Question about LG Televison & Video
BNO POWER TV FUSE ALWAYS BLOWN..
I REPLACE ALREADY NEW FUSE , BUT WHEN I TURN ON THE TV THE FUSE BLOWN AGAIN..
  • LG Master
  • 3,904 Answers
There is a short somewhere on the board causing the overload. You will have to get the power supply checked.
Posted on Jan 20, 2013
  • justin_sgall
    justin_sgall Jan 20, 2013
    SIR JERRY, THANK, HELP ME TO FIX THIS TROUBLE OF MY TV...
  • 2335 Answers
SOURCE: proscan lcd tv model 26lb30h blows fuse on power board
If the fuse blows again after replacing it, there's a shorted diode, bridge rectifier, capacitor or transistor in the power supply.
I repair these power supplies. If you need furhter assistance, write to jah2mil@hotmail.com
Posted on Jun 20, 2009
  • 8457 Answers
SOURCE: Dead TV
U know basic electronic's,and u know how to do soldering?Have soldering iron,tools and solders?The power supply board,the board that the power a/c power cord plug into it.That the power supply board have these parts call capacitors are dead.These capacitors alway bulges up on it top or puff on it top.Check all around the power supply board and it supporting boards.Replaced these dead leakage bulges up on it top or puff up on it top.Or tries websites like Shopjimmy.com,Ebay.com to buy and replaced the whole refurbish power supply board.
Posted on May 28, 2010
budmrtn
  • 11361 Answers
SOURCE: my philips lcd 32wf337b27 won't turn on. Opened tv
You have short circuits, need to check the bridge rectifier, MOSFET that drives the AC to DC converter, etc. You will have to do component level repair at this point, better off getting new power supply module. I did not anything on the web yet using your model number (correct number?) you provided. Try EBAY and www.shopjimmy.com
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jun 26, 2010
ankitchandel
  • 141 Answers
SOURCE: Have a 42PC3D-UD plasma tv.
Go to nearest help centre and check your tv
Posted on Mar 24, 2011
caroldon
  • 17130 Answers
SOURCE: the fuse inside the tv has blown so tv wil not
The main fuse is found on the power board which is a the front end of the power supply. Now if the fuse has blown you can replace with the same rating fuse which can be pruchased from any electronic store. All what is needed is to confirm the value of the fuse and replace only with the same rating. However if the fuse blows out again then it is confirmed that the SMPS- the power supply unit - has failed. If so it is important to look into this circuit to recitfy . attempt only if you are technically able.
Tips to repair the SMPS
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Posted on Sep 20, 2011
After a power outage, the tv wont turn back on. was hoping there is a fuse that may have blown.
Hi Michael,
Yes there is a fuse in your TV too and sometimes you do escape with a blown fuse after a power outage. Please open if you can the back cover of your TV, locate the fuse. If you do not see any damaged or blown parts, replace the fuse with the same rating. If the works, enjoy watching. If the fuse blows again, the power board needs to be repaired or replaced.
Good luck.
Apr 04, 2016 | Sanyo Televison & Video
Sylvania LC321SS9 B 32" LCD, won't turn on
Hi Stephen,
TV won't turn on means the power supply section is dead. Open the back cover if you can. Check up for the blown fuse. If the fuse is blown, replace a new one of the same rating. If the TV works, enjoy viewing and if the fuse blows again consult some TV tech. Never try another fuse with higher rating. It might seriously damage your TV. Good luck.
Apr 10, 2015 | Sylvania Televison & Video
Tv wont turn on
does the power indicator at the front panel blinking or in stand by mode. if no any indicator, look for the power supply board where in the power cord connected. replace blown fuse but before replacing new fuse make sure no other bad component like burnt parts or shorted. the fuse will blow again unless no other defective parts.
Sep 17, 2012 | Televison & Video
DOES NOT TURN ON
Hello
Open your TV and chekc whether the fuse in the power supply board has blown out or not. If it has blown out, never replace it with same type; befor troublshoot the reason for the blown out for the fuse. There must be some reason for the fuse to blow out. Without rectifying it, if you replace it with a new fuse, it may cause more damage to the set.
The power supply board to your TV will look like this.1_10_2012_4_00_19_am.jpg
Jan 09, 2012 | iLO LCT32HA36 Television
I try to turn the tv on but there is no power.
check the incoming power with a tester and if ok then check the plug fuse and if burnt replace and if ok proceed to open the tv cover and check the cable continuityand check the fuse in the power supply region if blown, check other components inthe power supply area and replace the faulty ones if any then open the fuse in the power supply and connect a 100w test lamp to see if there is a short circuit. if the bulb lights up and gets dim gradually you ca now remove the lamp and put backthe fuse and test again
however, your tv problem could be solved by simply replacing a burnt fuse but its always advisable to verify the cause of the blown fuse
Sep 21, 2011 | Sanyo Televison & Video
No power, stanby only
standby sont tv?...you need to open the back cover of your tv..check whether you fuse are blown/open...if yes,do not replace right away the fuse there might be a problem on the main supplys...using yuor multitester check your horizontal output transistor..it is located near the plyback transformer..if you do not now the correct testing of the transistor replace it with a new transistor...same with the regulator replace it with a new one...then replace the fuse ..your tv is now working again..
May 18, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Samsung Flat Screen Won't turn On
yea take your tv to a tech tv has a problem in the power supply there is 10mf cap in the power supply that likes to go bad replace it if that model does not have it check regulator and the microchip.however your problem lies in the powerand related circuit.good luck
Apr 02, 2007 | Samsung TXN3275HF 32" TV
Power surge I think
If you do not get any clicking or sound when trying to turn on the TV set, most likely the main fuse went out. This is almost always due to something else blowing out along or making the fuse to blow out. DO NOT SIMPLY REPLCE THE BLOWN FUSE! If there is other shorts inside the set, and you replace the blown fuse, you can cause more damage to the TV set. The best way to test this set if the fuse is blown would be to hook up a 100 to 150 watt light bulb across the blown fuse, and if there is a short in the TV set the light bulb will glow bright and stay bright. If the bulb lights up and goes dim maybe just maybe you got luck so replace the fuse and see what happens. If the light bulkb stays bright, there is a short in the set somewhere and if you do not have a service manual and a good multimeter and a knowledge of how the TV power supply works, you really should call in a pro to assist you in the repair of this TV. there is just too much High Voltage inside these TV sets to be experieenting around inside of it. Good Luck.
Mar 14, 2007 | Toshiba 36A43 36" TV
TV will not turn on when power button is pushed.
check the main fuse in the tv. test it with a multimeter, not visually. if its the thermistor that blew the fuse, it is very difficult to see the break in the wire. replace if blown. if unit blown fuse again withing a couple of weeks replace the thermistor in the degausing circuit. good luck.
Jan 09, 2007 | RCA F36665 36" TV
Televison & Video Logo
115 people viewed this question
Computer Repairing
Computer Repairing
