MSI computer randomly shutting down
I have a two year old MSI all in one computer and it is starting to randomly shut itself down several times a day. Do you know what is causing this? I was thinking it my be overheating, but it shouldn't be.
  • 32,281 Answers
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Posted on Jan 20, 2013
SOURCE: Overheating and shutting down..
rtyhfhfgh
Posted on May 01, 2008
Rhinoxeros
  • 3 Answers
SOURCE: Gateway P6860fx Shutdown
What you need to is Down Grade to windows xp 64 bit. This is what the system was really designed for trust me i bought mine back in april. and after 2 months of dealing with best buys idiots who know nothing other then commission on what they sell and some pakistani guy telling you that you voided something and it worked when they sold it to you. i Delved heavily into the mod scene to see what i could to do with my 1,300$ paper weight. After much searching and forum scouring i got all the drivers i needed to get back to xp 64 bit. right now my system only consumes 342 mbs of ram. i have the graphics card overclocked to 1084mhz using 177.66 forceware drivers from nvidia. i have absolutely no issues playing any games be it halo 2. crysis. age of conan. and my personal favorites the half lifes. i eat through games like its butter and online play no lag whatsoever on good servers. only issues for me is i am a 3d artist and have a couple of speed issues with renders inside of maya 2008 64 bit and zbrush. small stuff like plane clipping and overlay of desktop showing through when fully maximized. believe it or not thats it. i dont give a **** what people tell you about the sagers and the alienwares. My p6860fx scores around 12356 on 3dmarks06 but that program is just a reference for the uber dorks who hook up like car radiators to theyre computers trying to get a number that means nothing. its all about your jaggies thats it. the reason your laptop runs hot is because Vista is retarded and doesnt know how to manage anything even its self. if you look at your processes most of them are vista pinging microsoft trying to fix it self and it takes priority from you the user since microsoft is trying to get more feedback for sp2. ok hope this helps someone
Posted on Jul 18, 2008
  • 10 Answers
SOURCE: Random Shutdown
Toshiba's are notorious dust collectors, try blowing back through the air vents and some clever use of the vacuum cleaner on the intakes can bring it back to life. also check the RAM for dust and dirt on the pins and clean as required. USE ANTI-STATIC Precautions!
Posted on Feb 21, 2009
SOURCE: The scroll number lock goes on by itself
you can just press function+num lock and then it'll turn off and on when you want it to
Posted on Jul 29, 2009
durtopian
  • 408 Answers
SOURCE: Asus U52F laptop -- 1
Sounds like a faulty wireless card or the card is installed with the wrong version driver.The wireless card itself sounds to be bad and needs replacing
Posted on Jan 11, 2011
Notebook stuck in update mode after using a dual monitor
leave it alone, it will install several hundred more updates over the next day or two...it should shut itself offf afterwards
Jul 09, 2015 | MSI U210-008US Notebook
Compaq presario shutdown
you might need to replace the monitor
Sep 21, 2013 | Computers & Internet
1990 dakota engine shutting down randomly
I had a 1988 dodge Dakota ,and it did the same thing. I fould that the o2 sensor was bad. I am a self employed mechanic
Oct 28, 2012 | Dodge Dakota Cars & Trucks
My Goodman model GMS90703BXA has a problem wherein after a cycle, the ventilator / discharge fan doesn't shut down properly. It stays on after the burner has shut off and after the main fan has shut off. ...
Hello, usually this happens when the pressure switch remains open, this could be due to a blocked flue pipe, water inside the tube between inducer motor and pressure switch, or the switch itself is going bad. Condensation can form and leak back to the pressure switch through the tubing and causing an intermittent problem with the inducer motor running continuously
Mar 01, 2011 | Goodman GMS90703BXA Heater
Asus U52F laptop -- 1 week old, a few days ago the internal wifi network adapter started randomly shutting itself off here and there throughout the days. Occasionally it switches itself right back on, but...
Jan 10, 2011 | ASUS U52F-BBL9 Laptop
I have a Fujitsu 42'' PDS4221 - 10 years old - shuts itself off
See Fixya tips and tricks:-
'Fujitsu Plasma 42" random shutdown - continuous flashing red'
While the model of your set is slightly different, the checks described generally still apply, as it is very similar.
Nov 18, 2009 | Cars & Trucks
42 inch Samsung DLP TV shuts off by itself. I can turn it back on and sometimes it stays on and other times shuts off within seconds. Some days it stays on all day without a problem. Other days it shuts...
I bypassed the safety switch (it was bad) and vacuumed and blew out all of the dust. So far with this set, 3 years old, I have replaced the bulb twice,it exploded both times, and the color wheel which also exploded! We love the picture but the next time it goes out, it goes out to the trash and I will purchase a top of the line LED/LCD set. No moving parts!!! Samsung designed and manufactured a whole bunch of lemon sets and will not admit it. I have found several hundred complaints about their DLP sets and only a few on other brands.
Jul 31, 2009 | Samsung DLP HL-P5663W 56" TV
Restart
Change out the power supply. Dell had this problem with one of there desktop product lines.
Oct 07, 2007 | Acer Altos G700 Server
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
