem GSH25KGRB WW
I have the same problem with my GE fridge.  I inherited the fridge with the purchase of my house.  There is a coil located in the back of of the freezer.  Remove the wire shelves and remove the screws and remove the back panel inside of the freezer.  I can almost guarantee your coil is completely iced.  I just use a hardryer to remove the ice.  I need to perform this once every four weeks.  It's a bummer.
Jan 02, 2009 | GE GSS25LGM Side by Side Refrigerator
GE Side By side doesn't cool and freexer frosts up
Most common problem on GE's is the defrost heater(s) has gone bad. They are a glass tube and when they go bad the tube will have a burnt or black color to it. A good heater will be clear. I bet that is your problem. Seems to be the problem about 90% of the time on GE not defrosting.
Jun 29, 2008 | GE GSS20IEP Side by Side Refrigerator
GE washer
if you are only getting hot water on warm setting possible bad inlet valve cold side ck wiring first just to be sure wire to cold side not loose
Jun 08, 2008 | GE WHRE5260E Top Load Washer
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
